Loose BD Fog Light
Discussion in 'Lighting' started by alpinepro4, Jan 9, 2018.
  1. Jan 9, 2018 at 7:32 PM
    alpinepro4
    alpinepro4 [OP] What is your MPG Today!
    Pat
    2017 TRD Pro Cement DC
    Baja Designs Squadron Sport Fog lights, ARE CX Series Topper, Alcan Springs , DAP Tune, Coach Builder +1 Shackles, Headlight Revolution Supernova V.4 LED bulbs, HR LED interior bulbs. General Grabber ATX 275/70/R18
    I noticed tonight my driver side fog light was not shining correctly. I went out to check the light and it dropped down about 1/2". I can grab the BD bezel and move it up and down. If I remember right the light is being held in place by OEM screw and mounting bracket. How do I securely mount the light so this doesn't happen again? I saw someone zip tied the light in place.
  2. Jan 9, 2018 at 7:46 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Might have been @BlueBottle . He suggested that when I told him my Morimotos were rattling all over the place.
  3. Jan 9, 2018 at 7:49 PM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    Unless you have a different bracket I don’t remember mine mounting loosely. Do you have the fog kits?
  4. Jan 9, 2018 at 7:56 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    It’s not the bd that’s lose. It’s probably the stock plastic housing. Yes zip tie it to the black bracket
    SpeshulED, MotoTundra and 831Tun like this.
  5. Jan 9, 2018 at 7:59 PM
    alpinepro4
    Pat
    Mark, I do have the mounting bracket. I did notice the plastic housing is loose. I will pull it all apart. It bugging the hell out of me.
    1UPPER and Eclipsed & Floating like this.
  6. Jan 9, 2018 at 8:01 PM
    Baja Designs
    Baja Designs The Scientist of Lighting Vendor
    Bill
    San Marcos, CA
    Sorry about the issue with your kit. Here is a picture of how the BD bracket attaches to the Factory Fog Insert:
    Sometimes the clips that hold the fog insert into the bumper can break causing the assembly to rattle or possibly fall off in extreme cases. I would recommend double checking the bracket orientation and the clips that hold the fog insert into the bumper. If for some reason any of your BD parts are missing please contact us at 800-422-5292.
    -Bailey, Baja Designs
    www.bajadesigns.com
  7. Jan 9, 2018 at 8:04 PM
    alpinepro4
    Pat
    I believe the BD bracket is fine. I think the blue clip might be the culprit. I won't know till I get in there. I do love the lights:thumbsup:
  8. Jan 9, 2018 at 8:07 PM
    alpinepro4
    Pat
    Just in case it's the blue clip anyone know the part# or what it's called?
  9. Jan 9, 2018 at 8:11 PM
    Eclipsed & Floating
    Voluptuous Whitey
    @Roman would probably know
  10. Jan 9, 2018 at 8:14 PM
    alpinepro4
    Pat
    Mark thanks I will send him a message if it's indeed the blue clip.
    Eclipsed & Floating likes this.
  11. Jan 9, 2018 at 9:01 PM
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    I just installed this kit and didn’t notice a blue clip on either side. Anyone have a pic?
    MotoTundra likes this.
  12. Jan 9, 2018 at 9:04 PM
    alpinepro4
    Pat
    Think the blue clip is only on 2016/17 Tundra if I remember right.
  13. Jan 10, 2018 at 2:36 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    Hopefully someone has seen Zoolander...
    This is how I feel right now....
    Baja Designs[QUOTED] likes this.
  14. Jan 10, 2018 at 7:26 AM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
  15. Jan 10, 2018 at 6:30 PM
    alpinepro4
    Pat
    Roman, thanks for the part#. We are getting hammered with snow so it will be a few days before I can take a look.
  16. Jan 12, 2018 at 3:31 PM
    alpinepro4
    Pat
    Pulled the wheel well apart and the machine screw that holds the bracket came out. Only the outside screw was holding the light in place. Went to the local headwear store and bought 6mm machine screw, lock washer and removable thread lock. Won't come out now. Almost passed on the project today glad I didn't. IMG_0897.jpg
    BlueBottle and boostedtrdpro like this.
  17. May 9, 2018 at 4:11 PM
    TundraCoast
    TundraCoast Member In Good Standing
    Ian
    California
    1794 4x4
    1794 on the inside - PRO on the outside
  18. May 9, 2018 at 4:25 PM
    GreatAvalon
    GreatAvalon New Member
    2016 Tundra Limited DC
    Subbing to this thread. I just ordered the blue clips today from Roman just in case, as I plan to install the 2018 LED fog lights. I previously zip tied them, but those blue clips are like $1.50 so it's worth a shot to see if it takes care of the looseness more cleanly than zip ties.
  19. May 10, 2018 at 6:38 AM
    Roman
    Roman
    Franklin, TN
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-lamp-bezel-with-fog-lamp-521280c070
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-lamp-bezel-with-fog-lamp-521270c070
    The little blue clips are only for models with the plastic, painted bumpers. The chrome bumpers do not accept the clips.
