Low tire pressure light blinking
Discussion in 'Wheels & Tires' started by Racingjohndeere55, Nov 14, 2019.
  1. Nov 14, 2019 at 12:51 PM
    Racingjohndeere55
    Racingjohndeere55 [OP] New Member
    Last night the low tire pressure light started blinking in the dash. So just putting new tires on I figured one may be low. After checking all the pressures with a gauge they are good. Bad sensor all of a sudden? Or is one just hanging out with the wrong crowd?
    MELA 2016 likes this.
  2. Nov 14, 2019 at 1:26 PM
    chugs
    chugs New Member
    Ciao
    Central Cali
    2007 Tundra Blue Streaker
    Have you tried resetting the tpms?
  3. Nov 14, 2019 at 1:26 PM
    easleycrawler
    Travis
    Easley, South Carolina
    17 Tundra SR5 DC Black 5.7
    Probably just needs resetting. There should be a little button at the bottom of your dash, below the steering wheel, push it and see if that works for you. If not, take it back to where you got the tires and tell them to reprogram it or take it to your local dealership and they can do it.
    Kerch71, P-Factor and BravoDeltaRomeo like this.
  4. Nov 14, 2019 at 1:31 PM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I shit canned my sensors, the blinking stops after a minute or so.
    Mr Badwrench likes this.
  5. Nov 14, 2019 at 1:35 PM
    Jrharvey02
    Jrharvey02 New Member
    2010 Tundra CM 5.7 Platinum Dark Black
    Check the spare...
    FREEK, flyfisher and Ajkkane like this.
  6. Nov 14, 2019 at 1:36 PM
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    Did they rebuild the tpms sensor. Depending on your type of wheel, they may have reinstalled it backwards and caused it not to read properly. I had at least 5 trips to Discount Tire for them to figure it out. Especially if you have steel wheels.
  7. Nov 14, 2019 at 3:37 PM
    Racingjohndeere55
    Tried the reset button.... won't stop blinking . Just new tires not rim's. I will check the spare. Didn't know that one has a sensor, but that makes sense.
  8. Nov 14, 2019 at 3:54 PM
    Ajkkane
    Ajkkane Old fart.
    Nj
    2014 CM SR5
    You may or may not have a spare tire sensor. But when you drop the tire, clean and use a good spray oil on the tire lifting cable and hardware. Salt, water, dirt etc will cause it to rust and jam. If it wasn’t for bad luck we wouldn’t have any luck. It’ll just save you a ton of aggravation changing a flat tire in the pouring down rain or in the snow trying to unjam your spare tire mechanism. At the Toyota dealership I work at we had quite a few people that weren’t able to change their tire because the mechanism was rusted and wouldn’t work..
  9. Nov 14, 2019 at 4:26 PM
    easleycrawler
    Travis
    Since you just got new tires, I'm going to bet it's not your spare tire. The tpms needs recalibrated. My local wheel and tire shop has a hand held programmer that plugs into the ob2 port, and it recalibrates the system.
    Garvin74, Kerch71 and flyfisher like this.
  10. Nov 14, 2019 at 4:37 PM
    greghoro
    greghoro New Member
    Greg
    2012 Sequoia Limited
    To reset, with the ignition on, make sure you push and hold the button until the TPMS light blinks three times.
    Greg
  11. Nov 14, 2019 at 4:46 PM
    MELA 2016
    MELA 2016 New Member
    2016 Tunda xspX
    Factory with additional lift
    Just got new rubber, installer only put PSI that was on the door which doesn't corresponed with the factory tires. Add air to at least 3/4 of the psi on your tires
  12. Nov 14, 2019 at 4:50 PM
    MELA 2016
    2016 Tunda xspX
    If you have bigger tires than listed on your door put more air in according to the tires max PSI. My SR5 seems to know the difference between the factory tires and the factory upgrades
  13. Nov 14, 2019 at 5:03 PM
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
    I agree. Doesn't the blinking mean it needs to be recalibrated? If it was a pressure issue, it would be a solid light, not blinking.
    easleycrawler[QUOTED] likes this.
  14. Nov 14, 2019 at 5:42 PM
    Doesn't Techstream test the TPMS ? I never looked that close.
  15. Nov 14, 2019 at 6:15 PM
    Dr_Al
    Dr_Al New Member
    Al
    TechStream software will tell you everything you need to know. It'll tell you the lowest allowable pressure, the current pressure, and it'll tell you the temp of the sensor. When I had one go bad the light would flash and then go solid each time you started up the truck. I would try adding an extra 5 psi to the tires and see if it goes away. The push button is just for resetting the lowest allowable pressure. I wouldn't change it unless the new tires you put on require less pressure.
  16. Nov 15, 2019 at 4:07 AM
    Racingjohndeere55
    I'm going to lean towards the spare. Put e rated tires on so higher presser than the spare. I'll bump up the psi in that and see if it gets the light to go out.
  17. Nov 15, 2019 at 9:02 AM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    A blinking light either means one or more of your sensors is dead or the pressure is way past the allowable range.
    The TPMS button on the dash is only to be used to reset the baseline PSI pressure.
    What pressure did you set these new tires to?
  18. Nov 15, 2019 at 10:23 AM
    Racingjohndeere55
    50 psi. Then looking at them I dropped the rears to 45 and the fronts to 48
  19. Nov 15, 2019 at 11:22 AM
    Scuba
    Scuba Sober member
    Austin, Tx.
    Okay so one of the sensors could have failed or the tire pressure is too high according to the truck.
    To reset the baseline pressure the need to all be set to the same cold tire pressure. Say 45 all around.
    Then while the truck is running hold the tire pressure button for a few seconds until it blinks. After that the truck must remain on for I believe 15 mins. I recommend just driving it instead of letting it sit there and idle.
    If that doesn’t work then I would bank on a dead sensor.
    Racingjohndeere55[OP] likes this.
  20. Sep 22, 2020 at 12:02 PM
    buda_d24
    buda_d24 New Member
    Ron
    17 tundra sr5
    Is there a fix if tpms light comes on after disconnecting and reconnecting tpms reset button? I installed 2019 trd pro headlights and had disconnected reset button and removed bottom dash to connect wire under dash. Now tpms light stays on. Tried disconnecting battery and reconnecting. Also tried resetting tpms and no luck
