Lower grill LED strip wiring question
Discussion in 'Lighting' started by trooper669, Jul 23, 2018.
  1. Jul 23, 2018 at 3:57 PM
    trooper669
    trooper669 [OP] New Member
    2018 1794 MGM
    TRD front and rear sway bars/ CAI. Recon smoked tail lights. LED Bed Lights. LED grill lights Bilstein 6112 front and 5100 rear. RC 1” rear block. RC lower grill LED bar. Nitto Ridge Grapplers 295x60x20 on Fuel D-251 couplers. SDHQ ABS covers. Rear under seat storage. Body mount rebuild. Color matched mirrors, handles. Raptor step bars.
    For those of you running lower grill LED strips, I bought a RC 30' strip. My question is how intensive is the wiring for these types of strips? Thanks!
  2. Jul 23, 2018 at 6:34 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Easy, just make sure you use a relay. Google relay wiring diagrams. Did the light strip come with relay and wires? I like waterproof heat shrink butt connectors if splicing anything. I used spades at lights. I installed a Mictuning switch left of steering wheel. Hooked up illumination on nearby switch. Plenty of write ups in lighting section.
    parker44 likes this.
  3. Jul 24, 2018 at 3:51 AM
    trooper669
    2018 1794 MGM
    Thanks stump. I’ll look further when I have a moment.
  4. Jul 24, 2018 at 4:59 AM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    Most of the light bars come with a relay if they have any wiring included. They are very close to being plug and play, but getting the switch through the firewall is the challenge
  5. Jul 24, 2018 at 6:25 AM
    Cuzican
    Cuzican New Member
    Louisiana
    2017 Black Platinum Crewmax Tundra
    8" Lift, 22x10 Fuel Forged FF19, 37x13.50r22 Trail Grapplers, Amp Research steps, Spyder black smoked headlights with 35w HID's, all interior lights LED, Undercover tonneau.
    My Rough Country LED bar came with a wiring harness that had the relay in it, just had to de-pin and re-pin the connector to the on/off switch to make it easier to get through the firewal.
  6. Jul 24, 2018 at 6:48 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    I cut off the cheap switch and taped the wire to a kebab spear, used a flathead screwdriver and pryed open the firewall plug just enough to push the wire through into the cabin. I then added a LED bar switch and fuse tapped it to get the switch to light on and off.
  7. Jul 24, 2018 at 7:03 PM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    Same as mine except in daylight. My bars came with switches but they will not fit in Tundra blanks so I got the Mictunings. I bought a second one because the case came apart on the first. I pushed it too hard. Removed and snapped back together. They could use a little glue on the case. Have 2 bars. One switch, 2 relays.
  8. Jul 24, 2018 at 7:09 PM
    Just running the wire harness through the fire wall was a bit of hassle that's about it, I have the dbl row in lower grille and single row below bumper
  9. Jul 24, 2018 at 7:19 PM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    It is pretty simple. Just look for write ups in lighting section. Google wiring diagram for relays and whatever switch you buy. If you plan to illuminate switch just tap in to nearby factory switch. Factory wires very light gauge so get a small gauge tap.
  10. Jul 24, 2018 at 7:21 PM
    trooper669[OP] likes this.
  11. Jul 24, 2018 at 7:34 PM
    Baldmonkey22
    Baldmonkey22 New Member
    Quartz Hill, Ca
    Quick tip, take an old antenna and sharpen the end. Then push it through the firewall boot away from the harness tape the wires to it then pull it back through. If it's tough little spray of Wd40 helps.
    Running wires this way the boot seals around them and you have no leake or wires pinched between the boot and metal of the firewall.
  12. Jul 24, 2018 at 7:36 PM
    Now ya need the LED backlit TOYOYA letters from @Sting Ray
    Sting Ray likes this.
  13. Jul 24, 2018 at 8:40 PM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    I think mine is a Mictuning too or version of it, was off Amazon, I had to trim it to fit in the blank switch space.
    The original switch that came with the light bar was tear drop shaped with a small push button. It also came with a remote keyfob which I used for while until I wired it into the cabin properly.
    I wonder if OP's bar did not come with wiring/relay/switch.
  14. Jul 24, 2018 at 8:48 PM
    Yeah if it's a RC light bar he bought from them they come with everything you need, plug n play
    JoshuaA[QUOTED] likes this.
  15. Jul 25, 2018 at 9:09 AM
    trooper669
    2018 1794 MGM
    Good info, thanks!
