low tire pressure light
Discussion in 'Wheels & Tires' started by MicahTX, Dec 18, 2016.
  1. Dec 18, 2016 at 2:44 PM
    MicahTX
    MicahTX [OP] New Member
    Michael
    2016 White Tundra TSS
    Bakflip G2 bed cover Tailgate inserts
    My low tire pressure light just came on. I checked all four and added air to the recommended pressure (posted in the door well), but the light is still on. Could it be the spare? Before I pull it out, I want to hear from some members. Thanks.
  2. Dec 18, 2016 at 2:46 PM
    It's probably a faulty TPMS
  3. Dec 18, 2016 at 2:47 PM
    zlaneb
    zlaneb New Member
    Austin, TX
    First - stock tires and if not did the pressure sticker in the door sill get updated? Second, yes, could be your spare, it was mine on my old truck. Finally, read in your manual, once you get them to the pressure you want, follow instructions for resetting the pressure rating.
    The cold will definitely impact tire pressure....
    NewImprovedRon likes this.
  4. Dec 18, 2016 at 2:59 PM
    MicahTX
    Michael
    It a new truck with only 1100 miles so I wouldn't think it's the monitor, but anything's possible. It is cold here right now (38 degrees is cold for Houstonians). I'll drive it tomorrow to see if it goes out by itself. If that doesn't work, I'll check the manual then check the spare. Thanks.
  5. Dec 18, 2016 at 3:03 PM
    Seadawg1
    Seadawg1 New Member
    Larry
    Northwest
    2017 Gray Toyota Tundra, DC, SR5, TRD PRO
    Mine, is doing the same thing. For 2 weeks now, and in fact 2 of the tiese were 4/5 lbs over. And this was before the cold snap. I checked my tires and they are all within specs. I will going to the dealer and let them tell me. Crazy isn't it.
  6. Dec 18, 2016 at 3:12 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I haven't had to mess with it yet, but does the reset button have anything to do with it?
  7. Dec 18, 2016 at 3:27 PM
    MicahTX
    Michael
    There's a reset button? I just thought it went out when the pressure was corrected.
  8. Dec 18, 2016 at 3:29 PM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    Make sure you check the spare as well. Im not sure about the tundra, but some cars take a mile or so of driving before it resets.
  9. Dec 18, 2016 at 3:30 PM
    MicahTX
    Michael
    OK. I'll check it out. Thanks.
  10. Dec 18, 2016 at 3:49 PM
    MicahTX
    Michael
    All good ideas. Thanks.
  11. Dec 18, 2016 at 4:00 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Did you fill up recently? Could be gas cap too I believe.
  12. Dec 18, 2016 at 4:57 PM
    How does a low pressure light tie into the gas cap :notsure:
    Law323, Motor71 and joonbug like this.
  13. Dec 18, 2016 at 5:05 PM
    ej63090
    ej63090 New Member
    Eric
    McHenry, Illinois
    2017 White Crewmax SR5
    9/10 it's the spare if your other pressures are within the TPMS tolerances.
  14. Dec 18, 2016 at 5:26 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Hmmm. I just got my TPMS turned on on my new wheels and the guy at Americas Tire said my spare doesn't have TPMS.
  15. Dec 18, 2016 at 5:28 PM
    ej63090
    ej63090 New Member
    Eric
    McHenry, Illinois
    I haven't worked for Toyota for three years so it may be different. But I'm pretty sure a full size spare especially a 5th wheel would typically have a sensor.
  16. Dec 18, 2016 at 5:32 PM
    George14
    George14 New Member
    West Virginia
    2014 Tundra SR5 Dc TRD Off Road 5.7L with tow package
    None
    My tire was low put air in it light went out
  17. Dec 18, 2016 at 5:35 PM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    Try resetting it. I deflated my tires 3 days ago and reset them after I refilled my tires. Turn the key to ACC, press and hold the button located on the bottom right side of your steering column, the light will blink 3 times. Release the button and let sit for 5-6 mins with the key still on ACC. Should reset.
  18. Dec 18, 2016 at 5:47 PM
    MicahTX
    Michael
    This is getting interesting... I did refill my gas tank, today. Hard to see how the two are tied together, but the cap is easy to check. The manual did say to fill the tires to the correct pressure and the light will go out after a few minutes. Will check that, tomorrow. FYI - I did find the reset button. Pushed it a couple of times, but nothing happened. Still will check the spare if nothing else works.
  19. Dec 18, 2016 at 5:51 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Gas cap will trigger the CEL. TPMS has its own light.
    csuviper and Motor71 like this.
  20. Dec 18, 2016 at 8:10 PM
    TXMiamiFan
    Jose
    In the past, if you didn't close gas cap correctly, it would trigger low pressure warning. So one had to open and close it again. Not sure if that still works that way. So I threw it out there just in case it was a possibility.
  21. Dec 18, 2016 at 8:15 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    It's the spare!!!!!!!!!!!!!!!!!!
    MotoTundra likes this.
  22. Dec 18, 2016 at 8:15 PM
    csuviper
    Broomfield, CO
    Correct, not the gas cap.
  23. Dec 18, 2016 at 8:17 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    X2!
  24. Dec 19, 2016 at 5:47 AM
    Sixpack
    Sixpack New Member
    Central Florida
    2014 Silver Sky Tundra CM TRD 4x4 Limited
    Moto Metal 951 18x9 rims with 285x75x18 Nitto Terra Grapplers , ESP lockable under seat storage, Husky mats front and rear, ReadyLift 3/1, Undercover Flex trifold bed cover, Bed Rug, interior LED's, 15% tint all around, TRD CAI, Bully Dog Platinum GT tuner, TRD rear sway bar, Flowmaster Series 44 dual exhaust system, LED head lights and Fog lights, 32" LED light bar in lower bumper cover, Switchback running lights, much more to come...
    X3, it's the spare, and then hit the reset button...
  25. Dec 19, 2016 at 10:23 AM
    bsavoir
    bsavoir New Member
    Killeen, TX
    2016 Tundra Limited CM 4x4
    Gibson Metal Mulisha Exhaust, Replaced bulbs w/ LED's, AFe intake, Bullydog Tuner, Aftermarket Audio system, Rhino Bed Light sports bar, Tonneau Cover, Spyder Auto Headlights and Taillights, Recon 3rd Brake Light, Kensun HID's, Fender Flares, Custom Leather Interior, Heated Seats, 5% Tint on the Rear Windows, Pod light Foglights, 31" light bar behind the grille, linex spray bedliner, linex sprayed grille, ditch lights w/ dual 3in LED pods, 60" Tailgate LED strip.
    The spare has a TPMS, when a new tire is introduced it needs to relearn for that sensor in which the reset set button can do so. What type of rims do you have? Alloy rims and steel rims have different TPMS. The computer can only read one type at a time. I When I bought my new alloys rims I couldn't figure it out until I did some research and took it to a tire shop near by and he confirmed my suspicions. Based on you picture it looks like alloy not steel, and I would assume the spare would be steel as mine was.
  26. Dec 19, 2016 at 10:40 AM
    Junior4888
    Junior4888 2007 Toyota Tundra Limited 4.7l
    Travis
    Moxee, WA
    2007 Toyota Tundra Limited Dbl Cab 4.7l
    My air pressure light comes on every day about 1 mile from my house and blinks for about 2 min and then goes back out. I am thinking it is due to the cold weather 15 degrees in the morning. That's the only time it comes on though. It does it every morning for the last month.
  27. Dec 19, 2016 at 10:59 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Had to do this once during a cold snap with my stock tires. Re inflated my tires went out after a couple miles. Haven't had to do it since.
  28. Dec 19, 2016 at 11:16 AM
    trainracer
    trainracer New Member
  29. Dec 19, 2016 at 1:36 PM
    bsavoir
    bsavoir New Member
    Killeen, TX
    Same here, I live in Twentynine palms, CA and the temp in the morning is cold, but after a couple hours it warms up and the light goes away, but be mindful inflating in the morning because it cold could cause the tire to over inflate in the afternoon depend on how much it drops and you fill it up to. Once winter sets in usually I will fill it in the morning and it will be good as the temp doesn't really affect the tires.
  30. Dec 20, 2016 at 7:19 AM
    MicahTX
    Michael
    Breaking news!! The light has gone out! After re-inflating all tires to the correct pressure, I drove my truck a few miles and it went out. (Just like the owner's manual said.) Glad I didn't have to pull the spare out to check it. Would be nice to have the same feature my wife has on her Lexus - display shows all four tires and pressure for each. Maybe that feature is available for some models, but not my TSS SR5. Takes the guess work out it. Thanks, again everyone, for your help.
