Lower dash button... TPMS?
Discussion in '2.5 Gen Tundras (2014-2021)' started by TTU19, Oct 20, 2016.
  1. Oct 20, 2016 at 3:02 PM
    TTU19
    TTU19 [OP] Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    Ok, because I'm not able to read my manual and I just thought about it, I wanted to ask here. On the very lower side of the dash, there is a small SET button. From what I understand, that is a way to reset or set the TPMS on the tires. Can someone explain this better for me?
    Also, I have an SR5, am I mistaken that there isn't a way to see individual tire pressure amount? It only shows the indicator if the tires go low. My wife's TRD Sport Tacoma reads each tire pressure. I don't see that anywhere on the Tundra.
    Is there an aftermarket part to be able to see the individual tire pressure number?
  2. Oct 20, 2016 at 3:49 PM
    jberry813
    jberry813 The Mad Scientist Staff Member
    Lake Tahoe
    2015 Tundra Platinum, 2012 Tacoma, 2007 T4R
    Metric shit ton of parts
    Pushing and holding the SEt button will reset the TPMS to run at the pressure that's currently in your tires vs whatever it's set at from the factory.
    You can view individual tire pressures with a scangauge or similar.
  3. Oct 20, 2016 at 6:41 PM
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    2024 Honda Ridgeline Black Edition
    What he said ^^^^^ but not in your dash. You have to use a scanguage to see it. Helps a lot when you are on the road and the TPM error light comes on. Happened to me on vacation with under 2,000 miles as we approached out hotel. So I just waited overnight and voila, it was obvious! I guess they figure you'll just check each tire LOL
