Lower ball joints/part numbers
Discussion in '1st Gen Tundras (2000-2006)' started by Jasont, Oct 23, 2021.
  1. Oct 26, 2021 at 8:28 PM
    #61
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    Ahh yes... A souvenir. Better to get one than give one I guess.
    bmf4069 and Darkness like this.
  2. Oct 26, 2021 at 8:59 PM
    #62
    aredub
    aredub Supply Chain Guru
    USA
    2001 Tundra SR5 AC 4.7 2WD & 2025 Tundra Pro
    King Coilovers, Pro Comp Wheels, BFG KO2s, Kenwood head unit
    Thanks so much for the info as well as your generosity :cheers:
  3. Oct 27, 2021 at 1:25 AM
    #63
    ToyoLife
    ToyoLife New Member
    06 DC Limited 4x4
    Thank you kind sir! Looking to replace LBJ on my 06 limited. Went to all 3 sites, the Mcgeorge with the "freeship" promo code was the least (Far Left). Still no clue on where to buy Bolts tho.....
    jerryallday[QUOTED] likes this.
  4. Oct 27, 2021 at 2:07 AM
    #64
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    The bolts are 90105-A0187 (4 per), also from McGeorge
    jerryallday and bmf4069 like this.
  5. Oct 27, 2021 at 4:33 AM
    #65
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    04 Tundra AC, 2014 Tundra 1794 Crew Max
    Whole truck Raptor liner in olive green, leer camper cap, 5100 with OME, Wheelers AAL and Firestone Air bags.
    I'm going to call the dealer nd find out about this LBJ kit which is part number 04006-62134. It's around $180 for both.
  6. Oct 27, 2021 at 5:08 AM
    #66
    w666
    Maryland
  7. Oct 27, 2021 at 5:36 AM
    #67
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    I believe that is for the earlier 1st gens that has different LBJ and kit # is different.
    Late 04 - 06 kit # 04006-62134
    Early 02- 03 kit# 04005-21134
    Early 01- 02 kit# 04005-04134
    Can some verify?
    jerryallday likes this.
  8. Oct 27, 2021 at 6:28 AM
    #68
    daveeasa
    David
    So if we are 2002, how do we know which one?
  9. Oct 27, 2021 at 6:30 AM
    #69
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    I think you cross reference your VIN, or call the dealer with your VIN
    Sunnier and des2mtn like this.
  10. Oct 27, 2021 at 6:39 AM
    #70
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    Called the dealer and they can't cross reference no part number that starts wit a 0.
  11. Oct 27, 2021 at 9:08 AM
    #71
    alb1k
    Left Coast
    It's good
    I just went online and entered my VIN. Funny how the over the phone price is almost 50% more than the online price. Even with instore pick up. You should be able to get them for about $120 each ordering online. Call or walk in and 175-200 each.
  12. Oct 27, 2021 at 9:09 AM
    #72
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    I bought a pair of Detroit Axle LBJ's last Feb and have put 5K miles on them without problem. I'm stating to rethink that. I may have to run down to the local NAPA and see what they have. Maybe have them get a set of MOOG joints and pick them up if they have the 555.
  13. Oct 27, 2021 at 12:54 PM
    #73
    alb1k
    Left Coast
    It's good
    Just ordered mine. Thank you @Darkness for your willingness to help and your advice!
    Will do LCAs at the same time, and weld up the spindle gussets…
    JasonC., Sunnier and des2mtn like this.
  14. Oct 27, 2021 at 1:00 PM
    #74
    daveeasa
    David
    yeah I got mine too, you guys also doing LCA's too? Is there a good reason to swap those out if not going LT?
  15. Oct 27, 2021 at 1:06 PM
    #75
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    I replaced my original LCAs because the bushings were shot. I think the bushings are around $70? I don't have the right tools to press out the bushings and I didn't want to try a bottle jack to press them out, so I just bought new arms. I didn't realize how bad my bushings were until the new arms were in.
    If Speed Freek is doing your front end work, see what he thinks because he might be able to replace just the bushings and save you a little money. If you're doing it yourself, replacing the LCAs which already have the bushing pressed in is very easy and fast as long as there isn't rust.
    daveeasa[QUOTED] and Sunnier like this.
  16. Oct 27, 2021 at 1:06 PM
    #76
    Cummins3500
    Cummins3500 Never finishes.....
    Logan
    @daveeasa If your Lca bushings are toast, it’s usually considered easier to swap in new arms with them already pressed in than try and get the old ones out.
    daveeasa and des2mtn like this.
  17. Oct 27, 2021 at 1:09 PM
    #77
    16CMTXED
    16CMTXED New Member
    Gary
    Central Texas
    2016 Tundra CM
    Eibach Pro Sport Shocks (1.25in), RAS HD, Sumo Springs, HAWK Talon Rotors, OEM Tow Mirrows, Lund Hard Fold Tonneau, ESP Storage, Stampede Flares, Husky xAct Fit liners, General Grabber ATX 275/60R20
    Can someone share free shipping coupon code for McGeorge Toyota? Thanks!
  18. Oct 27, 2021 at 1:15 PM
    #78
    daveeasa
    David
    Thanks, I'll ask him. Poor guy, having to deal with me and my 1001 questions and the constant stream of new parts I throw in my truck every week :)
    He didn't seem to think replacing the LCA's was a great way to spend money last I asked about it, but I am not sure he's taken a close look at them yet.
    des2mtn[QUOTED] likes this.
  19. Oct 27, 2021 at 1:22 PM
    #79
    alb1k
    Left Coast
    It's good
    wasnt it SHIPFREE?
  20. Oct 27, 2021 at 1:24 PM
    #80
    alb1k
    Left Coast
    It's good
    The others covered it, bushings. Unless you broke one and then you know. The Moogs I ordered were around 100 per.
    des2mtn likes this.
  21. Oct 27, 2021 at 1:40 PM
    #81
    16CMTXED
    16CMTXED New Member
    Gary
    Central Texas
    2016 Tundra CM
    I tried all below without any luck.
    SHIPFREE
    shipfree
    FREESHIP
    freeship
  22. Oct 27, 2021 at 1:44 PM
    #82
    des2mtn
    Shady Grove
    Tonto cover
    16CMTXED[QUOTED] and daveeasa like this.
  23. Oct 27, 2021 at 1:46 PM
    #83
    daveeasa
    David
  24. Oct 27, 2021 at 1:48 PM
    #84
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Toyota bushings are around $80 each I think. Makes more sense to just get arms, but be a little picky about which ones. Mevotech lowers were known to have poor bushings in the past, not sure if that's changed. I went beck arnley and it's luck of the draw. Moog seems more consistent in quality.
  25. Oct 27, 2021 at 1:55 PM
    #85
    daveeasa
    David
    and SPC's or TC are where you spend more than needed if not going LT b/c they don't do anything different than OEM? This is what I've been told so far, but maybe I mis-heard / mis-interpreted?
  26. Oct 27, 2021 at 1:57 PM
    #86
    alb1k
    Left Coast
    It's good
    They help with alignment, and allow for more droop, less bind. And probably give you two less ball joints to worry about. Needed for EXT coilovers.
    Sunnier, des2mtn and Darkness like this.
  27. Nov 2, 2021 at 7:50 PM
    #87
    alb1k
    Left Coast
    It's good
    Related - Along with LBJs, I ordered Moog LCAs. One came, one was out of stock. So I ordered a NAPA, thinking the high price tag would get me the same quality. Nope, Moog looks and is built like OEM - Napa has smaller rivets, less material where the ball joint attaches, and less build quality in general. Avoid NAPA for LCAs. I found another Moog, I'm not going this far to mess around.
  28. Nov 2, 2021 at 7:56 PM
    #88
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    I just finished my LCA and I ordered AcDelco and they almost looked identical and felt like the oem.
    G_unit3000 and alb1k[QUOTED] like this.
  29. Nov 2, 2021 at 8:11 PM
    #89
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    I'm assuming your using oem LBJ correct? I'm going to be the guinea pig trying the ttx LBJ I'll keep everyone posted.
  30. Nov 2, 2021 at 8:17 PM
    #90
    alb1k
    Left Coast
    It's good
    That's correct.
    Dave8699[QUOTED] likes this.
