Looking to see if I can fit 305/55/20
Discussion in '1st Gen Tundras (2000-2006)' started by Mhagha, Jan 24, 2023.
  1. Jan 24, 2023 at 9:03 AM
    Mhagha
    Mhagha [OP] New Member
    Hey everyone,
    2001 Tundra V6 Access Cab 4x4
    I have been looking for wheels and I’m looking for a certain look for my Tundra.(pics attached)
    I have called a few wheel and tire companies but no one can help me.
    I have no one near me that can fit on wheels to see if/how they fit. I am going to someone to see what they think and can do….
    I have updated my front end. I do not have a lift kit or leveling kit. New billstein 5100s gave me more height.
    I am trying to avoid leveling kit. I do not want a lift kit.
    I am looking to see if I can fit on 305/55/20s. I don’t mind cutting a little, but nothing major.
    I will go down in size some if I can get this look.
    Thanks!
  2. Jan 24, 2023 at 9:26 AM
    Casper421
    In the woods
    06 DC
  3. Jan 24, 2023 at 9:46 AM
    Mhagha
    Same reason you like Ryan Reynolds……
    whittkl4 likes this.
  4. Jan 24, 2023 at 9:52 AM
    That look will require a lift kit. No way to clear tires that wide on stock setup. Also gonna require extensive BFH work in them wheel wells. Those are 33" plus tall tires. They are also 12" wide. Both require a lift to clear and a different offset wheel and fender modifications. This is one of those scenarios when you want a thing, but don't want any of the consequences of that thing. Something will have to give.
    des2mtn, Mhagha[OP] and shifty` like this.
  5. Jan 24, 2023 at 10:20 AM
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    I had to look on the calendar to make sure it wasn't April 1st or something.
  6. Jan 24, 2023 at 10:21 AM
    Casper421
    In the woods
    06 DC
    He is pretty funny, similar to your wheel choices.
    tvpierce, 2006Tundra and Elevatorguy like this.
  7. Jan 24, 2023 at 10:24 AM
    Do your thing @Mhagha, just know that this crowd isn't into bro-dozers. Taste is what it is. Handy tip, the search function here blows ass. Use google to search what you want to know and add tundras.com into your search request. Works way better than the one top right here.
  8. Jan 24, 2023 at 10:31 AM
    Not only that advice ^^ but I also see at least one of your pics is from the Custom Offsets website, which is chock full of bro-dozer setups - that is, impractical -street queens' with skinny tires, crazy deep dish/high offset wheels, weird and sometimes dangerous lifts - and normally they give info on how it was achieved, or general specs of the setup, which you can maybe model after.
    If you want any of the setups you show above, and insist on not throwing lifted springs in front and AAL lift out back, you'll at need a 3" body lift for clearance, but (ideally) both lift springs/AAL + body lift to get the job done.
    Any set of wheels and tires I'm seeing there are going to set you back a good $2,500 alone, not including the need for wheel spacers, potentially.
    Elevatorguy likes this.
  9. Jan 24, 2023 at 10:48 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    Last i checked, 5100s are a suspension lift.
    @Mhagha best you're going to do at stock height is a 31" tire without rubbing.
    Most of us with a 2-3" suspension lift (5100s, Eibach Pro truck ,dobinson, OME, etc) are running a "32-33" tire. that's as big as you can functionally get on these trucks without a BFH and a grinder, or a big 'ol drop bracket lift.
  10. Jan 24, 2023 at 11:13 AM
    Mhagha
    @Shifty,
    Yeah. I see that. I def do-not want to lift and have a bad ride. I def like the wheels. But will go smaller and see….
    I do see I have to address some children on this post. @HBTundra. That’s your comment coming from A 2WD Guy? Really? As you can see I can do it as well… be positive, give info if you have it. The world doesn’t revolve around your likes and dislikes. Many come on here to learn, and others share all the great advice they have. Don’t be mad. Have a good day!
    @Casper421. Is this what you do all day? Come on here to tell everyone what you think they should like? Move on… keyboard warrior. Have a good day!
  11. Jan 24, 2023 at 11:15 AM
    Mhagha
    Def don’t want to lift it without having headaches and a bad ride. So Thanks for that info!
    lsaami[QUOTED] likes this.
  12. Jan 24, 2023 at 11:17 AM
    Mhagha
    Yes I tried to search on here before I posted. I did google and some owners do have info posted and some others don’t.
    Thank You!
  13. Jan 24, 2023 at 11:53 AM
    Casper421
    In the woods
    06 DC
    Yeah, in between fixing the stupid mistakes people make on their vehicles, like adding massively oversized wheels and tires. But thank you, we call people like you job security. I've been around since 17, not going anywhere anytime soon. Especially now that I have a new internet friend! :wave:
    Just for shits and giggles, is this your first vehicle?
    bmf4069, Elevatorguy and BubbaW like this.
  14. Jan 24, 2023 at 12:05 PM
    If you’re gonna be on the internet, ya gotta have thicker skin people
  15. Jan 24, 2023 at 12:13 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
  16. Jan 24, 2023 at 12:17 PM
    Literally, @Mhagha, if you were going to pick one guy on this forum to be a snowflake with, you managed to pick one with more wheel/tire/alignment/lift experience than most others. He's not kidding, he literally installs and fixes wheel/tire/suspension mistakes. Might be ribbing you while doing it, which is normal around here, but the guy is trying to save you grief. Just some of the stuff he's been working on the last few weeks... :
    https://www.tundras.com/threads/1st-gen-lunch-table-general-discussion.60450/page-1317#post-2974940
    https://www.tundras.com/threads/1st-gen-lunch-table-general-discussion.60450/page-1410#post-3055252
    https://www.tundras.com/threads/1st-gen-lunch-table-general-discussion.60450/page-1412#post-3057826
    You really gotta loosen up, man. Life's too upshort to be uptight, much less to worry if someone is trying to disrespect you all the time.
  17. Jan 24, 2023 at 1:24 PM
    Mhagha
    Guys,
    I get it. He’s your buddy. I’m new here it’s all good but maybe it’s the other way around? Don’t dish it out if you can’t take it.
    Just because you have Experience and being on this site since 2017 doesn’t entitle you to talk to people the way you want. Yeah it’s the internet, so what.
    I just asked a question….
    Anyways,
    Are we moving on or are we continuing with this BS?
  18. Jan 24, 2023 at 1:39 PM
    Casper421
    In the woods
    06 DC
    Just because you don't get the answer you want doesn't mean you have to argue and cry about it. If you took the time to research this site, you would find your answer. With stock suspension you can fit a tall 31. If you want the mall crawler look with rubber band tires, 295/40r20 or 275/50r20 will fit. That only took me 4 minutes to figure out what tire size YOU should run. My minimum charge is $80, where should I send your invoice?
    bmf4069 and Elevatorguy like this.
  19. Jan 24, 2023 at 2:04 PM
    Mhagha
    Casper,
    Knock it off….
    And I did look. The search bar on this site is a bit funny.
    Thanks
  20. Jan 24, 2023 at 2:40 PM
    Casper421
    In the woods
    06 DC
    It’s alright kid, you’ll learn one day, maybe. Enjoy your truck.
    bmf4069, Taco-Spike and Elevatorguy like this.
  21. Jan 24, 2023 at 7:28 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Before I joined this site (or had my truck) I had a buddy with an 02 that lifted it and did a similar wheel/tire setup. Believe it was 285/55r20s. Had some rough country shock spacer in the front (junk) and then block lift in the back. The tires rubbed the UCA just a tiny bit but only sometimes, as well as the frame rail when turning which rubbed it down to bare metal. They fit but not great but don't think you can do it without lift. Maybe your slight front lift is enough but hard to say.
    I don't think it looked terrible but not really my style anymore but to each their own.
    Here's the only picture I have of it. (After he hit a deer and dented the door and ripped the flare off)
  22. Jan 24, 2023 at 8:01 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    I'll personally heckle you if you get less than 60 series tires.
  23. Jan 25, 2023 at 7:22 AM
    Mhagha
    Thanks @NickB_01TRD
    This is the look I’m going for. I don’t mind going down in size to 19” rims. As long as I can get the look I want. And have the correct tire I want. I am not looking for a low profile tire. The picture you posted and what I posted is what I like
    Problem is no one really knows about tires that can fit properly when you call online dealers. And if your lucky, maybe at a shop near..
    If I would go down to 19” or maybe….18”. What would be the tire size/a that would fit to achieve what I’m going for?
    Does “anyone” know…..
    Thanks
  24. Jan 25, 2023 at 7:32 AM
    19" will be harder to find tires for. 18" and 20" will be your best bet, 20" may have cheaper tire options. "That look" is gonna rub without a lift or wheel well modification. 2.5" lift up front will clear 33" tires on 18 or 20" rims IF YOU DON'T GO TOO WIDE. have to pick one, wide or tall. If wide is the goal, many mods must be made. Taller is easier than wider. Wide makes them rub the frame, the wheel well, the mud flaps, the UCAs etc. offset changes what it rubs. These trucks have small wheel wells. All of those pictures you posted are of lifted trucks with modified wheels wells and they all still rub 100%.
  25. Jan 25, 2023 at 8:14 AM
    Mhagha
    If you know,What would be the size for 18”
    I’m not sure if having the TRD off-road package helps out any with space…
  26. Jan 25, 2023 at 8:17 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    I have some 20's and 33's that are way too big to fit.
    supposedly they came off a sequoia with 3" lift and spacers.
  27. Jan 25, 2023 at 8:46 AM
    Original tire size for these is 30" tall tire by 9-10" wide on a 16" rim. They were pretty snug. TRD suspension is not a lift, but different shock coil combo. I have 30.5" by 10" wide tires on 16x8" rims and they would rub without the 2" lift. They rubbed with the lift and I had to trim the mudflaps.
    Weagle and Mhagha[OP] like this.
  28. Jan 25, 2023 at 9:02 AM
    Mhagha
    Thank you. That actually helps a-lot..
    maybe 18s are the way to go.
  29. Jan 25, 2023 at 10:30 AM
    It’s not the rim diameter, it’s the overall tire diameter. An 18” rim with a 33” tire will have 7.5” of sidewall height. A 20” rim with 33” tires will have only 6.5” of side wall height. Both will take up the same space in the wheel well.
  30. Jan 25, 2023 at 11:48 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    What look are you going for? Are there specific wheels you have in mind? These trucks are best suited for 16-17" wheels.
