Lower bumper valance removal
Discussion in 'Deals & Group Buys' started by Stocky Balboa, Oct 26, 2019.
Thread Status:
Not open for further replies.
  1. Oct 29, 2019 at 2:44 PM
    tinman10101
    tinman10101 Ah cha cha cha
    Tinman
    2016 MGM Crewmax
    Thanks for the info. I guess I'll see once i remove the bumper. I do see on their website they have brackets for different gens and quite possibly they sent you the wrong one. In any case, thanks for your advice.
  2. Oct 29, 2019 at 2:49 PM
    Jrharvey02
    Jrharvey02 New Member
    2010 Tundra CM 5.7 Platinum Dark Black
    It was securely packaged and the printed on label was 2nd Gen. I really don’t think there’s a difference between their 2nd and 3rd gen brackets as there’s only slight differences between the entire bumper assembly of 2 and 3 gens...I’d put $ on it... the website pics sure look identical and I can tell you I received exactly what your pic shows.
    edit: and at the end of the day, Rago is superior steel and powder coated, it will last.
    tinman10101[QUOTED] likes this.
  3. Oct 29, 2019 at 6:34 PM
    Stocky Balboa
    Stocky Balboa [OP] New Member
    OC , CA
    2018 Limited TRD 4x4 CM - Cement
    Minor stuff- Tint, rear sway bar , pedal commander, TRD drop in filter DD Exhaust, Bilstein 6112/5160, stealth 32” lightbar, Cali Raised Offroad fog light replacements.
    Called at noon-ish & No call back from Cali today. Not off to good start.
  4. Oct 29, 2019 at 7:54 PM
    Stocky Balboa
    OC , CA
    After looking at your pic more, and another video I think those series of bolts might for the center might be accessible by removing the fog lights and reaching in with a 1/4 drive mini ratchet. I might be able to try this tomorrow but my BA exhaust is suppose to be delivered....
  5. Oct 29, 2019 at 8:45 PM
    tinman10101
    Tinman
    2016 MGM Crewmax
    Wow you are determined not to take off the whole bumper. Lol
    booyaa and Jrharvey02 like this.
  6. Oct 30, 2019 at 6:54 AM
    paradizecityz
    paradizecityz New Member
    Richmond, TX
    2022 Tundra TRD Off Road
    Should really take off the bumper. I went in with no knowledge and winged it and did it without taking the bumper off, took much longer and much more inconvenience...lol
  7. Oct 30, 2019 at 7:03 AM
    booyaa
    booyaa New Member
    You must remove the entire bumper to remove the front valance properly. Like a previous poster said - it is attached to the end caps from behind the cap itself.
    Just do it and learn how the thing is assembled so moving forward subsequent mods will be easier. It’s not hard at all.
  8. Oct 30, 2019 at 10:31 AM
    Stocky Balboa
    OC , CA
    Anyone got some info/steps on how to remove the entire bumper, might save me from breaking something? ‘18
    Thanks
  9. Oct 30, 2019 at 10:33 AM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Look at this video. Seems this is the easiest way to remove bumper
    https://youtu.be/PhV9hduOSBU
  10. Oct 30, 2019 at 10:40 AM
    Stocky Balboa
    OC , CA
    Got it. Thank you.
  11. Oct 31, 2019 at 8:34 AM
    booyaa
    booyaa New Member
    not in order - but i followed these
    Screen Shot 2017-01-24 at 4.00.40 PM.jpg noScreen Shot 2017-01-24 at 4.00.32 PM.jpg Screen Shot 2017-01-24 at 3.56.56 PM.jpg Screen Shot 2017-01-24 at 3.58.50 PM.jpg Screen Shot 2017-01-24 at 4.00.24 PM.jpg Screen Shot 2017-01-24 at 3.59.38 PM.jpg Screen Shot 2017-01-24 at 3.59.28 PM.jpg Screen Shot 2017-01-24 at 3.56.49 PM.jpg Screen Shot 2017-01-24 at 3.59.20 PM.jpg Screen Shot 2017-01-24 at 3.58.58 PM.jpg Screen Shot 2017-01-24 at 3.56.35 PM.jpg Screen Shot 2017-01-24 at 3.59.10 PM.jpg
    Beesta, SNO BUS and Stocky Balboa[OP] like this.
  12. Oct 31, 2019 at 8:44 AM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    i have this same kit. I followed their video and just remover the grill and left the bumper on. I was able to install the brackets and light bar.
    do you have to remove the bumper for your kit?
  13. Oct 31, 2019 at 9:15 AM
    Stocky Balboa
    OC , CA
    Here’s the Cali brackets installed for the next guy.
  14. Oct 31, 2019 at 9:18 AM
    fisherman951
    Tony
    2017 crewmax 4x4
    So how did u remove the bumper after all?
  15. Oct 31, 2019 at 9:25 AM
    Stocky Balboa
    OC , CA
    Did some more research and I didn’t. Pulled the center part off. It breaks the few plastic tabs and done. Those tabs have no effect on the center plastic piece going back on securely. There’s still 9 bolts that hold that section on. IMO no need to remove the whole bumper. Much faster and easier to get to in the future for any tweaks On the lightbar.
  16. Oct 31, 2019 at 11:11 AM
    paradizecityz
    Richmond, TX
    Was yours the the lower bumper or behind the grill?
    I didn't mean to say that you can't do it with bumper on, I was just saying that it's harder with bumper on
  17. Dec 23, 2019 at 7:25 PM
    DblGobble
    DblGobble New Member
    Tyler
    2014 Black SR5 Crew Max 5.7L
    Any trick to making this work? I see you mention other research, I've been searching for hours tonight and haven't found anything explaining it. Any help would be appreciated, looking to install mine this week
  18. Dec 23, 2019 at 7:27 PM
    Jrharvey02
    I think he explained it pretty clearly. You either break the shit out of the black plastic piece or you spend 45 min. removing the necessary bolts and do it right.
    FREEK likes this.
  19. Dec 23, 2019 at 7:58 PM
    #49
    Stocky Balboa
    OC , CA
    There’s a guy on YouTube who is plasti-dip’n his bumper caps and in his video he briefly shows and talks about the plastic mounts that snap off.
    Essentially you just pull on the black center piece and it comes off fairly easy. Barbaric right haha.
    IMO If I had to do it over I would snap that center section out again. As mentioned some folks say its only 45min to remove the whole bumper etc... I don’t see any need to do all that. It made no difference with the plastic tabs broken off.
    I can take my grill off and remove that center section in 5 mins to do any adjustments to my Lightbar or to add anymore items in the future.
    Again, to each his own and I did appreciate all the feedback on removing the entire bumper but for me this works great.
    Cheers
  20. Dec 23, 2019 at 7:59 PM
    #50
    Stocky Balboa
    OC , CA
  21. Dec 23, 2019 at 8:21 PM
    #51
    DblGobble
    Tyler
    Preciate it, yeah I'm short on time as it is. If it doesnt hurt the structural integrity of it I'm not worried about it. I just didnt know if you had to tilt and pull or anything like that or just pull straight off
Thread Status:
