Looking for a bed cover
Discussion in 'Tonneau Covers, Caps and Shells' started by Bryguy215, Aug 22, 2019.
  1. Aug 22, 2019 at 3:41 AM
    Bryguy215
    Bryguy215 [OP] New Member
    New jersey
    Grey Tundra 1794
    I'm picking up a 2019 1794 edition And the first thing I will need is a bed cover. I keep tools in my bed so I need something safe and I also need it to be convenient to fold up so I can put my quad in the back. Any suggestions for quality cover?
  2. Aug 22, 2019 at 4:26 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
  3. Aug 22, 2019 at 4:40 AM
    Fishman57
    Fishman57 New Member
    Wayne
    Bucks County, PA
    The BakFlip MX4 will do the job. That’s what I have and I am very happy with it.
    OR18TRD likes this.
  4. Aug 22, 2019 at 4:52 AM
    Gotyour6
    Gotyour6 New Member
    Fairport, NY
    2019 Tundra Pro
    I have an Extang Solid Fold 2.0 Tonneau Cover that is a pile of shit so I can't tell you what to get but I can tell you not to get this one.
    It isn't a solid fold, it is more like a foam fold. It dents easily and I had two divots in it from the installer over tightening it so the company said.
    They replaced the panel but said if it happens again I am SOL.
    The problem is that when you dont tighten it it shows light where you clamp it down. Which means water will get in there.
    I will be getting something else from a different company maybe in the spring
  5. Aug 22, 2019 at 7:37 AM
    Devildog183
    Devildog183 New Member
    Roger
    Kansas
    2019 Limited CM 4x4 2007 SR5 DC 4x4
  6. Aug 22, 2019 at 7:39 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Not sure of your location but there is one listed on the Texas Fishing Forum. I can get info if you want. Dude is in San Antone. Cover looks nice. Non-fishing classified
  7. Aug 23, 2019 at 2:43 AM
    Bryguy215
    New jersey
    Grey Tundra 1794
    My buddy has this one on his gmc and he likes it also. The two little arms that hold the cover up seem a little shaky to me tho. Any issues with that?
  8. Aug 23, 2019 at 2:44 AM
    Bryguy215
    New jersey
    Grey Tundra 1794
  9. Aug 23, 2019 at 2:58 AM
    Fishman57
    Wayne
    Bucks County, PA
    Not when they’re in use. They’ve worked very well for me. The only issue that I have is them popping out of the storage hooks when not in use. I’m going to heat the hooks up and bend them a little more closed to see if that helps.
  10. Aug 23, 2019 at 3:31 AM
    SIMPLYTHETRUTH
    SIMPLYTHETRUTH THE ALBINO RHINO
    PA
    2020 Cement TRD
    S&B Cold Air Intake, Recon light bar, Rough Country light bar, Cali ditch lights, aFe throttle spacer,
    BakFlip are nice. I used to have one. Bought form autoanthing they prices matched what I found plus extra 5%. Ended up is the 650-680 range.
    Bryguy215[OP] and Fishman57 like this.
  11. Aug 23, 2019 at 7:19 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I have the undercover flex. Honestly not sure how i should review it. I hate it, but i forget that ive used it for 3 years so maybe it “worked”
    It was watertight for 2 years. But for the last year it drips water through every seam. The pull handle action is also worn out, still works OK. It has to be smacked down to engage all the latches.
    The reason i hate it is likely not their fault. I don’t have deck rails so it is clamped on, the clamps fail all the time, even with red locktight and tightening. IF i had deck rails, it would go on with those and be solidly mounted. I didn’t know that at the time.
    If i have to replace the bedcover every 3 years I’m ok with that. Next time i am getting a rugged cover. I have a 6.5 foot bed so im ok with the front not folding up.
  12. Aug 23, 2019 at 2:02 PM
    djhase
    djhase member
    David
    Southern Illinois
    2019 Silver Tundra TRD
    Check out Truxedo.com and look at the Sentry. Its there secure cover that will still roll up out of the way so you can load a bike or atv in the back.
  13. Aug 23, 2019 at 2:58 PM
    jeffw6236
    jeffw6236 New Member
    Jeff
    San Antonio
    2019 MGM CrewMax 4x4
  14. Aug 23, 2019 at 2:58 PM
    TheBeast The Beach
    American tonneau cover. Love mine
    I have the hard panels tri fold one
  15. Aug 25, 2019 at 7:17 PM
    MICKs18yota
    MICKs18yota New Member
    Ohio
    2018 Tundra SR
    Can you post some pictures I’m looking at this one
  16. Aug 25, 2019 at 7:59 PM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    I have a Bak X2 revolver, it’s two years old and is coming apart. Im going back to a full painted hard cover soon.
  17. Aug 25, 2019 at 8:02 PM
    andersab
    andersab New Member
    Fort Mitchell, KY
    2019 Black Tundra TRD Off-road
    I have a Retrax Pro. Great aluminum cover that "rolls" up. Super smooth and fits very well to my 2019.
  18. Aug 25, 2019 at 8:12 PM
    TheBeast The Beach
    no pics right now but here is a good video that helped me decide to go with them.
    I like that I am able to use the toyota oem bed and I can remove the cover quick if needed. It's also hard panels so they won't get slashed easily with a knife.
  19. Aug 25, 2019 at 8:36 PM
    Dos Cylindros
    Dos Cylindros New Member
    2022 1794 Edition Smoked Mesquite
    Try peragon.com, I just bought one and it’s an awesome cover.
  20. Aug 25, 2019 at 8:43 PM
    Moco
    Moco New Member
    Marcos
    Boerne
    2019 Tundra TRD Pro, 2015 JKU Rubicon, 2016 HD 48
    I will take the info if you don’t mind, I am in San Antonio and looking for a cover for my new TRD pro
  21. Aug 25, 2019 at 9:45 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    You could leave your tool inside and put your quad up on top of the bed
    Diamond back HD
    hma153, oriojasjr and OR18TRD like this.
  22. Aug 26, 2019 at 2:57 AM
    Midnite72
    Midnite72 Anything DIRT !!
    Bill
    Northern MD
    18 SR 5.7 4x4
    2” level P&P sliders
    @DECKEDUSA
    Waterproof/ lockable storage- put 2000 lbs on top and not have to move tools- unless there too big to fit under cover or In drawers
    Lower center of gravity vs diamond back cover- al though u get full depth of bed
    JM2C
    Pistol0528 and DECKEDUSA like this.
  23. Aug 28, 2019 at 3:17 PM
    MICKs18yota
    Ohio
    2018 Tundra SR
    Thanks looks like a nice fit on top of the rails I’m looking for something that goes to the edge and that one looks really good.
  24. Aug 28, 2019 at 3:36 PM
    Alexstundra
    Alexstundra Not a new member
    Northeast PA
    2016 MGM DC Trd
    Just this moment.... I realize what the taping noise is when I stop. I never hook them in and just let em dangle. Interesting
    Fishman57[QUOTED] likes this.
  25. Aug 28, 2019 at 5:47 PM
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
    Steer clear of the Extang tri-fold. Dents easily, lets water in, and is too heavy. Not impressed and will likely replace it soon.
  26. Aug 28, 2019 at 6:35 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    I got a bak flip before with my tacoma, it work very well for the first few years. later I found out the channel need cleaning like once a year because the dust other crap got inside the channel and block the drain so water went inside the bed and all my hand tool got rusted. The Aluminum on the panel is super thin, I put a shower door on top once and it cut the aluminum panel open. All you need is a coat hanger to open the cover because the cable latch that they use, so its a low security cover. In 6 years of use, I used the whole bed with the cover in open position like 5 times, cause when you have the whole bed full of tools, you don't really want to unload everything to use the bed and put everything back once you are done. So when I got my tundra I choose the diamond back HD instead. I just use the bed for tool storage and use the top of the cover for real hauling
  27. Aug 28, 2019 at 8:12 PM
    biebs96
    PA
    I have a gator evo bi-fold cover. For the past 6 years I’ve had a cap and loved it.
    So this was different approach, but I don’t want to sacrifice this back window.
    TundraDude18 likes this.
  28. Aug 30, 2019 at 10:52 AM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    Truck Covers USA american work cover - has a built in tool box and you can wire up to lock/unlock with your doors/key fob. No need to open/flip anything up to get to your tools. Could throw a light in the toolbox too so you can see your tools at night. Nicely built covers that index every 12" plus your sweet view out the back window wont be ruined when the cover is retracted. Final feature is you can throw a rack on top of the cover for surfboard/camping tent.. whatever you need.
    Could easily fit a quad in the bed using the Louisiana (LA) guard dog. Works awesome.. used it all the time with my old quad. Just my $.02
  29. Aug 31, 2019 at 9:55 AM
    Bryguy215
    New jersey
    Grey Tundra 1794
    I really like the diamondback bed covers but unfortunately I use my whole bed front time to time. I ended up purchasing the bakflip f1. Just waiting for it to come in now. I will post pics when it's on
  30. Aug 31, 2019 at 10:10 AM
    red arrow
    red arrow New Member
    2021 Gray Metalic Limited Off Road Tundra Crew
    I got a lomax from agri-cover. main benefit is they make a ladder / kayak rack that works with it for hauling a kayak or ladder and still keeping stuff below locked up via tail gate lock. But with a pry bar somebody is probably into it in about 30 seconds....
