Love deliveries...Morimoto XB Headlights (now w/night shots)
Discussion in '2.5 Gen Tundras (2014-2021)' started by buckrub71, Aug 8, 2019.
  1. Aug 8, 2019 at 10:14 AM
    buckrub71
    buckrub71 [OP] Like Father, Like Son--Semper Fi
    2016 Bronze 1794 CM
    Just finished installing my smoked Recons and took them out for a spin. The plan was to then install my Putco Blade but these bad boys were waiting for me! 20190808_125132.jpg
  2. Aug 8, 2019 at 10:40 AM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
  3. Aug 8, 2019 at 10:42 AM
    cctxquicksand
    cctxquicksand IG - TRDistheWrd
    :thumbsup: Very nice!!
    Definitely watching this thread. Please post up pictures of your output I’m on the fence on these headlights.
  4. Aug 8, 2019 at 10:45 AM
    YotaMan
    YotaMan Silver Bullet
    Colorado Springs
    2021 Platinum
    Lemme know if you have any faults like me.
    p.s. your gonna love them
  5. Aug 8, 2019 at 10:57 AM
    DividedSky
    DividedSky New Member
    Jeff
    '18 Crewmax - ADS Mid Travel
    ADS 2.5's (rear bypass) U748 Leaf Springs
    Love Deliveries?
    I thought this was gonna be a thread about Adam&Eve or Fredricks... I feel cheated!!
    :spy:
  6. Aug 8, 2019 at 10:58 AM
    TRDProLife
    TRDProLife LETS GO BLUES
    St.Louis
    Barcelona Red Metallic TRD Pro Tundra
    Window Tint, ICI Magnum Steps, firestone spring helpers for towing, 295/70R18 Atturo Trsil blade X/T's
    They look good.
  7. Aug 8, 2019 at 12:57 PM
    buckrub71
    2016 Bronze 1794 CM
    Ugh! Look great, really great but will not allow sequential signal. The online direction for OEM DRL shows different wiring than I have. Regular signals work and look great but I want sequential! More to come...
  8. Aug 8, 2019 at 1:16 PM
    YotaMan
    Colorado Springs
    2021 Platinum
    Post a pic of the wiring
    From what I see if you just swap 2 plugs around and that enables sequential. Mine come that way
  9. Aug 8, 2019 at 1:44 PM
    buckrub71
    2016 Bronze 1794 CM
    Will do but this was a "discreet" delivery and wifey is home. So it'll have to be tomorrow. I have a 2016 1794. As per the online directions, since I have OEM DRLs, I'm supposed to use the included harnesses. The problem is, I do not have the "multi pin connector" on the vehicle they refer to. Perhaps that's only on later models??? Thoughts? I plan on heading out tonight to check the light output.
    panicman likes this.
  10. Aug 9, 2019 at 7:14 AM
    buckrub71
    2016 Bronze 1794 CM
    Update: the lights are wicked bright! But, I need to adjust them s bit later tonight. I sent an email to support last night and got a response pretty quickly. To get the sequential I needed to disconnect two wires. Here comes the next issue. With them disconnected I get hyper partial sequential flash. It seems that because I also have the Recon led tails which I just installed, they are conflicting with one another. Waiting on a possible solution response...
  11. Aug 9, 2019 at 5:02 PM
    buckrub71
    2016 Bronze 1794 CM
    I confirmed that the Recon taillights are the culprit causing the sequential signals hyper flash. I installed the stock incandescent and viola the sequential work perfectly. It's a thing of beauty. Support at Xenon said that there is not enough resistance having leds in both the headlight and taillight signals. It was suggested I add a 7.5 ohm resistor to the signal wires in the Recon. However, I am not sure how to go about that. I will reach out o Recon to collect their input. Any thoughts from members savvy in this area???
  12. Aug 9, 2019 at 5:06 PM
    TXTundra2722
    2015 Black Tundra
    I can't talk you through this, but this is a super simple mod and there are several threads out there involving the led resistors
    TheBeast likes this.
  13. Aug 9, 2019 at 5:09 PM
    buckrub71
    2016 Bronze 1794 CM
    Thanks. I've already been searching. However, the thing that troubles me is that the Recons already have built in resistors. This is where my confusion begins. I worry about causing an issue. Rolling up my sleeves...
  14. Aug 9, 2019 at 5:20 PM
    toyoboyo
    toyoboyo New Member
    Sub'd for updates and pics!
  15. Aug 9, 2019 at 5:27 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    I'm here for headlight porn and there isn't enough of it!
    :worthless:
    Haha. Hope you get the tails figured out
    831Tun and SouthBoundSteve like this.
  16. Aug 9, 2019 at 6:39 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Waiting 4 output pics, been waiting for mmoonntthhss. This is wosre than a 5 yr olds x-mas anticipation.:D
    joonbug, TheBeast, Pudge and 2 others like this.
  17. Aug 9, 2019 at 6:51 PM
    _khaki_
    _khaki_ New Member
    2025 Black Sr5
    MotoTundra and 831Tun[QUOTED] like this.
  18. Aug 9, 2019 at 7:02 PM
    NCTundra1980
    NCTundra1980 New Member
    Stephen
    2019 SR5
    Have you heard back what the problem was?
  19. Aug 9, 2019 at 7:31 PM
    buckrub71
    2016 Bronze 1794 CM
    Just finished adjusting them and took them out for a spin. Sorry for the night shot glare here. Believe me they do not throw off any of the glare you see in the pic! They are clean, tough looking and should be what the truck came with off the assembly line. Below I've included some close shots on the garage door with lows and highs and a couple different night road shots with lows and highs (all with fogs off). All in all, these are AMAZING compared to my OEM with LED bulbs. There is NO comparison! The DRLs are extremely bright and the switchback signals match the output. Though I am bummed about not having a remedy (yet) for the sequential, the only negative, which is not a result of the product, is that I will need to adjust to having such a clean cutoff with the low beams. It's a different driving experience.front shot with fogs.jpg
    This is after adjustments at about 20 ft W/O fogs
    With fogs
    Low beams #1
    High beams #1 (notice the cutoff still to the sides)
    Low beams #2
    High beams #2
  20. Aug 9, 2019 at 7:37 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Damn those looks bright
    ryanwgregg likes this.
  21. Aug 9, 2019 at 7:41 PM
    NCTundra1980
    Stephen
    2019 SR5
    They look absolutely amazing
  22. Aug 9, 2019 at 7:43 PM
    toyoboyo
    toyoboyo New Member
    Oh wow!
  23. Aug 9, 2019 at 7:51 PM
    buckrub71
    2016 Bronze 1794 CM
    SouthBoundSteve likes this.
  24. Aug 9, 2019 at 7:55 PM
    buckrub71
    2016 Bronze 1794 CM
    After hitting my back roads I headed into town a drove around in traffic and didn"t receive one flash from oncoming traffic. Cant say that about my previous setup!
    ryanwgregg, MotoTundra and 831Tun like this.
  25. Aug 9, 2019 at 7:56 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I ran into a problem with some headlights I bought. They were great forward but scary AF when cornering. There was no output to the sides. Yours looks great forward, how is it cornering?
    joonbug likes this.
  26. Aug 9, 2019 at 8:00 PM
    buckrub71
    2016 Bronze 1794 CM
    That's going to be a little bit of the adjustment I was referring to. It is darker to the sides but with the fogs I already had (Morimotos as well), they throw light into the ditches quite a bit. Still different and will take some getting used to.
    831Tun likes this.
  27. Aug 9, 2019 at 8:05 PM
    AZTundra
    Paul
    Phoenix, AZ
    @buckrub71 - Light output looks amazing on those! Do you feel they are worth the hefty price tag based upon your driving impressions?
  28. Aug 9, 2019 at 8:07 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Thanks. I run Baja fogs (wide cornering) and when I shut them off with the other headlights I seriously thought I was gonna crash on the mountain road I live on.
    joonbug, TheBeast and MotoTundra like this.
  29. Aug 9, 2019 at 8:14 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    After I did my retrofit I had to get used to the cut off. It's weird at first.
    Some Baja Designs Squadron Sport's with a wide cornering lens would balance that out nice! That's what I ended up doing, they make a huge difference (when I can use them).
    This is a screenshot from another thread I made that shows my HID retrofit low beams without then with the @Baja Designs Squadron Sport's with Wide Cornering lens. They really balance things out. I was stopped when I took the picture, which is evident by the weeds along the road, so you can see how much you can miss with low beams.
    I don't use mine with oncoming traffic, but their SAE approved fogs may do the trick too, I just don't have any experience with them.
    Link to the original thread for DIY in case you are interested.
    https://www.tundras.com/threads/diy-baja-designs-squadron-r-sport-14-mount-kit-bezel.15967/
    SouthBoundSteve and 831Tun like this.
  30. Aug 9, 2019 at 8:18 PM
    buckrub71
    2016 Bronze 1794 CM
    Based on only my personal experience...hell yeah! They are absolutely amazing in light output in both low and high. So, as for function, they are spot on. Additionally, the switchback drl to amber turn signal is easily seen. I walked away from my truck for quite a ways and looked back to see if I could see the signal over the lights at night...yup! More function. Besides, did I mention just how bad ass these look on my mica bronze baby...man!
    If I'm being fair, I have not had any personal experience with the new leds on the latest models. From what I understand, the light output is good but can only go on other posts. But, they offer no switch back and seem to still "hide" the front signal when looking at them at night. I do think some folks have added amber led bulbs though. I have been waiting on these vs buying the newest oem lights.
    I think the true test of being worth it will be longevity.
    AZTundra[QUOTED] likes this.
