Looking for the best overall LED headlight/ foglight.
Discussion in 'Lighting' started by TexasReaper, Jun 2, 2017.
  1. Jun 2, 2017 at 9:54 AM
    TexasReaper
    TexasReaper [OP] New Member
    Beaumont, TX
    2017 Red TSS 4x4
    3"lift and 35" tires
    So many options, what is the best overall plug and play LED headlight and foglight for the money?
  2. Jun 2, 2017 at 10:08 AM
    HUTCHJ
    HUTCHJ I can ride my bike with no handlebars
    J
    Check this video out. Kinda long but should help you out. Definitely recommend watching it all the way through.
    https://youtu.be/SQF5ESBHLrw
    TheBeast, Tomcat and Tony'sToy like this.
  3. Jun 2, 2017 at 10:55 AM
    PermaFrostTRD
    Northern NY
    Morimoto XB fogs for sure.
    I went with Philips ultinon LED head lights. Direct bulb swap. Plug and play.
    Very happy with appearance and performance. IMG_5127.jpgPic was before I installed the morimoto fogs. They match the color output of the headlights.
    Phillips says 6200k but it's much closer to the 5500k of the morimotos. This was a huge selling point for me. I hate the blue light look. These are white.
    GV1990, BlueBottle and NewImprovedRon like this.
  4. Jun 2, 2017 at 11:43 AM
    Let's see nights shots down lonely road highs n lows with without fogs
  5. Jun 2, 2017 at 1:36 PM
    strosek7
    strosek7 New Member
    2016 Black Tundra SR5 DC
    I have morimoto xb fogs they are brighter than stock halogen. Dont like led with out projector because light output is scattered with reflector headlights giving them worse than stock imo. Do a retrofit is really only true way for brighter output. @eledobleu
  6. Jun 2, 2017 at 1:51 PM
    Tony'sToy
    Tony'sToy New Member
    Tony
    Savannah, MO
    2015 Toyota Tundra SR5 TRD OFF ROAD
    6" Rough Country lift kit 20" BMF Novakane Wheels 35"X12.50R20 Nitto Trail Grappler MT AIRAID Cold Air Intake Flowmaster Outlaw Exhaust System Bushwacker Pocket Style Fender Flares Recon Projector Headlights (Smoked) Recon 35 Watt Hid Headlights Recon 35 Watt Hid Foglights Recon LED Brake Lights (Smoked) Recon LED 3rd Brake Brake Light (Smoked) Recon LED Tailgate Light Bar(Smoked) Recon LED Big Rig Light Bar (Smoked) Recon LED Bulbs Every Bulb Location Rough Country 30" Bumper Mount Single Row Light Bar. Headlight Revolution LED Interior Light Kit Replaced Every Bulb Blue LED Bulbs Toyota TRD PRO Grille (Black) TRD Shift Knob All Windows Tinted 20% WeatherTech In Channel Window Deflectors WeatherTech Floor Liners Extant Encore Tonneau Cover
    I have the GTR LIGHTING gen 3 ultra series from Headlight Revolution fog lights. They are brighter than my Recon HID head lights in a Recon projector housing. The video up top is no bull shit. The light out put is insane! Plus life time warranty. They will replace them for life no questions asked . Can't beat that!
    treihing and NewImprovedRon like this.
  7. Jun 3, 2017 at 9:18 AM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    I have the same setup. Here is a vide before I installed my XB's though
    https://www.youtube.com/watch?v=TSxC-l5Tf2o
  8. Jun 3, 2017 at 9:20 AM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    With XB fogs in
    FFCB47E0-3496-4A6D-B672-89166349D516_zps_644f58f043ca23cfd47a957f9736c7fe11b13e00.jpg
    MotoTundra, Viper3G and PermaFrostTRD like this.
  9. Jun 3, 2017 at 10:11 AM
    PermaFrostTRD
    Northern NY
    Entirely possible I got the idea from you. If so, thanks. I love the set up. So much better than stock.
  10. Jun 3, 2017 at 10:42 AM
    Tony'sToy
    Tony
    Savannah, MO
    Yes these are just plug and play!!
  11. Jun 3, 2017 at 10:54 AM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Yes with the exception that you need to mount tha led driver. It's easy though. Double stock tape and zip ties.
    PermaFrostTRD likes this.
  12. Jun 18, 2017 at 12:43 PM
    MTwiford
    MTwiford The second mouse always gets the cheese
    2025 Platinum TRD Magnetic Gray
    Are the Morimoto fog lights easy to install? Do the headlights need to be removed to get to them or can you do it without removing them?
  13. Jun 18, 2017 at 2:00 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    MTwiford and NewImprovedRon like this.
  14. Jun 18, 2017 at 3:53 PM
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    LED interior lights, Baja Designs foglights, Baja Designs S8 hood bulge light bar, LED bed lights, Baja Designs S8 amber bar in bumper on Rago Fab mounts, AMP Research bedstep, Switch Pros sp-9100, tinted door windows
    I went with some Baja Designs Squadron Sport lights instead of a bulb replacement. Easy install. Can be done be removing the back of the bumper inner wheel well mud guard.
    18582238_1531503136861810_25094413166031_e343cf733330a7e494f6990305196c2486f76e95.jpg
    Here they are compared to the stock headlights.
    18557040_1531769963501794_29903726264735_5fd00160b7505016251f72f09b090ac47997df22.jpg
    MotoTundra and MTwiford like this.
  15. Jun 18, 2017 at 4:51 PM
    PermaFrostTRD
    Northern NY
    +2
    I didn't have enough stock wiring to install mine from the front of the bumper. Once I installed them from behind (and made a mess of the liners and tabs and screws - UGH eff those things) the morimotos had more wire so I was able to adjust / aim the lights once they were installed by accessing them from the front.
    The only bad thing you'll notice about the morimoto fogs is that they will instantly make you wish you replaced your headlamps at the same time. They're that much better.
    @MTwiford
    040Tundra, Viper3G and NewImprovedRon like this.
  16. Jun 18, 2017 at 6:02 PM
    MTwiford
    My headlights are getting retrofitted with HID/RX350 projectors as we speak, so my problem is the opposite :) I need to get rid of these ugly fog lights lol. Thanks for the info guys
  17. Jun 19, 2017 at 2:56 AM
    sstoddard
    sstoddard New Member
    Shawn
    2019 Crewmax Sport
    Alarm/start (Compustar Ft7000,Rf2wl1b 2-way remotes and Drone Mobile) Tailgate inserts NSV Lightbar Tailgate actuator Blacked out decals
  18. Jul 11, 2017 at 2:31 PM
    TheBeast The Beach
  19. Jul 11, 2017 at 5:25 PM
    sstoddard
    Shawn
    2019 Crewmax Sport
    I have there switchback leds and they are awesome
  20. Sep 21, 2017 at 3:11 PM
    Viper3G
    Viper3G Why isn't work more like this?
    Rick
    2016 Crew Max 1794 4WD Super White
    Phillips X-treme Ultinon LED H4 bulbs, 3M Color Stable 35 tint on front doors, 3M Crystalline 40 on sunroof, OEM bed liner, OEM running boards, Morimoto fog LEDs, Fold-A-Cover G4 Elite, Husky X-Act Contour floor mats
    After reading this thread I got the Phillips X-treme Ultinon LED bulbs. I didn't want to shell out a lot for retrofits with projectors and couldn't wait to see how the 2018 LED headlight assemblies worked. I was concerned if I would be satisfied with the amount of light and worried about some threads that said LEDs threw a lot of light all over the place. I installed them and then went on a 500 mile trip. I'm very happy with the Phillips LED bulbs. They were plug and play. The low beam is 100% better than the OEM halogen, IMO. The beam cutoff is good and I'm not blinding oncoming traffic which I would assume would be flashing me if I were. The high beams are adequate. They do seem to throw a lot of light upward. I don't need them that much so I can live with it. The light color also matches the Morimoto XB fogs really well.
  21. Sep 21, 2017 at 4:00 PM
    PermaFrostTRD
    Northern NY
    I have the same setup and experience with my Philips as you. I'm very happy with them
    Viper3G[QUOTED] and BlueBottle like this.
  22. Sep 21, 2017 at 5:04 PM
    poheller
    poheller 2018 Platinum
    Scot
    The great state Ohio
    2018 platinum
    I just installed the VLED hi/lo led lights last week, so much better, also installed the switch backs a few months ago. VLED LMZ
  23. Oct 29, 2018 at 1:57 AM
    Traril
    Traril New Member
    Brain
    North Bergen,New Jersey
    Ford F150
    none yet
    I recently bought some ebay H4 LED bulbs. I've been running them for a month, and am still not sure if I like them or not.
    If you buy some, make sure you buy the first style you posted and not the second style. You want the LED elements to be arranged as close as possible to where the filaments would be in a normal H4 bulb. You also need the little reflectors on the low beam elements to maintain the vertical cut off properly. Also, the first bulbs you posted have three elements in each position. However you can find the same bulb style with four elements in each position, which are rated much brighter. I ended up buying bulbs with fans, but obviously it would be better buying bulbs with passive coolers instead.
    So far here are my thoughts on them:
    Positives:
    - Use less power from the electrical system (LEDs are more efficient, less heat more light).
    - Great low beam light output/pattern
    - The LEDs are regulated, which means your lights don't get dimmer if your alternator output drops a bit at idle. The light output is always the same regardless of the power input.
    - Look more modern.
    Negatives:
    - When we got snow, there was not enough heat from the bulbs to melt the snow off my H4 housings. So I quickly lost light output as my housings covered in snow.
    - The high beam does not project as well as my old Halogen H4's. It's wider, but not as far.
    - I don't really like the narrow light spectrum/color. Even though there is more light, it is almost harder to see. A halogen has a wider spectrum, so is easier to see.
    - The bulbs I bought seem to create electrical noise that interferes with my radio. The result of buying something from China that doesn't adhere to electronic emissions requirements.
    - Can't fit the rubber boots over the bulbs I bought.
    I bought bulbs on the cheaper end of the spectrum. There is certainly potential with this technology, it's just a matter of picking the right bulb design I think. For example, Philips makes LED bulbs. They are expensive as heck, but I bet they are good. Most of the Chinese bulbs are knock-offs of the Philips ones.
    These are the ones I bought:
    2x H4 160W 16000LM LED Headlight PHILIPS Chip Kit High Low Beam Bulb 6000K White
    If I were to try another pair, I'd probably try something more like these ones. I like how they are flatter, with less aluminum cupped around the LEDs blocking light:
    https://10carbest.com/led-headlights-bulbs
  24. Oct 29, 2018 at 4:17 AM
    Part_time
    Part_time Not a new member
    Oregon
    2017 MICA BRONZE SR5
    What about Cali raised?
