Looks like Toyota may be backtracking on the key fob remote start subscription.
Discussion in '2.5 Gen Tundras (2014-2021)' started by jhardy1979, Dec 23, 2021.
  1. Jan 10, 2022 at 7:55 AM
    #61
    normagene
    normagene New Member
    Normagene
    New England
    2021 Cement DC Limited Texas Edition
    Texas Edition
    Yes and my window sticker does say it has remote connect or something like that. Dealership never told me I could start it using the fob. Only using the app which I didn’t bother cuz it has a subscription fee once the free trial is over.
    Figured why even bother.
  2. Jan 10, 2022 at 8:02 AM
    #62
    Retired...finally
    Thanks. This feature doesn't work on my SR5. I didn't think it would since I have the old style ignition switch. Don't really need it anyway.
  3. Jan 10, 2022 at 8:25 AM
    #63
    Retired...finally
    I wonder if the parking brake must be applied for the RS to work. If I were designing a RS system it would require the parking brake to be applied in order to start the truck.
  4. Jan 10, 2022 at 8:51 AM
    #64
    normagene
    Normagene
    New England
    Texas Edition
    Sometimes if I press the Lock button too slow in between clicks it doesn't work. For mine 1 second in between seems to work.
    So Press Lock (one Mississippi) Press Lock Again (one Mississippi) Press Lock Again and Hold Down (one mission….two Mississippi….three Miss……..up to 6 Mississippi then release the clicker.
    That’s how I have to do mine. A whole bunch of Mississippis :)
    jrquist likes this.
  5. Mar 29, 2024 at 3:02 PM
    #65
    SD Surfer
    Bruce
    So Cal
    So I have a stupid question: I assume this only works on the "push to start" models?
    Like my '19 with an E-key won't do this hack right?
  6. Mar 30, 2024 at 8:11 AM
    #66
    BoyHowdy
    BoyHowdy New Member
    2021 Tundra
    Not sure but did you give it a try just for science?
    woods likes this.
  7. Mar 30, 2024 at 8:26 AM
    #67
    SD Surfer
    Bruce
    So Cal
    Lol, you'd think that would be the first step huh?
    I didn't, only 'cuz when I wrote that I was at work and drove my wife's car.
    woods likes this.
  8. Mar 30, 2024 at 8:39 AM
    #68
    seydou
    seydou Distinguished Member
    What he said is correct. I do not have the app, I am not connected to Toyota, and the fob works for remote start.
    What?
  9. Mar 30, 2024 at 8:40 AM
    #69
    BoyHowdy
    BoyHowdy New Member
    2021 Tundra
    Ah no worries, well when you get a chance try it out and report back.
  10. Mar 30, 2024 at 10:44 AM
    #70
    JohnWhicker
    JohnWhicker New Member
    This does not work for me. So I don't have it?
  11. Mar 30, 2024 at 11:06 AM
    #71
    seydou
    Not necessarily. It can be a bit tricky to get the cadence of the button pushes correct. I press and when I hear the beep I press again, holding it down on the third press untill the lights flash multiple times.
    Henry1jg likes this.
  12. Mar 30, 2024 at 11:16 AM
    #72
    JohnWhicker
    Is it possible that I don't have this option on my 2021?
  13. Mar 30, 2024 at 11:30 AM
    #73
    seydou
    What level trim?
  14. Mar 30, 2024 at 11:45 AM
    #74
    JohnWhicker
    SR5 TRD Off Road. It does not work, I tried every possible way :)
  15. Mar 30, 2024 at 7:46 PM
    #75
    TRLDD
    TRLDD New Member
    2018 Cement Tundra CrewMax SR5
    Works on my 2018 SR5.
  16. Mar 30, 2024 at 9:45 PM
    #76
    SD Surfer
    Bruce
    So Cal
    Nope, no joy.
    2019 SR5 w/TRD Pkg
    Probably for the best... If it worked then I would usually forget to turn it off with AC or heat set for how I'd want it when I used the nifty remote start, then I'd just be pissed off about that. :frusty:
  17. Mar 31, 2024 at 3:35 AM
    #77
    woods
    woods New Member
    2021 SR5 TRD Sport
    I have a 2021 sr5 sport and it works.
  18. Mar 31, 2024 at 6:22 AM
    #78
    boatsnbikes
    boatsnbikes New Member
    Also 21 sport and mine works. Like already said it’s a little tricky to get the timing right though.
  19. Mar 31, 2024 at 6:34 AM
    #79
    JohnWhicker
    Well I guess I am not tricky enough for my truck. My truck is fighting me and and I am gonna ground it for few days LOL
    boatsnbikes[QUOTED] and woods like this.
  20. Mar 31, 2024 at 6:46 AM
    #80
    woods
    woods New Member
    2021 SR5 TRD Sport
    I don't even use it, I just walk outside and start my truck. It needs the truck locked and turns itself off after a while I think.
    I want it open and running for as long as I feel it needs.
  21. Mar 31, 2024 at 6:48 PM
    #81
    NoMoreGreen
    NoMoreGreen New Member
    Robert
    2020 Tundra
    2020 SR5 / TSS no remote start.
  22. Mar 31, 2024 at 7:49 PM
    #82
    TundraTXTSS
    TundraTXTSS New Member
    Conroe
    2020 White TRD Pro
    Window Breakage add on Alarm,Wireless Charger. Console Safe, Rear Dif Breather Relocation, Rear Under seat Storage, Hard wire for Radar Detector, Tonnneau Cover, Brake Sensor Protection,SABM with TRD Filter, Tailgate lock, BFG's, LED Running lights.D-3 Tuner.
    Works on my 2020 Pro, if you start with remote start you can also turn it off by doing the same three clicks on lock.
  23. Apr 1, 2024 at 12:19 PM
    #83
    Redseal199
    Redseal199 New Member
    2021 CM NightShade
    Tried mine at lunch after reading all this and I am still good to go... Never did the app and mine is a 2021 Limited. I rarely used it to begin with, as like said above its finicky at best.
    woods and Bergy24 like this.
