Lower ball joint bummer
Discussion in 'Suspension' started by FowlhookDE, Jan 25, 2019.
  1. Jan 25, 2019 at 11:26 AM
    FowlhookDE
    FowlhookDE [OP] New Member
    Ryan
    Delaware
    2019 Black DC
    Ready lift 3/2 level 18” race line 981 +25mm 35x12.5 ironmans Rockford Fosgate 6.5” all around 35% tint up front
    So I was driving into work this morning and heard a POW then a clank. Thought maybe it was a rock stuck in my tread or something. Nope! The bolt came out of my lower ball joint. Just had the level kit installed 3 weeks ago. Now the install shop can’t look at it until Monday. I’m a little pissed off right now. At least my local Toyota dealership is able to order the bolt and will have it in tomorrow morning so I can have my truck back
    Tundra_361, Rica25 and dcsleeper408 like this.
  2. Jan 25, 2019 at 11:33 AM
    Yikes! No bueno amigo, hope ya get fixed soon
    dcsleeper408 likes this.
  3. Jan 25, 2019 at 11:34 AM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    hopefully that ball joint is still ok.
    GodlessPro, Rica25 and joonbug like this.
  4. Jan 25, 2019 at 11:38 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Why did they even take that bolt out? Not needed for the installation
    Tundra_361 likes this.
  5. Jan 25, 2019 at 11:41 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    I'd raise some questions and concerns to the shop.
    Did you take it back for their usual retorque?
  6. Jan 25, 2019 at 11:45 AM
    FowlhookDE
    Ryan
    Delaware
    2019 Black DC
    Not yet. I was scheduled for next week. It’s been about 400 miles since the level was put on.
    Rica25 likes this.
  7. Jan 25, 2019 at 11:46 AM
    Woodtickmp
    Woodtickmp Black beast/beauty/pearl
    Mathew
    west bend WI
    2010 tundra double cab black TRD rock warrior
    3in front leveling kit with camburg engineering upper A-arms, 2in block in the rear and 6 pack leafs, 295/65/17
    I just had that happen to me about a month ago luckily i was in my driveway. That sucks.
    FowlhookDE[OP] and Rica25 like this.
  8. Jan 25, 2019 at 11:52 AM
    Damn!!!
    Glad you are ok.
    I wonder what kind of stress the knuckle puts on the upper ball joint when this happens?
    Hummmmm
  9. Jan 25, 2019 at 12:12 PM
    FowlhookDE
    Ryan
    Delaware
    2019 Black DC
    Thanks. Hopefully it’ll just be a replace the $11 bolt fix but I’m sure it has put unnecessary stress on the ball joint. The shop told me it was fine to limp it the 10 miles to their shop. No thanks. It’ll just sit until my bolt comes in tomorrow. Hopefully won’t be too difficult to put back in?? Just jack it up and should realign right?
  10. Jan 25, 2019 at 12:53 PM
    15whtrd
    15whtrd Mr. Blonde
    This kind of stuff drives me nuts. I know human error happens. But, that’s why when I did mine, I used a paint marker on all the nuts and bolts that I torqued. One, it tells me that I’ve finished that nut and 2, all I have to do is look under the truck and make sure all the lines of paint lineup and I know it hasn’t come loose.
  11. Jan 25, 2019 at 12:54 PM
    Hopefully.
  12. Jan 25, 2019 at 1:01 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Wow! Just wow!
    Rica25 likes this.
  13. Jan 25, 2019 at 1:11 PM
    Woodtickmp
    Mathew
    west bend WI
    Ya jack up the front and take the tire off and loosen the other bolt alittle and make sure you have red thread locker.
  14. Jan 25, 2019 at 1:22 PM
    15whtrd
    15whtrd Mr. Blonde
    I didn’t use any thread locker. It hasn’t come out and I’ve beat on it pretty good. Proper torque is the key. My Toyota installation instructions do not mention any thread locker that I noticed. https://www.dropbox.com/s/sxjguie9rkx4dti/PTR13-34140inst.pdf?dl=0
    The lower ball joint bolts need to be torqued to 221 ft•lbf
    Trooper2 likes this.
  15. Jan 25, 2019 at 1:59 PM
    Woodtickmp
    Mathew
    west bend WI
    It's always better to be safe then sorry.
    equin and waynescaggs like this.
  16. Jan 26, 2019 at 6:29 AM
    waynescaggs
    waynescaggs No more of that .
    Wayne
    Idaho
    2019 tundra Crewmax Limited
    Agree
  17. Jan 26, 2019 at 2:22 PM
    FowlhookDE
    Ryan
    Delaware
    2019 Black DC
    Installed my $11.99 bolt today and got her back the road. We’ll see what the shop has to say on monday when I bring it in....
    equin and buckeyes1975 like this.
  18. Jan 28, 2019 at 10:43 AM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    I’m a bit confused about what happened. When I did mine, I removed two bolts to separate the lower ball joint assembly from the knuckle. I didn’t remove the lower ball joint itself. Upon install, I applied threadlocker on those two bolts, and then torqued them up.
    300BLK likes this.
  19. Jan 28, 2019 at 11:14 AM
    FowlhookDE
    Ryan
    Delaware
    2019 Black DC
    Hey Ed. It was one of the two bolts that separate the ball joint assembly. Sorry I wasn’t very clear on that. I brought it into the shop today and they re tightened everything down, apologized a few times and gave an alignment.
    equin[QUOTED] and 15whtrd like this.
  20. Jan 28, 2019 at 11:42 AM
    equin
    Ed
    DFW, TX
    Ah, gotcha. That makes sense. Guess I should check mine to make sure they haven’t loosened. Hope the shop fixed yours for good.
    FowlhookDE[OP] likes this.
  21. Feb 8, 2021 at 7:57 AM
    Addisone33
    Addisone33 New Member
    Addison
    2017 Quicksand Tundra
    Does anyone know what the specs for this bolt is?
  22. Feb 8, 2021 at 5:41 PM
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
    There's no way they torqued those to proper spec. They're supposed to be at 221ft/lbs. That's scary, glad you didn't have a failure at high speed. I would advise you go get a torque wrench and torque every single bolt to spec in your suspension and mark them with a paint marker. Failures from a monkey not torquing things properly is a sad way to wreck your truck or get hurt.
    These are the specs:
    Tie rod end: 51 ft lbs
    Top coilover bolts: 33 ft lbs
    Bottom coilover bolt: 144 ft lbs
    Wheel: 97 ft lbs
    Upper control arm ball joint: 81 ft lbs
    Steering knuckle: 81 ft lbs
    Sway bar bolt: 89 ft lbs
    Top stabilizer bolt: 111 ft lbs
    Lower control arm ball joint attachment(2 bolts): 221 ft lbs
    Lower ball joint: 123 ft lbs
    Aluminum wheel: 97 ft lbs
    Steel wheel: 154 ft lbs
    Control sensor wire A: 10 ft lbs on UCA
    Control sensor wire B: 21 ft lbs on spindle
    Sway bar brackets bracket (4 bolts): 51 ft lbs
    UCA through bolt for TC UCA: 173 ft lbs
    Uniball: 100 ft lbs
    Rear spring: 77 ft lbs
    Rear Ubolt: 74 ft lbs
    Rear shock upper: 21 ft lbs
    Rear shock lower: 66 ft lbs
    Sundog and Hbjeff like this.
  23. Feb 8, 2021 at 6:12 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    What shop was this?
  24. Feb 11, 2021 at 7:17 AM
    NoRcptn
    NoRcptn Better than mediocre poster
    NorCal
    2017 Platinum
    GFC, Dobinsons IMS, RW's 285/75/17
    I cannot thank you enough for this. I've been searching and logging torques specs for the last two days till I randomly ran across this.
    300BLK[QUOTED] likes this.
