Lower oil pan replacement
Discussion in '1st Gen Tundras (2000-2006)' started by KPAT, Sep 3, 2022.
  1. Sep 3, 2022 at 4:52 PM
    KPAT
    KPAT [OP] New Member
    Hey everyone, I'm new here but have been reading threads as a guest for a while. So I have a 2006 Tundra double cab and have always done my own maintenance. My last oil change I had part of the threads come off where the plug goes. I did get the plug in, with a little determination, but I'm nearing my next change and I'm afraid the plug isn't gonna cooperate a second time. Has anyone replaced the lower oil pan and is it a do it yourself job?
  2. Sep 4, 2022 at 8:43 AM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    2wd or 4wd will be the biggest determining factor on how easy it is I believe.
  3. Sep 4, 2022 at 9:04 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    W.I.P - FOX 2.5 with DSC, SCS F5 wheels with MT Baja ATZ 285s
    Yup. It’ll probably be a PIA. I believe there’s a crossmember in the way which means you have to raise the engine to get it out. If you have 4WD then you also have the front diff to move out of the way. I’m not looking at a diagram right now so can’t say definitively if that’s the case. Hopefully someone with more experience will chime in.
    Usually, people will use a threadsert and a larger plug to replace it. Next oil change try cleaning the threads and re-tapping it. Might be able to save it.
    KNABORES, FirstGenVol and NickB_01TRD like this.
  4. Sep 5, 2022 at 7:33 AM
    KPAT
    Thanks for the responses. It's a 2wd and I was afraid you had to lift the engine. I may try the re-tapping option and try to get a few more oil changes out of it.
  5. Sep 5, 2022 at 10:07 AM
    chunk
    chunk New Member
    110 miles north of Los Angeles, Ca.
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    If you can get any sealing on the bad threads, maybe think about one of those quick change valves. They thread in, and never need to unscrew, they use a lever to open to drain after installation.
  6. Sep 6, 2022 at 4:44 PM
    KPAT
    I'll look into that. The biggest problem is the threads aren't just bad, they were literally breaking off. Luckily it was only the first of them but who knows when I take the plug out again. I appreciate the responses and suggestions.
  7. Sep 7, 2022 at 3:13 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    FirstGenVol and Tundra2 like this.
  8. Sep 7, 2022 at 2:03 PM
    KPAT
    Thanks tvpierce, I didn't know about those. I'm due for an oil change this weekend so I'm gonna look that pan over good to see what my best option is. I really like doing my own maintenance and repairs.
  9. Sep 7, 2022 at 3:59 PM
    KPAT
    What is everyone's opinion on valvomax drain plugs?
  10. Sep 7, 2022 at 6:33 PM
    chunk
    chunk New Member
    It looks good, low profile and a sealed dust cap as a secondary seal. I'm not clear exactly what they called an actuator is, that pushes the check valve ball off the seat to let the oil flow. But it looks well thought out. Should be fine from that aspect. If you can repair the threads and find a device like this to match the new threads in the pan, that should be a good fix, unless there are enough threads left in your pan now, but it sounds like a tap to the next size up is in your future. Sure beats having to jack up the motor to replace the pan though.
    https://www.valvomax.com/
    dbittle likes this.
  11. Sep 8, 2022 at 3:05 AM
    tvpierce
    Maine
    I'd never heard of them, so checked out the link posted by @chunk. Looks like a well thought out product, and appears to be well made. But IMHO, needlessly complex for a Tundra. I've had vehicles where the oil drain plug was hard to reach, or that the oil when draining didn't have a clear path to the drain pan. In those cases something like this makes sense. If I was going to use one though, I think I'd go with https://www.fumotousa.com/
    Whatever you decide, you're still tapping up to the next size. The valve is just adds an extra convenience feature.
  12. Sep 8, 2022 at 4:06 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Y'all running the long nipples or the short nipples?
    bmf4069 likes this.
  13. Sep 8, 2022 at 7:44 AM
    chunk
    chunk New Member
    I've never been a fan of any of these quick oil change thingies, it always seemed a solution in search of a problem. I use a new Toyota drain plug washer every drain and don't over tighten the plug. No leaks or stripped hole, of course I've never let one of those oil change apes near it in 21 years, that's probably why I still have good threads in my oil pan.
    bmf4069, w666 and shifty` like this.
  14. Sep 8, 2022 at 8:34 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    id like to try playing with longer nipples, short nipples are probably less exciting.
    i got a bellypan idea i'm working on, and am gonna want to have all my drains accessible with a small door for the filter. Recessed plugged valves would be cool. Take the plug off, and turn the valve to drain. Plug for safely.
    1/4" square socket, because i have a 4" long 1/4" drive breaker bar. If its windy, or i wanna dump it into a small neck bottle, i could stuff a hose onto the plug threads.
    Think i might use my '80 fords rear 10 gal tank where the spare tire hoist resides, and the step in the bellypan could keep a quick connect valve system safeish. Kinda wanna tuck some house batteries up in the bedsides...
    bmf4069 and Tundra2[QUOTED] like this.
  15. Sep 8, 2022 at 10:03 AM
    shifty` Countin' and breathin', disappearin' in the fade
    tvpierce, Mr.bee[QUOTED] and bmf4069 like this.
  16. Sep 8, 2022 at 11:01 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
