Loud pop after new tires
Discussion in 'Wheels & Tires' started by BRP479, Mar 8, 2020.
  1. Mar 8, 2020 at 5:00 PM
    BRP479
    BRP479 [OP] New Member
    Ricky
    Rogers,AR
    2025F1CE-A010-49BB-88F9-206E2BD5DA26.jpg B26E6ADE-885D-4D3C-B68D-CD2D435D62D0.jpg I just got new 275/60/20BFG KO2 ATs put on. After leaving and driving a mile, there was a loud startling pop from drivers side front. Going about 45mph. Getting on the highway, got up to 65mph and loud pop from passenger side. Made it home and no other sounds. Is this normal?! Or what caused this?
    All lug nuts are still on haha.
    I had 285/55/20 BFG KO2 ATs. Wish I would have gone slightly larger than the 275/60
  2. Mar 8, 2020 at 5:07 PM
    CLowery
    CLowery New Member
    Bates City, MO
    2018 Cement Tundra TRD
    None (yet)
    Sounds like the beads of the tire weren't completely seated. The tire installer should have never let it leave that way. You should be fine now but I would crawl under the truck and look at the inside and outside of the rears.
    15whtrd likes this.
  3. Mar 8, 2020 at 5:08 PM
    BRP479
    Ricky
    Rogers,AR
    What should I be looking for? I was the last install of the day too, so not sure if mine was rushed.
  4. Mar 8, 2020 at 5:32 PM
    Bravohook
    Bravohook New Member
    Addame
    NY
    2007 RCSB
    Cool Things
    Anywhere where the tire isn't contacting the outer edge of the rim
  5. Mar 8, 2020 at 5:34 PM
    OV-1794
    OV-1794 New Member
    Possibly a balancing weight coming off but I figure that would've been more of a clunking sound than a popping.
    Bassmonkey67 likes this.
  6. Mar 8, 2020 at 6:32 PM
    Dirt Dawg
    Dirt Dawg "It'd be a lot cooler if you did"
    Connor
    Denver, CO
    2014 Toyota Tundra Limited CrewMax 4x4
    Every tire weight I’ve had pop off has sounded almost like a gunshot.
  7. Mar 8, 2020 at 6:32 PM
    BRP479
    Ricky
    Rogers,AR
    It was loud so it could have been a clunk/pop. It came from both sides at different times which was odd.
  8. Mar 8, 2020 at 6:34 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I would guess weights coming off. Or a rock stuck in the tread? Bfgs can really hold onto gravel
  9. Mar 8, 2020 at 6:35 PM
    BRP479
    Ricky
    Rogers,AR
    The truck didn’t feel as stable around corners and a little “loose” if that makes sense. I’ll have them take a look. It sounded like a gun shot
  10. Mar 30, 2020 at 2:01 PM
    fiveduece
    fiveduece I like to party.
    Brandon
    2020 TRD sport MGM crewmax
    tint, N-Fabs, trifold cover, bilstein 5100 w/spacers, +2 shackles, MT deegan wheels
    whats your offset for those wheels. I just bought some +18 offsets, have your size Nittos in my cart right now. looking for pictures of fitment and/or belly rub before purchasing these! thanks
  11. Mar 30, 2020 at 10:22 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Did you have any steering vibrations before or after the pop?
    BFG states they have a "very tight bead seat" and that a lot of "warranty" issues from vibrations are that the installer doesn't use enough lube and the bead doesn't seat properly. Wonder if this is what happened.
    15whtrd likes this.
  12. Mar 31, 2020 at 5:28 PM
    BRP479
    Ricky
    Rogers,AR
    I have +55 offset and thinking about some spacers. No rub with 275 60 or 285 55
  13. Mar 31, 2020 at 5:29 PM
    BRP479
    Ricky
    Rogers,AR
    No issues before. I took it back in and they rebalanced it. Said all the wheel weights were still on. Still confused on what happened. Maybe it was the tire setting properly?
