Looking for some advice
Discussion in 'Audio & Video' started by bayfisher27, Jun 24, 2018.
  1. Jun 24, 2018 at 4:27 PM
    bayfisher27
    bayfisher27 [OP] New Member
    JEFF
    2018 TUNDRA SR5
    Alpine ILX Carplay, Bedcover
    Gents,
    I'm installing a set of Image Dynamics CXS 64 V2 both in the front and rear doors. I would like to mount the tweeter directly on the coaxial so if someone looking through the window they wouldn't know i have a system. I know I will sacrifice some sound quality, but i'm ok with it.
    So, the instructions that came with the speakers were not great. Once i mounted the tweeter directly on the midbass driver the instructions made it sound like i wire the tweeter to the midbass versus the crossover. Clear as mud? Wouldn't i just wire up the tweeter and connect in to the crossover just like i would if i mounted the tweeter in the sail panel?
    Thanks in advance! You guys are great!
  2. Jun 24, 2018 at 4:30 PM
    bayfisher27
    JEFF
    2018 TUNDRA SR5
    After reading that, i am not sure if that made any sense. In others words, i want to wire and install the comp set just like a coaxial.
  3. Jun 25, 2018 at 8:43 AM
    B737
    B737 Throbbing Member
    Jersey Shore
    2015 Tundra Double Cab Limited
    if you put the tweeters inside the front dash corners, they will be totally invisible, and there is a ton of room in those front corners.
    also, the trucks with JBL have tweeters in the door sail panels, so that would look stock too. Mine are in the front dash, sound great.
  4. Jun 25, 2018 at 9:10 AM
    yoneytan
    yoneytan New Member
    Asi
    14 CM
    Mine are in the dash as well and sound great.
  5. Jun 25, 2018 at 7:01 PM
    bayfisher27
    JEFF
    2018 TUNDRA SR5
    gotcha! Thanks guys!
  6. Jul 4, 2018 at 1:13 PM
    Landman500
    Landman500 New Member
    joseph
    2016 Tundra double cab limited try off road
    good luck
