Looking for enablers..
Discussion in 'New Member Introductions' started by 04trdv6, May 19, 2019.
  1. May 19, 2019 at 6:30 AM
    04trdv6
    04trdv6 [OP] New Member
    Lynn
    Houston / Corpus
    Researching 1st Gen
    Hi All,
    I already have a 1st gen Tacoma and an 80 series Land Cruiser, but I've got a new itch for a 1st gen Tundra. Not looking to get rid of either of the other two, but to add to the collection. This doesn't seem like rational thought any way I try to spin it so figured I'd join the site and surely there would be some spin doctors here that could help convince me this is the right thing to do.
    I'm thinking 1st gen just because they can be found reasonably priced, I expect easy enough to work on (I am no mechanical wizard) and because I just think it's cool to have the 1st generation. I'll be perusing the forums looking for pros and cons. If anyone wants to shoot me some ideas of particular threads to read through that would be greatly appreciated.
  2. May 19, 2019 at 6:31 AM
    seniramsu
    seniramsu Pro Runnin
    Nate
    VA
    2017 TRD Pro Tundra Wht
    Welcome from NC!!
    Pinay likes this.
  3. May 19, 2019 at 6:44 AM
    04trdv6
    Lynn
    Houston / Corpus
    Researching 1st Gen
    Thank you sir.
    Pinay likes this.
  4. May 19, 2019 at 6:45 AM
    Blueknights75
    Ron
    Clayton, NC
    Just watch out for frame and underbody rust and welcome from NC!
  5. May 19, 2019 at 6:46 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    :wave: Hi and welcome from SoCal!!!
    15whtrd and 04trdv6[OP] like this.
  6. May 19, 2019 at 6:51 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Welcome from AZ!
    04trdv6[OP] likes this.
  7. May 19, 2019 at 6:51 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Welcome from TX!
    Only drawback for me and Gen 1's is the timing belt, costly maintenance item. The 5.7 and 4.6 engines in Gen 2 & 3 have chains.
    Migraine likes this.
  8. May 19, 2019 at 7:04 AM
    04trdv6
    Lynn
    Houston / Corpus
    Researching 1st Gen
    Thanks. Good info there. But it's the non interference just like the 3.4 in the Tacoma right? I know I can look this up but I thought I read that there was an option for the 4.6 on the 1st Gen? Lots of reading to do. Maybe done so much already I've confused myself.
    I'm in Houston also. Well my home is Houston but work and spend most of my time in Corpus Christi now.
    Black Wolf likes this.
  9. May 19, 2019 at 7:09 AM
    Trooper2
    JR
    I cannot verify 4.6 in Gen 1, but they did put some 4.7's in the 2007's as they evolved. Not sure if later Gen 1 would have 4.6 when they were still making 4.7 for early Gen 2.
    Non interference sounds right but cannot confirm.
  10. May 19, 2019 at 7:10 AM
    Fishin RGV-Trd Pro
    Fishin RGV-Trd Pro White is faster
    Alex
    RGV Texas
    2011 White Toyota Tundra Limited
    Welcome from South Texas. Nice collection. Gen 1 Tundra would look good in your garage.
    :yes:
    Sunnier likes this.
  11. May 19, 2019 at 7:14 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    This information is a couple years old, but it's still valid.
    The 4.6 is Gen 2 only.
    The Most Underrated Cheap Truck Right Now: A First-Gen Toyota Tundra
    Sunnier and 04trdv6[QUOTED][OP] like this.
  12. May 19, 2019 at 7:15 AM
    04trdv6
    Lynn
    Houston / Corpus
    Researching 1st Gen
    Right? Almost like I HAVE to.
  13. May 19, 2019 at 7:15 AM
    Welcome from Houston, what part of town are you?
  14. May 19, 2019 at 7:20 AM
    04trdv6
    Lynn
    Houston / Corpus
    Researching 1st Gen
  15. May 19, 2019 at 7:22 AM
    04trdv6
    Lynn
    Houston / Corpus
    Researching 1st Gen
    Pearland actually.
  16. May 19, 2019 at 8:18 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome from Colorado
  17. May 19, 2019 at 8:42 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Welcome, you must have one.
    First gen only have 4.7 for V8, there are also V6 available and even some V6 with manual trans.
    The 99-04 have the 245hp 315tq V8 and 4 speed auto
    There are some hard to find 00-03 with the supercharger, adds about 100hp and 100tq.
    The 05-06 have the 271hp 313tq V8 and 5 speed auto
    03-04 have two notable improvements over prior models, they have larger front calipers and a stronger transmission.
    Double cabs are only 04-06.
  18. May 19, 2019 at 8:45 AM
    Rex Kramer
    Georgia
    There are regular cab long bed 1st generation Tundra, the most desirable are 4WD SR5 V8
  19. May 19, 2019 at 8:48 AM
    Hammerdog
    Hammerdog YCMTSUP
    Robbie
    Louisa VA
    2018 tundra sport crew max
    Tint Bed cover Red Tow Hooks TRD Intake 7 inch BDS 22x12’s 35 Toyo’s Rigid ditch lights RC light bar in bottom grille One bad ass stereo
    I’d like to get me a decent used one to drive back and forth to work and to hunt in. They are decent trucks.
  20. May 19, 2019 at 8:53 AM
    realtorblake
    realtorblake Tundra Thunda
    Redneckistan... aka Cypress, TX
    2019 Crewmax Platinum 5" Zone lift Fox 2.5 /OME suspension 12.5x35x18 ProComp's
    Wecome from Cypress, TX! Our son is USCG stationed in Corpus.
    04trdv6[OP] and Black Wolf like this.
  21. May 19, 2019 at 8:56 AM
    Bappa
    Bappa Off the grid
    Bo
    Arizona
    2018 Tundra CrewMax
    Coil overs (3”) and 295 tires, ESP storage, grab bar; RCI skids; tinted windows; rear air bags
    Welcome from AZ.
    Go for it!
  22. May 19, 2019 at 9:03 AM
    Trooper2
    JR
    Fellow Pearlander or Pearlandonion or Pearlandite, etc!!!
    04trdv6[QUOTED][OP] likes this.
  23. May 19, 2019 at 9:03 AM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    Welcome to the party!!
  24. May 19, 2019 at 9:29 AM
    BestGen
    BestGen New Member
    Paul
    Haunted Turnbull Canyon CA
    '05 RCLB, 2UZ-FE, 4wd / '88 4RNR XTE 22RE/W56/RF1A
    Fabtech 2.5" coilovers, BFG KO2 34/10.5/17, 17x7.5 TE wheels, add-a-leaves, 4.56 gears, Rhino-lined
    Welcome fellow first genner! :cheers:
    More Toyotas is always a good thing. I've got multiple Toyotas too. Tacomas, 4Runner, Tundra... all 1st Gens! 4.7 is an interference engine. Timing belts are to be changed every 90,000 miles.
    Sunnier, 04trdv6[OP] and Black Wolf like this.
  25. May 19, 2019 at 10:05 AM
    SQUAIDS
    SQUAIDS New Member
    Eric
    2010 Tundra Limited Slate metallic
    Stealth Custom series SR8 matte black 3 inch lift. Air Lift 5000 rear. TRD offroad.
    Do it! I have 5 vehicles not including the wifes. Welcome!
  26. May 19, 2019 at 10:09 AM
    Professional Hand Model
    Hand Protectors
    Welcome from St. Barts South Coast! These 1st Gens can be maintenance hogs. Bake in the front suspension rebuild before buying as they get real tired in the 130k range.
    Sunnier and 04trdv6[OP] like this.
  27. May 19, 2019 at 12:29 PM
    04trdv6
    Lynn
    Houston / Corpus
    Researching 1st Gen
    I haven't been in Corpus long enough to have an opinion on the place. Still learning my way around. I do know that apparently I am required to have some fishing gear.
    Sunnier likes this.
  28. May 19, 2019 at 12:34 PM
    04trdv6
    Lynn
    Houston / Corpus
    Researching 1st Gen
    Good to know. I've done the 80 and the Taco. Same usual suspects for suppliers? Like Wheelers and head strong, etc...
  29. May 19, 2019 at 12:41 PM
    Hand Protectors
    In my case, I had a local shop do the front suspension work. For the other DIY items, I shop either ToyotaPartsDeal or Big Gurl from Brasil sites. I keep it mostly OEM on all the suspension/mechanicals/maintenance. Will stray to OE on other items that make economical sense.
  30. May 19, 2019 at 1:13 PM
    Rex Kramer
    Georgia
    165,000+ on my '02... the front suspension is solid.
    I do take great care of the tires & shocks, so that must be why it's still solid.
