Love Plasti-Dip !!
Discussion in '2.5 Gen Tundras (2014-2021)' started by bretn77, Apr 8, 2019.
  1. Apr 15, 2019 at 5:26 PM
    bretn77
    bretn77 [OP] New Member
    Ryan
    2022 Tundra TRD Pro in Solar Octane
    Thank you!
    I love the black, to the point where I don’t even understand why Toyota still makes the Tundra with chrome!
  2. Apr 16, 2019 at 8:44 AM
    TundraLaw
    TundraLaw New Member
    Northern Nevada
    Definitely. I have on order a black limited, and I just don't get why the limited's have so much chrome. Toyota is definitely stuck in 2005 on that one.
    Did you notice any scratching of the plasti-dip?
    Durania likes this.
  3. Apr 16, 2019 at 8:57 AM
    bretn77
    Ryan
    I totally agree about Toyota being stuck in the past!
    It doesn’t really. But it certainly is not an absolute perfect solution.
    High wear areas (bumpers and grill) get little flecks occasionally, but I usually just touch them up.
    Overall it holds up very well if applied properly!
  4. Apr 18, 2019 at 6:52 PM
    bretn77
    Ryan
    So most recently I did the wheels.
    I did 7 coats on each wheel and used about 2 + cans.
    As they start to get to the bottom of the can, I only will use that part for initial coats, because it can throw extra air and some larger blotches of Dip.
    VTYOTA[QUOTED] likes this.
  5. May 15, 2019 at 12:51 PM
    Newfietoyota
    Newfietoyota New Member
    How are the rims holding up with the plasti dip?
  6. May 15, 2019 at 1:58 PM
    TokerJoker
    TokerJoker ΜΟΛΩΝ ΛΑΒΕ
    Travis
    Nowhere, Specific
    2014 Black SR5 4.6 Dbl Cab
    None.....yet
    Looks good OP :thumbsup:
  7. May 15, 2019 at 2:02 PM
    bretn77
    Ryan
    No problems at all!
    Proper prep and coats!
    Newfietoyota[QUOTED] likes this.
  8. May 15, 2019 at 5:05 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I'm doing my wheels soon with brass monkey plasti dip. It's a dark bronze. I got a "wheel kit" from dip your car for $60. Comes with 4 cans of color, 3 cans of glossifier, masking supplies, a spray nozzle, "dip prep" aka wheel cleaner, and "dip release" aka tire shine. The price was too good to pass up, that color was on sale and dyc.com had a 20% sale. I hear warming the cans in hot water helps. I also read the glossifier is a good idea on wheels as far as making them easier to clean down the road. I like you tip about the bottom of the cans. Any other tips? Thanks
  9. May 15, 2019 at 6:51 PM
    Mudroadfun
    Mudroadfun New Member
    James
    Detroit Michigan
    2016 Tundra 1794 Black
    Plastic Dip is great to use but I have problems getting it off.
  10. May 15, 2019 at 8:17 PM
    bretn77
    Ryan
    Sounds like a great deal!
    My other suggestion that I mentioned is to be very meticulous with your coats.
    First coat is quite literally just a dusting. You should see at least 50%+ of the original surface.
    I wait 20 mins in between when indoors, or perfect weather outdoors.
    Second coat another dusting, but slightly heavier.
    By the third coat almost all of the original surface can be covered.
    Then get progressively heavier with your coats.
    Do at least 7. All very even coats.
    The last pretty heavy, but not super wet.
    Then you’re ready to roll!
    Yes, I only use bottom of cans for beginning coats.
    When doing wheels use Post-It notes all around the rubber part of the tire under the edge of the rim so you don’t get it all over your tire.
    I believe I learned this from Fonzie on the DYC site.
    Use $.50 pieces to cover your lug holes if you take your wheels off, which I do and place them on a work bench.
    Other than that, have fun!
    Are you doing your badges too?!?
    Those are my favorite to do!
    This is my second Tundra that I have dipped all the shiny stuff, and have been very successful with all of it!
    Please let me know if you have any other questions!
    Pudge[QUOTED] likes this.
  11. May 15, 2019 at 8:19 PM
    bretn77
    Ryan
    If you have problems getting it off, you did not apply your coats properly.
    Check out what I said to ‘Pudge’ further down.
    If your coats are thorough and you have done enough, it should come off in a sheet.
    Pull up all the edges, and then it will all come off smoothly in one big sheet.
    Maybe time to try again!
  12. May 15, 2019 at 8:22 PM
    bretn77
    Ryan
    Yes, regular matte black!
    SteyrM40A1[QUOTED] likes this.
  13. May 15, 2019 at 8:24 PM
    cmiller219
    cmiller219 New Member
    Nashville, TN
    2018 Cement CM Tundra
    You love it now just wait hahah. That shit is the devil
  14. May 15, 2019 at 8:25 PM
    bretn77
    Ryan
    They hold up great if applied properly!
    I had a 2010 that I did, and they lasted 4-5 years with minimal touch ups.
    The only real touch ups were when I got new tires.
  15. May 15, 2019 at 8:26 PM
    bretn77
    Ryan
    I have not had any problems with it.
    I do plan to leave it on though.
    If applied properly, it comes off very easily!
  16. May 15, 2019 at 8:27 PM
    cmiller219
    Nashville, TN
    ^^^it holds up well yeah i just hate the stuff. Its rough and can’t be cleaned or scrubbed hard. It’s just a cheap product that i don’t prefer
  17. May 15, 2019 at 8:28 PM
    bretn77
    Ryan
    To each him own, for sure!
    When I clean my truck to take the time to use a soft bristle brush which works great!
    We have the same truck, that’s cool!
  18. May 15, 2019 at 8:32 PM
    cmiller219
    Nashville, TN
    Yeah i did some wheels years ago and a few other things and I just wasn’t happy. I know tons of people who love it and use it for so many projects
    bretn77[OP] likes this.
  19. May 15, 2019 at 8:36 PM
    #49
    bretn77
    Ryan
    I use it on my snowmobile and other things too!
    No snowmobiles where you are though! :)
    cmiller219[QUOTED] likes this.
  20. May 15, 2019 at 8:51 PM
    #50
    Pudge
    CT
    Thanks for the tips. I plan to do them on the truck and was planning on using index cars for the tires.
    I do want to do my badge. I only have the platinum badges left on my truck, I removed the others. I wish I had got and extra can of dip when I ordered. I may go get a can or two of black to use as a base on the badges then finish off with a few coats of the brass monkey color, then clear.
    bretn77[QUOTED][OP] likes this.
  21. May 15, 2019 at 9:26 PM
    #51
    bretn77
    Ryan
    I have not done them on the truck, but I believe that it is recommended that you cover the brakes/discs...
  22. May 19, 2019 at 5:05 PM
    #52
    Pudge
    CT
    Brass monkey plasti dip with glossifier. I cleaned everything 3 times. First coat was just a dusting and worked my way up to thicker coats. Used 4 cans of color and 3 cans of glossifier. Not sure exactly how many coats are on there but my guess is 10 or 12 total on the wheels and 5 on the badges. It really came out nice. The glossifier leaves the surface a little tacky. I have read this is common. I hope it hardens up as it cures. I did read that you can add a spray wax and it'll cut down on that tacky feeling. I hope it holds up well. I spent several hours doing this but I think it looks great for the money and time spent.
    mojojo, Boerseun, SteyrM40A1 and 4 others like this.
  23. May 19, 2019 at 5:48 PM
    #53
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    Damn @Pudge that color is great!
    nlaroy and Pudge like this.
  24. May 19, 2019 at 6:16 PM
    #54
    bretn77
    Ryan
    Looking great man!!!!
    Kind of a fun project, right!?!
    I used the glossifier a few times and simply found that the matte was the look that I preferred.
    Let me know how it holds up and wears for you!
  25. May 19, 2019 at 7:03 PM
    #55
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    Anyone plasti-dip their exhaust tip? I know the exhaust tip doesn’t get as hot but wondering if plasti-dip can handle it.
    Pudge likes this.
  26. May 19, 2019 at 7:05 PM
    #56
    Pudge
    CT
    I did on my Tacoma and it held up fine. I will me doing my tundra tip once I come across a can of black dip
    bretn77[OP] and Y0TA PR0[QUOTED] like this.
  27. May 19, 2019 at 7:06 PM
    #57
    Y0TA PR0
    Rafael
    2017 TRD PRO
    Does look painted! Good job! :thumbsup: Looks good.
  28. May 19, 2019 at 7:08 PM
    #58
    Y0TA PR0
    Rafael
    2017 TRD PRO
    Really?! Awesome, good to hear. Maybe that will be my project for tomorrow!
  29. May 19, 2019 at 7:30 PM
    #59
    Pudge
    CT
    It was fine on my Tacoma. It may have hardened and been brittle, I'm not sure but it looked fine and wasnt peeling or chipping. Looked like flat black paint
  30. May 19, 2019 at 7:33 PM
    #60
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    They look good guys!
