Looking for pics of your 3rd gen Tundra with just a leveling kit, wheels, and tires. Thanks.
Discussion in '2.5 Gen Tundras (2014-2021)' started by TOYTUNDRA18, Dec 30, 2019.
  1. Jan 20, 2020 at 7:04 PM
    #61
    aussieaarons
    aussieaarons die with memories, not dreams
    2019 Cavalry Blue TRD
    2” level, roof mount DVD, interior LED bulbs, sumosprings out back, OEM folding cover, Blackout emblems
    #61
    Rustedfenders and yoshi82 like this.
  2. Jan 20, 2020 at 7:24 PM
    #62
    Steve89gt
    Steve89gt New Member
    2018 Limited CM
    De-badged, De-chromed, TRD CAI, TRD Exhaust, Bilstein 5100s, Fuel 18 x 9 wheels, BFG KO2s 275/70/18, ESP Underseat Storage
    5100s all around, 275/70/18s, Fuel 18 x 9s
  3. Jan 21, 2020 at 10:06 PM
    #63
    Willskaf
    Willskaf New Member
    William
    Castro Valley, CA
    19, Limited, CrewMax, Off Road, Cement Gray
    None Yet
    Ok fellas, so the TRD pro is 2" higher on the front than my TRD off-road. The rear are exactly the same height. I have seen on this forum and on many YouTube videos people installing the 295/70/18 on the TRD Pro with OEM wheels without any rubbing at all. All they had to do is remove the front mud flap. Wouldn't that mean if I put a 2-inch spacer lift in the front I will be also able 2 fit 285/70/18 as well ? I don't have a problem also installing the bumper shim
  4. Jan 21, 2020 at 10:08 PM
    #64
    Willskaf
    Willskaf New Member
    William
    Castro Valley, CA
    None Yet
    This will be on the OEM Wheels of course
  5. Jan 22, 2020 at 7:36 PM
    #65
    SR520
    SR520 Lay it tight
    Robert
    Evergreen
    2020 SR5
    Leveled by Toytec: Boss Aluma 2.5 adj coilovers/ UCA
    IMG_20191226_095533.jpg IMG_20200121_092945.jpg 00100lrPORTRAIT_00100_BURST20200121092845047_COVER.jpg Toytec Boss Aluma 2.5 Coilovers
    Adjustable 0-3" (mine leveled @ 2")
    SPC adjustable UCA
    Fuel Lethal 18x9 / +20 offset
    Yoko 285/65
    207UplandGame and DaBoro54 like this.
  6. Jan 22, 2020 at 7:51 PM
    #66
    Willskaf
    Willskaf New Member
    William
    Castro Valley, CA
    None Yet
    Thanks buddy. I'm wondering if I can fit a 295/70/18 on my OEM wheels with a 2" leveling kit .
    Silverghost likes this.
  7. Jan 22, 2020 at 8:11 PM
    #67
    SR520
    SR520 Lay it tight
    Robert
    Evergreen
    2020 SR5
    Not really apples to apples for my setup. Standard offset is +60. These wheels are +20. Looking at the back side of my wheel I don't think there's clearance for an even wider tire than what I have without that extra 1.5 "
    Wish I could be more help.. Maybe someone has that setup..
  8. Jan 22, 2020 at 8:12 PM
    #68
    Willskaf
    Willskaf New Member
    William
    Castro Valley, CA
    None Yet
    I appreciate you brother .I understand
  9. Jan 22, 2020 at 9:16 PM
    #69
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    2016 Limited 4x4, 2003 Sequoia
    It does look like there's been some rubbing on the UCA
  10. Jan 22, 2020 at 9:47 PM
    #70
    Floydk
    Floydk New Member
    Floyd
    Paso Robles, CA
    2019 Tundra Sport
    TRD PRO WHEELS 2.5 LEVEL KIT
  11. Jan 23, 2020 at 12:12 AM
    #71
    Willskaf
    Willskaf New Member
    William
    Castro Valley, CA
    None Yet
    @mjiminez , you are running 35s with just a leveling kit and no rubbing? You didn't have to do anybody chop or remove a plastic? I see in the picture that the front plastic have been removed if I'm not mistaken. Can you give the whole setup please? Exact tire size and brand, offset, how many inch and what brand leveling kit?
  12. Jan 23, 2020 at 4:13 AM
    #72
    Paulismydog
    Paulismydog New Member
    2020 Black Limited Double Cab
    Are the the 17 or 18 inch Method 313s? Thanks.
  13. Jan 23, 2020 at 1:15 PM
    #73
    Highsierraguy
    Highsierraguy New Member
    Nor Cal
    17’s, tires are 285/70/17 Load C
  14. Jan 23, 2020 at 5:40 PM
    #74
    cctxquicksand
    cctxquicksand IG - TRDistheWrd
    Honestly the seal on the top SUCKS, it’s the only down side to these particular flares. No trimming is required to install them, super easy they just screw right in, the fronts do have a bracket that needs to be put on first though. I drive an hour to work and there have been a couple times that the wind will catch the rubber gasket and start pulling it off because the top seal is not the best. They come w silver hardware but I just spray painted them all black since I was already painting the flares.
    aussieaarons[QUOTED] likes this.
  15. Jan 24, 2020 at 9:18 AM
    #75
    XPTUNDRA
    XPTUNDRA New Member
    North MS
    2016 Tundra Limited
    4" Pro Comp Lift 35x12.50x20 Toyo RT's 20x9 +20 Fuel Mavericks Rough Country soft tri-fold bed cover LED headlight and Fogs with LEDs throughout the cab as well
    OR it has been bumped during tire install ?????
    Either way there's no rubbing this area after install. Trimmed the skid plate on both sides and removed mud flaps.
  16. Jan 25, 2020 at 12:05 PM
    #76
    Cement4WD
    Cement4WD New Member
    Cement TRD Off Road 4x4
    Nice tundra! What steps are those and are they wheel to wheel? Thanks!
  17. Jan 25, 2020 at 4:41 PM
    #77
    OPSteel
    OPSteel New Member
    2017 White Tundra TRD Crewmax
    TRD grille, Bushwacker OEM flares, stereo system
    I put fender flares, 285/70/18 RG’s, 3/2 leveling kit, and am now going to buy 18x9 SRG’s to pome them out just a hair.
  18. Jan 25, 2020 at 4:53 PM
    #78
    KERNEL_DALE
    KERNEL_DALE New Member
    Norcal
    19’TRD-PRO
  19. Jan 26, 2020 at 8:29 AM
    #79
    OPSteel
    OPSteel New Member
    @DALE That might be the baddest ass Tundra I’ve seen, ever.
    Mr_Kane and KERNEL_DALE like this.
  20. Jan 27, 2020 at 11:27 AM
    #80
    Baldmonkey22
    Baldmonkey22 New Member
    Quartz Hill, Ca
  21. Jan 29, 2020 at 3:01 AM
    #81
    kleiker0303
    kleiker0303 New Member
    Kyler
    Kansas City
    ‘16 Platinum
    Bilstein 6112 @ 1.9" Bilstein 5100's in rear Afe drop in filter Afe intake tube Afe throttle body spacer Afe catback with vibrant resonator added Stubby antenna TRD front grill Paint matched door handles Paint match mirror caps RCI skid plate All LED bulbs Undercover flex cover 20% tint all around Husky floor liners ESP under seat storage 2018 headlight mod Baja designs fog light kit 275/60/r20 falken wildpeak at3w 20x9 fuel ripper
    what size tire are you running? looks nice
  22. Jan 29, 2020 at 4:41 AM
    #82
    Baldmonkey22
    Quartz Hill, Ca
    Thanks, they are 295/60/20
  23. Jan 29, 2020 at 11:57 AM
    #83
    kleiker0303
    Kyler
    Kansas City
    ‘16 Platinum
    Do you know what offset your xd’s are? I’ve got a +1 offset I Think and am wanting to run 295/60/20. Any rubbing issues with the 295’s?
    1SassyShan likes this.
  24. Jan 29, 2020 at 1:22 PM
    #84
    Baldmonkey22
    Quartz Hill, Ca
    I have -18, and had to remove the front and rear mudflaps and spaced the bumper out with Coachbuilder shims. I also had to push the front lower fender liner forward and redrill 1 hole to keep it in place. The +1 should clear a lot easier.
    kleiker0303 likes this.
  25. Jan 31, 2020 at 4:01 AM
    #85
    XPTUNDRA
    XPTUNDRA New Member
    North MS
    2016 Tundra Limited
    N-Fab. No they don't go wheel to wheel. Complete cab coverage though
    Cement4WD[QUOTED] likes this.
  26. Jan 31, 2020 at 4:48 AM
    #86
    FancyPants
    FancyPants Not my Husband’s truck
    Amber
    Oregon
    ‘19 SUPER WHITE Platinum Crewmax
    4” leveling kit with 33’s. No rubbing. My brother has the same 4” but with 35’s and had to cut to avoid rubbing
  27. Jan 31, 2020 at 4:52 AM
    #87
    FancyPants
    Amber
    Oregon
    Mine are the same but are the wheel to wheel version. They offer both. ;)
  28. Feb 3, 2020 at 6:42 AM
    #88
    yoshi82
    yoshi82 New Member
    DAVID
    HOUSTON
    2014 Silver Tundra SR5
    3in ToYtech lift on Tundra and 2.5in in the rear. Tow Mirrors. Toyota grill, and Front bumber. New 6in antenna. Repainted the stepping boards
    @platslvrblt19
    That’s a old pic before the rims. I have a 2in block in the back.
  29. Feb 3, 2020 at 6:09 PM
    #89
    Gitlin1
    Gitlin1 New Member
    2017 Tundra 1794 Crew Sunset Bronze Mica
    yoshi82 likes this.
  30. Feb 4, 2020 at 11:13 AM
    #90
    Rustedfenders
    Rustedfenders If it ain't broke, don't fix it.
    Wally
    Rosedale Md.
    2016 Blazing Blue Pearl TRD Tundra Crew Max
    Aries 4" Bull Bar, 3-2 Level Lift Havoc Stainless hoop steps.
    Looks good. Whats the lift?
