Lower ball joints/part numbers
Discussion in '1st Gen Tundras (2000-2006)' started by Jasont, Oct 23, 2021.
  1. Nov 2, 2021 at 10:14 PM
    #91
    stevechumo
    stevechumo New Member
    Most aftermarket suspension parts look and operate like OEM. Yes, but they don't last. Been there and done that.
    Diablo169 and des2mtn like this.
  2. Nov 3, 2021 at 6:54 PM
    #92
    AWilliams
    AWilliams New Member
    ok...so I just did my lbj's with new oem but didn't but I didn't use new bolts. I never really thought about replacing them. Please tell me I can replace these one at a time while on the truck vs. taking the whole thing apart again?
  3. Nov 3, 2021 at 6:58 PM
    #93
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Put them in one at a time tight, then torque appropriately is what I would do. I may be corrected - but that should be no problem , IMO
    AWilliams[QUOTED] likes this.
  4. Nov 3, 2021 at 7:57 PM
    #94
    Sunnier
    Sunny
    San Diego, CA
    Yes, you can. But torque as you go.
    des2mtn, AWilliams[QUOTED] and alb1k like this.
  5. Nov 5, 2021 at 9:41 PM
    #95
    10 blue trucks
    10 blue trucks New Member
    04 4WD RCLB
    I did LBJs and didnt do new bolts. I cant say it was right, but I can say nothing has gone wrong. 15k miles so far. YMMV. I have periodically checked the 4 bolts. They don't seem to be loosening.
    Richid, des2mtn and alb1k like this.
  6. Nov 6, 2021 at 6:26 AM
    #96
    des2mtn
    On the Scenery, Looking at the Road
    2004 Black DC Limited 4x4
    Tonto cover
    You can always mark the LBJ bolts with paint pen for a quick visual. Another good practice that Dan recommended is throwing a torque wrench on them every oil change.
  7. Nov 6, 2021 at 7:13 AM
    #97
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    If you can get them to torque. If not, start with Noah's method of gradually increasing the torque spec. Get it to click at 25, 35 etc. That's what I had to do.
  8. Nov 6, 2021 at 3:27 PM
    #98
    16CMTXED
    16CMTXED New Member
    Gary
    Central Texas
    2016 Tundra CM
    Eibach Pro Sport Shocks (1.25in), RAS HD, Sumo Springs, HAWK Talon Rotors, OEM Tow Mirrows, Lund Hard Fold Tonneau, ESP Storage, Stampede Flares, Husky xAct Fit liners, General Grabber ATX 275/60R20
    My 16yo son and I just finished the install of OEM LBJ from McGeorge Toyota on his 06 2WD Dbl Cab. Thanks to this thread for the free shipping coupon code. We also had front rotors turned and installed Hawk LTS pads on front end. We removed the stock coilovers and will be dropping off at a local shop to swap over the stock coils onto Bilstein 5100's, set in middle slot. Waiting on new tophats from Wheelers (should arrive on Tuesday) to also have installed along with shocks. So, right now the truck is on jacks, until we get the shocks assembled. All is reassembled on the front end now. When I install the coilovers, what will I need to unbolt/loosen to have enough room for the now longer coilovers? Lower control arms? Swaybar? I appreciate any feedback. I bought new in 06, then sold to my brother in 15' (with 75k miles), and just bought back a couple months ago (now right at 150k miles). Been working on it since for my boy. Pic shows his Tundra on right, mine in middle and momma's Sequoia on left.
    G_unit3000, BR73, ivbyiv and 6 others like this.
  9. Nov 6, 2021 at 3:35 PM
    #99
    des2mtn
    Tonto cover
    Nice trucks!
    I would disconnect the sway bar links from the lower control arms. Good chance those will want to fight you. When I first put in longer coilovers, I was able to pry down on the lower control arm enough to get the shock in. I didn't have to touch the cam bolts. I'd definitely try that first.
    If you can't get them in that way, you can mark your cam plates on the LCA and the frame to keep your alignment as close as possible, then loosen the cam bolts to allow the LCA more movement.
    DaWhiteTundra, Darkness and Sunnier like this.
  10. Nov 6, 2021 at 4:57 PM
    #100
    16CMTXED
    16CMTXED New Member
    Gary
    Central Texas
    2016 Tundra CM
    Thanks @des2mtn!
    I'll try what you recommended when reinstalling the coilovers and post some pics afterwards.
  11. Nov 29, 2021 at 2:55 PM
    #101
    Alltimehigh
    Alltimehigh New Member
    Ordering lower ball joints today for my 2004. In my cart Ive got
    Part Number: 4334039595
    Part Number: 4333039825
    but what is the correct part no for the bolts that go with these? Is it
    90105-A0187
    or
    90105-12316
  12. Nov 29, 2021 at 2:59 PM
    #102
    des2mtn
    Tonto cover
    90105-A0187 is the part number for the 8 bolts. That's what I used.
    Sunnier likes this.
  13. Nov 29, 2021 at 3:03 PM
    #103
    Alltimehigh
    @alb1k
    How'd those bolts work out? Wrong size?
  14. Nov 29, 2021 at 4:06 PM
    #104
    alb1k
    Left Coast
    It's good
    No, exact parts, they are fine. Just wanted to be sure I was torquing them enough.
    Edit: whenever I order parts, I put in my VIN
  15. Nov 29, 2021 at 4:20 PM
    #105
    Jack McCarthy
    Jack McCarthy Happy hour; beer goggles, not a fake profile.
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    I don't have issues with my LBJ bolts loosening due to nature's loctite...rust.
  16. Nov 29, 2021 at 4:55 PM
    #106
    Alltimehigh
    Unfortunately they both say they fit my VIN and we have 2 people saying they used 2 different sets of bolts. Flip a coin or buy both I guess.
  17. Nov 29, 2021 at 4:58 PM
    #107
    alb1k
    Left Coast
    It's good
    I bet they are the same bolts, but that is weird.
    des2mtn likes this.
  18. Nov 30, 2021 at 5:59 AM
    #108
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Ditto
  19. Nov 30, 2021 at 6:12 AM
    #109
    alb1k
    Left Coast
    It's good
    I bought a bolt X 8. I'll see if I can find my part number, but I'm wondering if it is numbers for a set of 8 vs. 1
  20. Nov 30, 2021 at 6:19 AM
    #110
    des2mtn
    Tonto cover
    I had to buy a bolt x 8 as well and entered my VIN. They were identical to the ones I took out.
    I just pulled up a parts diagram from Toyota and both part numbers were listed. There's apparently two more part numbers that fit here? (90105-10505 & 90119-10933). @NWPirate 's picture below shows that 90119-10933 obviously isn't right though...
    https://parts.toyota.com/showAssemb...ukey_driveline=0&ukey_trimlevel=0&modelYear=0
    Sunnier and alb1k[QUOTED] like this.
  21. Nov 30, 2021 at 6:19 AM
    #111
    alb1k
    Left Coast
    It's good
    This is 05' Tundra
    Order Contents:
    P/N Quantity Price Each Description
    9010512316 8 $ 1.76 BOLT
    FOR FRONT LOWER BALL JOINT LEFT; FOR FRONT LOWER BALL JOINT RIGHT.
    des2mtn likes this.
  22. Nov 30, 2021 at 6:24 AM
    #112
    alb1k
    Left Coast
    It's good
    Looks like have your vin and look them up, or call the dealer if you like. Sometimes same parts have different numbers due to updates or whatever. Bolts don't change a whole lot in construction.
  23. Nov 30, 2021 at 6:42 AM
    #113
    NWPirate
    Zach
    WA
    I'm in the same boat looking for the right bolt, I think there are multiple options for different years. AC, DC and Sequoia. I bought these a while ago but they are clearly undersized, and have a loose washer. My Sequoia bolts have a 17mm head.
    Punk1974 and des2mtn like this.
  24. Nov 30, 2021 at 7:31 AM
    #114
    Jack McCarthy
    Bill
    North of Boston
    02 AC Tundra has the 14mm bolts w/washer
    NWPirate and Punk1974 like this.
  25. Dec 6, 2021 at 5:10 PM
    #115
    dman409
    dman409 New Member
    Does anyone know if the bolts are included in the kit 04006-62134?
  26. Dec 6, 2021 at 5:18 PM
    #116
    des2mtn
    Tonto cover
    DaWhiteTundra and Punk1974 like this.
  27. Dec 6, 2021 at 6:09 PM
    #117
    dman409
    dman409 New Member
  28. Jan 21, 2022 at 11:49 PM
    #118
    stevechumo
    NWPirate and w666 like this.
  29. Jan 26, 2022 at 4:44 AM
    #119
    bmf4069
    bmf4069 Captain wtf
    Beau
    TX
    02 AC sr5 4wd v8
    ColoradoTJ likes this.
  30. Jan 26, 2022 at 4:53 AM
    #120
    Done.:thumbsup:
    bmf4069[QUOTED] likes this.
