Loss of power
Discussion in '1st Gen Tundras (2000-2006)' started by Jtoy813, Feb 25, 2024.
  1. Feb 25, 2024 at 1:46 PM
    Jtoy813
    Jtoy813 [OP] New Member
    02 Toyota tundra
    When I hit. The gas it doesn’t accelerate. Nor increases in rpm also it back fires. 02’ tundra when I first start it for first time of the morning or day it starts reves with increased and decreases in power then dies multiple times before it actually starts. Please help
  2. Feb 25, 2024 at 3:09 PM
    Sounds like timing problem based on that description. And that's scary, because failure to chang the timing belt is the one thing that will kill these engines.
    But we need way more details, dude.
    Is it the V6 or V8?
    Any recent maintenance?
    When was the last time the timing belt was done?
    Is the timing set correctly?
    Is check engine light on? If yes:
    • Is the light solid or flashing?
    • What codes are set?
    Last, any symptoms before this started, like overheating, slow starts, anything?
    Bob likes this.
  3. Feb 25, 2024 at 4:47 PM
    Jtoy813
    02 Toyota tundra
    It’s a v8 yes check engine light not flashing except just an hour ago for just a few sec. As for the codes the ignition coils code p0174 and p0171 system to lean bank 1&2 whatever that is. Mass or volume air flow circuit and intake air temperature sensor 1 circuit. So just put in new fuel pump new pcv valve new mass air flow sensor just did a break change in front.
  4. Feb 25, 2024 at 4:48 PM
    Jtoy813
    02 Toyota tundra
    Currently drivable but no acceleration
  5. Feb 25, 2024 at 4:50 PM
    Jtoy813
    02 Toyota tundra
    As far as the timing belt I have no idea when it was done last the engine is not the original won’t excellorrate over 1 rpm
  6. Feb 25, 2024 at 5:07 PM
    Change the fuel filter
    (EDIT: I'm kidding, btw)
  7. Feb 25, 2024 at 5:13 PM
    Jtoy813
    02 Toyota tundra
    We have it was the last thing we have done to it
  8. Feb 25, 2024 at 5:16 PM
    I mean the mix of codes you have makes it sound like a bad ground or a harness problem. Have you tried running a temporary ground from the battery to the engine block? Did you check all the grounds? Do you have corrosion inside the battery cables?
  9. Feb 25, 2024 at 5:27 PM
    Jtoy813
    02 Toyota tundra
    The cables are good clean I haven’t tried to run temporary ground
  10. Feb 25, 2024 at 5:30 PM
    Jtoy813
    02 Toyota tundra
    So while driving it’s like some times it catches and will go but if you try to accelerate to much to fast it stops and lose rpm/power it don’t die just don’t accelerate
  11. Feb 25, 2024 at 5:46 PM
    87warrior
    87warrior Whiskey Tango Foxtrot
    Kansas
    2004 DC 2uz 4x4
    The intake air sensor is part of the mass air flow sensor. The MAF can cause non running problems.
    What temperature is the incoming air temperature reporting?
    How many CFM or g/s is the MAF reporting when its driving and when it stumbling?
    Is your throttle position sensor reporting numbers that make sense?
    shifty` likes this.
  12. Feb 26, 2024 at 7:39 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    What does your intake filter look like??
  13. Feb 26, 2024 at 8:13 AM
    Everyone here will just be spitballin' based on the limited info we have and the fact that your rolling a replacement engine installed by who knows who. Someone knowledgeable in these trucks and engines will need to be present to help you troubleshoot. Otherwise you'll be chasing your tail.
  14. Mar 17, 2024 at 12:57 PM
    Jtoy813
    02 Toyota tundra
    New coil packs ignition, new plugs
    New fuel to air ratio sensor basically o2 sensors bank 1. And 2 for upstream and downstream new also fuel pump filter yep you got it new mass airflow in tank sensor new
  15. Mar 17, 2024 at 1:10 PM
    When did the issue begin? Before, or after all the new stuff?
  16. Mar 17, 2024 at 1:27 PM
    Jtoy813
    02 Toyota tundra
    Before we thought it needed to warm up due to old weather
  17. Mar 17, 2024 at 1:35 PM
    Wait - so the truck was sitting? How long, and where?
    Have you checked for rodent damage in the usual places? If you don't know what I mean by "usual places", check this thread: https://www.tundras.com/threads/so-you-wanna-buy-just-bought-a-1st-gen-tundra-eh.115928/
    If you don't want to read the first two replies fully, search the 1st page for "rodent". You may need a snake camera to look under the manifold through the slot in the front. You may be able to look through the runners on the pre-VVTi models, not sure.
