Looking for tow mirrors!!!
Discussion in '1st Gen Tundras (2000-2006)' started by itscoreyc, Jul 12, 2020.
  1. Jul 18, 2020 at 4:41 PM
    04TundraTRD
    04TundraTRD Once upon a time....
    Neil
    Kentucky, near Louisville
    2004 Tundra TRD 4WD AC
    TRD Supercharger, Bilstein 5100's on all four corners, Setting 4 on the fronts, 1" Front Diff Drop Kit, Suspensionmaxx Front Sway bar end links, 1" lift shackles out back, 1.5" wheel spacers all around, 285/75R16 BFG AT TA/KO2's, Front Brush Guard with 20" LED light bar, Kool Vue Dodge style tow mirrors, Yellow Box Speedo Corrrecter by Yellr, Volant CAI, Banks Monster 3” Catback Exhaust, LED's on the interior, LED Headlamps and LED Back Up Bulbs
    This may belong in the mods section, but here goes.
    The first part was easy. Remove the door panel, disconnect the wiring harness' and put aside. Disconnect the mirror harness (if equipped with
    power/heat). Remove the mirror.
    Old and new mirror side by side.
    The Dodge mirror has a similar base but it is taller and wider. Here are additional pictures of the individual mirrors.
    I did update my spacers while I had the mirrors off. It looks like this now. You can also see the base that was made for the mirror. It was cut out from a mud flap.
    Here you can see that the forward hole has to be extended to fit the dodge mirror.
    Mounted.
    I was wrong about how i wired them up. Rather than cutting the harness from the stock mirrors I just pulled the pins from the Dodge connector, insulated them and connected them directly to the harness in the truck. Here are a few pictures of that.
    And finally some close ups of the finished product.
    Hope this helps in your decision making process. If anyone has questions feel free to ask.
    Tundra2, T4RFL, WestCoast Fl and 4 others like this.
  2. Jul 18, 2020 at 10:04 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    thats great. I tried an old dodge mirror previously but the base was WAY different so I nixed it but did see I would have to move the front bolt hole. I know that the AC and DC models on our 1st gens are different so hopefully that doesn't screw with me too much. I get the mirrors wednesday so with work, the wife and kids, and finishing some house projects I hope to get them installed before 2022! :(
  3. Jul 21, 2020 at 9:43 PM
    04TundraTRD
    Neil
    Would you take some pictures and measurements of the mounting plate and bolt spacing. They look like they would fit better than the dodge adaptation.
    Tundra2 likes this.
  4. Jul 21, 2020 at 10:39 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Sure will. I am hoping they fit a lot better. Should be here tomorrow
  5. Jul 22, 2020 at 2:29 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    whelp....got the mirrors today and started dinking around with them. Had to drill another top mounting hole and just oval'd the bottom ones to the upper insides to make the studs fit better. There obviously needs to be some wiring changes but it fits fairly well. I cannot mount it though because the studs on the mirrors are too short. Tried a few different tactics to get the studs off but couldn't so not sure what to do even if I found new longer studs.compare.jpg
    Comparison of new Taco mirror on the left and old Tundra mirror on the right old wire.jpg old wire2.jpg
    Old wiring that uses 5 of the 6 spots. Not sure if the wiring is the same for the diff trims or not.new wire.jpg new wire2.jpg
    New wiring. Has a disconnect for the heated part (I assume) and comes with an additional wiring harness or can be plugged into the main connector it appears.mount.jpg mount2.jpg rubber.jpg
    Mounting rubber piece was used to line up the stud holes. There was gonna be gaps but I lined it up with the window (left straight part in picture) to try and make the mirror straight up and down.studs.jpg studs2.jpg
    Mounting studs are 1/2" shorter on the new mirrors from the plastic plate vs 2" on the old Tundra mirrors.
    Studs BARELY show their faces. Unfortunately not enought to get nuts on them :/
    Different view if it actually was mounted up.
    04TundraTRD and bmf4069 like this.
  6. Jul 22, 2020 at 5:38 PM
    Professional Hand Model
    Hand Protectors
    Try an Acorn Type Nut similar to our lug nuts so that it can reach down and capture the threads through the drilled hole and the flat washer ring presses on the outer surface. You may need a Unibit to wallow out the hole to customize it to your Acorn Nuts Shaft.
    CodyP[QUOTED] likes this.
  7. Jul 22, 2020 at 6:01 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    That’s a good idea. Thanks I’ll try tomorrow maybe
  8. Jul 22, 2020 at 9:05 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    well it would be nice to find some around town but that's a no go. I am thinking maybe I could order some coupling nuts and then thread in small bolts on the inside to tighten everything. Gotta order off Amazon though :/
  9. Jul 23, 2020 at 10:59 AM
    bmf4069
    bmf4069 Captain wtf
    Beau
    TX
    02 AC sr5 4wd v8
    Can you double nut it to try and pull the stud out or would that ruin it?
    CodyP likes this.
  10. Jul 23, 2020 at 12:50 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    that may ruin it but on the flip side the threads that close to the base wouldn't be used so maybe I will try that. Then I just gotta find some longer studs which probably means online since HD and Lowes don't carry much
  11. Jul 23, 2020 at 1:02 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Brilliance. Not sure why I didn’t think of this before @bmf4069
    So, now I can either try and find longer studs or maybe unscrew the studs by a few threads and put a bit or spacer on the inside?
    bmf4069 likes this.
  12. Jul 23, 2020 at 1:07 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Well poop
    bmf4069 likes this.
  13. Jul 23, 2020 at 1:10 PM
    Hand Protectors
    What about flipping that stud bolt and using a spacer. That way you have more shaft in the threads. Bummer on the snappage.
  14. Jul 23, 2020 at 1:23 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    yeah I did that and looks like I may get enough threads to do that as well. But if they studs are out I may just get a M6x1 threaded rod and some nuts instead.
  15. Jul 24, 2020 at 5:00 AM
    bmf4069
    bmf4069 Captain wtf
    Beau
    TX
    02 AC sr5 4wd v8
    I was thinking about all thread too. Usually your local hardware store will have metric sizes. I had to get some in 10mm to hang some fans from canada. I left the extra at the shop hoping someone else would grab it thinking it's 3/8s. I'm a dick like that. :D
    CodyP[QUOTED] and 04TundraTRD like this.
  16. Jul 24, 2020 at 5:05 AM
    04TundraTRD
    Neil
    LMAO! I think we'd get along just fine.
    bmf4069[QUOTED] likes this.
  17. Jul 24, 2020 at 5:15 AM
    04TundraTRD
    Neil
    Could you take some measurements of the new mirror base along all three sides. I'm curious to see how it compares to my factory mirrors. It looks like the mirrors from my '04 AC use a different base than the '06 DC.
  18. Jul 24, 2020 at 12:41 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    yes i'm sure they do. The headlights and I believe taillights differ on the DC vs the AC too....
  19. Jul 24, 2020 at 12:42 PM
    #49
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    my local stores only have threaded rods in standard sizes..no metric :(
  20. Jul 24, 2020 at 2:06 PM
    #50
    Have you popped by your local Fastenal? There's one right there in CDA. Fastenal is like my 2nd home when I'm fabbing stuff up. If you get a good person behind the counter, they can usually run up just about anything you can imagine, and many of them have tons in stock.
  21. Jul 24, 2020 at 3:35 PM
    #51
    bmf4069
    bmf4069 Captain wtf
    Beau
    TX
    02 AC sr5 4wd v8
    You would be correct.
  22. Jul 25, 2020 at 12:23 AM
    #52
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    son of a! Never even thought about Fastenal.
  23. Jul 25, 2020 at 6:10 AM
    #53
    Toyokuhl
    Toyokuhl New Member
    aaron
    SWFL
    2018 Cav Blue CM OR
    Uhhhh oem! Why wouldn't you?
  24. Jul 25, 2020 at 6:11 AM
    #54
    Toyokuhl
    Toyokuhl New Member
    aaron
    SWFL
    2018 Cav Blue CM OR
    Oh nvm 1st gen my bad carry on lol
    CodyP and bmf4069 like this.
  25. Jul 25, 2020 at 6:16 AM
    #55
    04TundraTRD
    Neil
    Good thing you caught yourself. Some of us first genners are ruthless.
  26. Jul 25, 2020 at 6:21 AM
    #56
    bmf4069
    bmf4069 Captain wtf
    Beau
    TX
    02 AC sr5 4wd v8
    SouthPaw, Tundra2, shifty` and 3 others like this.
  27. Jul 25, 2020 at 6:28 AM
    #57
    Hand Protectors
  28. Jul 25, 2020 at 6:30 AM
    #58
    bmf4069
    bmf4069 Captain wtf
    Beau
    TX
    02 AC sr5 4wd v8
  29. Jul 25, 2020 at 6:30 AM
    #59
    bmf4069
    bmf4069 Captain wtf
    Beau
    TX
    02 AC sr5 4wd v8
    Well that didn't work the way I wanted....
    Tundra2 and 04TundraTRD like this.
  30. Jul 28, 2020 at 2:40 PM
    #60
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Anyone know the pin outs on the 2006 tundra mirror and then the 2005-2015 Tacoma towing mirrors?
