Looking for some wheel knowledge
Discussion in '1st Gen Tundras (2000-2006)' started by CRudy, Oct 9, 2019.
  1. Oct 9, 2019 at 4:50 PM
    CRudy
    CRudy [OP] New Member
    Collin
    2006 Toyota Tundra. Double cab. SR5
    Whats up! I'm new here and recently bought a 2006 Tundra, SR5, double cab, 4 wheel drive. I've practically finished all of my maintenance that I wanted to do (Timing belt, replace all fluids, ball joints, etc..) and am now ready to get to some aesthetics. That being said I want to start with the wheels, it currently has the stock silver wheels on it and I was looking to replace them with the Toyota Trail edition wheels that came on some 4runner and FJ's. So ive done some researching and I cant quite get a definite answer if they will work, I was hoping someone here with some more wheel knowledge could help me out. The current set up that's on the truck now is:
    Tires - BFG all terrain ko2 LT285/70/R17 121/118R
    Wheels (according to the sticker on the door jam) - 17x7.5JJ
    The truck also has a leveling kit on it, I'm unsure what size because the previous owner put it on and I forgot to ask
    Thanks for any help!
  2. Oct 9, 2019 at 4:54 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    It will looks awesome with the 4 runner wheels
  3. Oct 9, 2019 at 5:00 PM
    SoCalPaul
    SoCalPaul New Member
    Paul
    San Fernando Valley, CA
    2006 Tundra Access Cab Limited 4wd.
    Front Bilstein 6112 shocks & Bilstein springs. Rear Bilstein 5160 remote Reservoir shocks, Wheeler’s Off-road add-a-leafs. LED lighting. Pioneer Avic 7200NEX Nav Head unit. Borla cat back exhaust.
    Post a pic, should be fine.
  4. Oct 9, 2019 at 5:01 PM
    CRudy
    Collin
    Oh, this might be valuable also, here are the specs for both wheels based off of the official tundra guide that is a sticky here and just from reading other posts about the trail edition wheels.
    Tundra stock wheels for 2006:
    Lug pattern: 6 lug 5.5 inch or 139.7mm medium offset
    Lug nut thread pattern: M12 x 1.5
    Center bore: 110mm
    Width: 7.5"
    Offset: +18mm
    Backspacing: 5"
    Hub Bore Diameter = 106mm
    Toyota Trail edition wheels:
    6 lug
    Diameter: 17
    Width: 7.5
    Offset: +15mm
    Back spacing: 4.84"
    Bolt pattern 139.7mm
    Also for the width of the stock tundra wheel it says 7.5 JJ and the trail edition wheel is 7.5 J. From what I've read the JJ or J have to do with the lip or bead of the wheel? will this hinder me from using the trail edition wheels on my truck? Thanks!
  5. Oct 9, 2019 at 5:07 PM
    CRudy
    Collin
    hbjeff, I know Ive seen a picture on here where someone has them and I think it looks awesome! and SoCalpaul, will the difference in Offset and Backspacing be a cause of concern? Also, havent taken many pictures but Ill see if i can upload what Ive got
  6. Oct 9, 2019 at 5:12 PM
    Voyagermike
    Voyagermike New Member
    California
    Hbjeff and SoCalPaul like this.
  7. Oct 9, 2019 at 5:13 PM
    CRudy
    Collin
  8. Oct 9, 2019 at 5:20 PM
    CRudy
    Collin
    Sorry if those pictures arent working or are too small, I tried to drag and drop it from my email and unsure how well it actually worked lol. And Voyagermike, thanks for the link, Ill check it out! I was pretty sure they'd fit my truck, I just wanted some extra opinions before I spend the money on the new wheels. Also, last question, does my current tire size matter for the new wheel, or will it pretty much mount right to new wheel because the diameter and width are the same? Even though the stock wheels are 7.5 JJ and the trail edition are 7.5 J?
    Voyagermike likes this.
  9. Oct 9, 2019 at 5:47 PM
    SoCalPaul
    Paul
  10. Oct 9, 2019 at 6:02 PM
    CRudy
    Collin
  11. Oct 9, 2019 at 6:03 PM
    CRudy
    Collin
    That should have worked, they are a little big haha
  12. Oct 10, 2019 at 11:30 AM
    Albatrossboss
    Albatrossboss New Member
    I have those wheels on my 2006 SR5 Double Cab. No problems whatsoever. Will be upgrading tires here in the next couple of months since the tread was still good when I purchased it in July.
    Don't mind the pups
  13. Oct 10, 2019 at 12:43 PM
    Wammer
    Wammer New Member
    MN
    2003 Tundra SR5
    I have the TE wheels on my 2003 with LT275 /70 R17 KO2s. They rub slightly at full lock but nothing serious.
  14. Oct 10, 2019 at 2:14 PM
    CRudy
    Collin
    Awesome, looks like I’ll go ahead and try and find some. Both nice looking trucks y’all have, thanks for the replies!
  15. Oct 10, 2019 at 2:19 PM
    Voyagermike
    California
  16. Oct 10, 2019 at 2:21 PM
    CRudy
    Collin
    Good idea man, preciate it
