Lower control arms?
Discussion in '1st Gen Tundras (2000-2006)' started by Daq_daddy, Aug 26, 2019.
  1. Feb 8, 2023 at 4:04 PM
    Pronto13
    Pronto13 New Member
    ‘06 white DC SR5 V8/4wd
    How are those moog LCAs doing?
  2. Feb 9, 2023 at 3:10 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    I used moog on my sequoia about a year and half ago. They are fine for cheap. The Sequoia is kind of my beater so I don't care a whole lot, if it was a different car I would have replaced with OEM or replaced the OEM bushings with Siberian (If you can get them anymore).
    Pronto13[QUOTED] likes this.
  3. Oct 9, 2023 at 1:17 PM
    Aaol1
    Aaol1 New Member
    Sam
    05 DC tundra TRD offroad 4x4 V8 w/ LSD and tow
    2 inch lift, diff drop
    @growit how did it go / is it going with the AC delco Gold LCA? im thinking im going to go for those, just not finding much info on anyone running them
  4. Oct 9, 2023 at 1:19 PM
    Aaol1
    Aaol1 New Member
    Sam
    Anyone run those SPC cam bolts and have good success with them?
  5. Oct 9, 2023 at 1:23 PM
    I believe the last thing I read here was the SPC had the same shortcomings as other aftermarket: The sleeves were plastic or otherwise garbage and failed in short order.
  6. Oct 9, 2023 at 1:36 PM
    Aaol1
    Aaol1 New Member
    Sam
  7. Oct 9, 2023 at 1:47 PM
    I'm not a huge fan of Moog parts these days. I used to be a total fanboi about their stuff. I'd ask around before using.
  8. Oct 10, 2023 at 3:09 PM
    rock climber
    I had not success, they are garbage. Just go oem, the design is so much more robust. Or use cam eliminator plates.
  9. Nov 23, 2023 at 11:29 AM
    2006Tundra
    2006Tundra Financially Irresponsible
    Lou
    Long Beach, CA
    2006 Toyota Tundra Double Cab SR5, 4.7L V8
    In the market for some LCA's. I would rather have OEM but what's a good alternative?
  10. Nov 23, 2023 at 11:45 AM
    Aaol1
    Aaol1 New Member
    Sam
    I went with mevotech supreme. I know it's not a popular alternative but I had a bit more faith in their supreme parts VS regular mevotech. Available on rockauto. Seemed like a decent part when I installed em, just make sure you do final torque on the ground with vehicle on its own weight
  11. Nov 23, 2023 at 11:46 AM
    2006Tundra
    Lou
    Long Beach, CA
    How long ago did you install them? Any issues?
  12. Nov 23, 2023 at 11:48 AM
    Aaol1
    Aaol1 New Member
    Sam
    Not too long ago, no issues at all with anything but yea I definitely don't have a long term review for you unfortunately. I can definitely say though for cam bolts and plates, stay away from anything aftermarket. OEM is stupid expensive, there's just no avoiding it. Reuse everything you can from old ones, I managed to save 3 plates and all bolts. Just needed the sleeves and 1 plate
  13. Nov 23, 2023 at 11:50 AM
    2006Tundra
    Lou
    Long Beach, CA
    Thanks. Yeah, I plan on reusing cam bolts. I'm hoping I don't need to replace them.
  14. Nov 23, 2023 at 12:51 PM
    Aaol1
    Aaol1 New Member
    Sam
    Right, sleeves you may not be able to reuse
  15. Nov 23, 2023 at 2:12 PM
    2006Tundra
    Lou
    Long Beach, CA
    do you have a part number for the sleeves?
  16. Nov 23, 2023 at 2:18 PM
    Aaol1
    Aaol1 New Member
    Sam
    2006Tundra likes this.
  17. Nov 23, 2023 at 4:59 PM
    GreenMachineDream
    GreenMachineDream New Member
    West Central, OH
    2002 Tundra SR5, 4WD, RCLB, Metallic Green
    Lower suspension go OEM all day! LCAs, LBJs, Cam bolts, Sleeves, the whole thing. Don't cheap out and go another 200k of peace of mind IMO. Whatever you decide wishing for the best!
    Dook55 and 2006Tundra like this.
  18. Nov 23, 2023 at 5:15 PM
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    I recently put SuperPro LCA's on my GX project. Basically stock Arms with upgraded poly bushings. And cheaper than OEM
    @memario1214 can supply them
  19. Dec 11, 2023 at 6:34 PM
    #49
    AmericanKing06
    AmericanKing06 New Member
    New Mexico
    04 Toyota Sequoia aka Dadwagon
    I did white line bushing and 555 BJ on my 03 GX. The bushing were a PIA to remove. I used the bottle jack mention. Soaked in PB oil, NM car its whole life still kicked my ass.
    I'm needing to replace my LCA on my 04 Sequoia can someone chime in on their experience with aftermarket LCA time, mileage and usage of vehicle. I will be doing a lift at the same time. 2inch fox DCS Coil overs with JBA UCA. Ive installed OEM LBJ about 5k miles ago.
