Looking at a new furnace...Trane or Carrier?
Discussion in 'Off-Topic Discussion' started by cfred70, Mar 4, 2018.
  1. Jun 26, 2018 at 5:20 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Craig, you done good. Gas furnace split system is good. Even if it was a package unit gas is way to go. Heat pumps are ok if you rarely need heat. Heat pumps w elec strip heaters are expensive to run.
    18 seer. Wow. Expensive up front but huge savings month to month. Trane is quality equipment.
    Someone was talking about Goodman, they are junk, however they had a good warranty. I wouldn’t recommend them to anyone.
    A little background, worked in the hvac industry for 10 yrs, more if you count me tagging along on dads jobs. Granted, it was 20 yrs ago. Still do all my own work and buddy’s stuff. They buy parts n beer. And crawl in attics w me. I teach while working.
  2. Jun 26, 2018 at 5:25 PM
    Sterlinglwood
    Sterlinglwood Never enough!
    Sterling
    Newbury Park, CA
    2017 Tundra Double Cab SR5 4X4
    In the commercial world we referred to them as “Trane wrecks”. Back when I was doing HVAC Trane rooftops would fail and made it hard to troubleshoot when all the wiring was the same color. This was over 10 years ago though and I’m sure it’s changed. As far as homes go Goodman was considered shit back then and that’s what I have in my house now with no problems. The best packages I remember installing were either American standard or York. American standard owns Trane as far as I know. Again it’s been a while.
    PennSilverTaco likes this.
  3. Jun 26, 2018 at 5:29 PM
    gm125800
    gm125800 New Member
    2018 GMC Sierra Denali
    True, I dreaded messing with Carrier's Infinity line of products.
  4. Jun 26, 2018 at 6:37 PM
    BIGUGLY
    Paul
    2018 Limited
    Heat pumps are fine until you have extended periods of cold below 30 degrees. Then your losing all effeciency and have to switch over to your emergency setting. Which is either a gas back up or an electric heating element . They however do a fantastic job as an air conditioner. We had an entire month of sub zero temps and a heat pump will just run and run while the house gets cold. In warmer climates they are great.
  5. Jun 26, 2018 at 6:49 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Yup, exactly
  6. Jun 26, 2018 at 7:06 PM
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck
    Please see signature!
    By the time my parents' Goodmans die, I'll probably be an HVAC technician. I will install a couple of Trane units!
    NewImprovedRon likes this.
  7. Jun 26, 2018 at 7:07 PM
    PennSilverTaco
    Charlie
    2010 Zombie Truck
    Trane and American Standard are both owned by Ingersoll-Rand...
  8. Jun 26, 2018 at 8:00 PM
    Basskrazee
    Basskrazee Pop
    Joe
    Indianapolis, IN.
    2016 Tundra SR5 /TRD
    AFE mass air intake TRD rear anti sway bar Headwaters seat covers TRD Pro grill Bilstien 6112 coil overs Bilstien 5160 rear shocks Consol vault
  9. Jun 26, 2018 at 8:06 PM
    BayRunner
    2017 Tundra Platinum
    I went through this a few years ago when our R22 systems died. I did a lot of research into this subject and discovered that Trane and Carrier were the main 2 picks for after build installs and Goodman were the builder grades used. one of the things I learned that regardless of the brand, almost all of the failures and performance nightmares were caused by the installation. A bad installation or taking shortcuts will present problems in the near future.
    I personally chose the Carrier 19 seer variable 5 stage compressor with 2 stage gas furnace. I worked with the installation company and carefully planned and supervised the install of 2 full units. Going on 3 years now with no problems and my gas and electric bill were cut in half from the original units.
  10. Jun 26, 2018 at 8:07 PM
    PennSilverTaco
    Charlie
    2010 Zombie Truck
    :amen:
    An air-conditioner/heat pump/furnace is only as good as the man (or woman) who installs it!
    landphil, JMB and mdavis like this.
  11. Jun 26, 2018 at 8:24 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    I have two Carrier furnaces and two AC and had Carrier in my last house for 13 years with zero issues.
  12. Jun 27, 2018 at 7:08 AM
    gm125800
    gm125800 New Member
    I've been by their assembly plant before out in Tyler, TX. They build both lines there. I'm not sure if they build their off brand units there though...
  13. Jun 27, 2018 at 10:20 AM
    PennSilverTaco
    Charlie
    2010 Zombie Truck
    There are no "off-brand" units, just Trane and American Standard. One is more expensive than the other, but other than high-end American Standard units lacking the distinctive Duraguard fan grille of the Trane XLi and XV units, they are virtually identical.
  14. Jun 27, 2018 at 10:56 AM
    PennSilverTaco
    Charlie
    2010 Zombie Truck
    The cheaper Carriers are actually better and less problematic in my opinion.
    My parents bought a brand new townhouse in September 2007 and we lived there until March 2016. The house had two 2-ton 13 SEER Carrier A/C units matched with Carrier 92% 40,000 BTU gas furnaces. The units used R-22 refrigerant and even had TXV (Thermostatic Expansion Valve) instead of capillary tubes.
    BTBAKER[QUOTED] likes this.
  15. Jun 27, 2018 at 1:00 PM
    TomC843
    TomC843 The wheel weaves as the wheel wills.
    Tom
    Charleston, SC
    16, 4X4, 4U3, Katzkins, Flowmaster, ARE MX, Swing cases, TRD skid plate, Volant CAI....
    Been in the biz 28 years. Pic is last Wednesday. Really interesting hearing Tundra guys going for multi stage this, wifi that. I have two Goodman 2016 package units in my house. I made sure they had single speed Scroll compressors and NO, ZERO, NONE variable speed motors. I went through the fake allergy filters that just caused restricted air flow phase, the every homeowner trying to install programmable tstat and burning out the transformer (heat pumps have up to 7 wires) phase, now the wifi phase. Glad I got away from residential.My advice is with no experience with cold climate high gas bill is keep the AC or heat pump simple, all new units are high efficiency by law. MOST important thing is proper airflow and proper sizing and proper install.
    JMB likes this.
  16. Jun 27, 2018 at 1:14 PM
    TomC843
    Tom
    Charleston, SC
    Quick part two about wifi tstat and Comercial HVAC. National companies get the big restaurant chains to go with complete wifi control retro fit to their units to save money. What do you think happens when the router drops, no cooling. Calls us gets a several $100 bill. What happens when employee breaks wifi remote sensor, call us and we wire up a regular tstat and drop it in the return and tell them to call the company that wired up everything and order a new one from them. Just get a nice digital tstat, set it, and stop touching it.
    BTBAKER likes this.
  17. Jun 27, 2018 at 1:53 PM
    gm125800
    gm125800 New Member
    Now that i think about it you're right.
    Here in Texas, homeowners were always trying to self install the pesky Nest thermostats. Next day, i was called out to repair what the husband tried to fix. lol
    Quite often they would receive a Nest thermostat for the wrong configuration.
    Tech: Sir, i'm not even gonna try to install this for you...
    HO: Why? (Utility Company) said it would work with my system.
    Tech: You have a heat pump...
    HO: What's a heat pump?
    Tech:...
    HO:....
    TomC843[QUOTED] likes this.
  18. Jun 27, 2018 at 2:59 PM
    PennSilverTaco
    Charlie
    2010 Zombie Truck
    So they had a thermostat for a straight-cool unit?!?!
  19. Jun 27, 2018 at 3:01 PM
    #49
    MistrRoboto
    MistrRoboto '17 MGM SR5 TRD CrewMax
    Virginia Beach, VA
    Another vote for Goodman here. It's Amanas off brand, mostly same internals. Family member who's big in HVAC recommends them over anything else. Great bang for your buck.
    PennSilverTaco and TomC843 like this.
  20. Jun 27, 2018 at 3:15 PM
    #50
    TomC843
    Tom
    Charleston, SC
    Back in the 90's it was Lowe's/ Home Depot digital tstat in place of the dangerous mercury tstat. Sir this is a one stage heat and one stage cool AND you don't have a common wire.
    Red and common is probably the norm today but it didn't use to be.
    Yes sir this is a heat pump tstat but you will have to replace the battery every few weeks because you don't have enough wires pulled to the stat. The guy at the store said this is the right one.
  21. Jun 27, 2018 at 3:18 PM
    #51
    TomC843
    Tom
    Charleston, SC
    Probably single stage heat, heat pump needs 2 stage to bring on the strip. At least in my neck of the woods that was most common.
  22. Jun 27, 2018 at 4:05 PM
    #52
    gm125800
    gm125800 New Member
    Oh yes, this has occurred more than once. The next question of course was, "can you make it work??" Those with two stage equipment had to wait a while for a revised version of the Nest thermostat to come out so that it could be supported. (at least in my area it did)
  23. Jun 27, 2018 at 5:02 PM
    #53
    BayRunner
    Don't agree about the Goodman brand, but that just my personal opinion. Had too many with severe issues over the years. I definitely agree with your filter comment. Folks don't see that these high end (and expensive) filters are killing their units with restrictive air flow. I buy the cheap brown ones by the case and change every 3-4 months
  24. Jun 27, 2018 at 7:57 PM
    #54
    PennSilverTaco
    Charlie
    2010 Zombie Truck
    In the meantime, did they just put the old thermostat back?
  25. Jun 27, 2018 at 8:23 PM
    #55
    TomC843
    Tom
    Charleston, SC
    give me a Copeland Scroll compressor and 1/3 1075 motors and I will be running trouble free as long as I got proper air flow and clean coils. Any elec component goes out hell I can hard wire around most of it and know I can get that single stage common compressor same day. But go with some thing like the Lennox RTUs at Outback with a Variable speed DC condenser fan motor then you have a full day out no ac during 95 degree days with next day air fee and a motor that my cost was $328 then customer has $1100 bill. so much for all that elec savings. 1/3 1075 motor job $350 max.
    My Goodman has copper coils, Copeland compressor, and non-china motor. Problem with budget friendly units is that is what gets slapped into the new built neighbor hoods by the lowest bidder that installs 5 a day. Under sized duct work and air/moisture in line sets, bad compressors in 1-3 years. Not the fault of the unit.
  26. Jun 27, 2018 at 8:28 PM
    #56
    PennSilverTaco
    Charlie
    2010 Zombie Truck
    The difference between Goodman and Amana is that Amana only sells to licensed contractors/installers. Goodman sells it's units to ANYBODY, typically people who are unqualified to install or even work on HVAC equipment.
  27. Jun 27, 2018 at 8:31 PM
    #57
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I went with Rheem and have been very happy with my unit
  28. Jun 27, 2018 at 8:39 PM
    #58
    TomC843
    Tom
    Charleston, SC
    ps- never be the first buyer of a tract home.
  29. Jun 27, 2018 at 8:50 PM
    #59
    TomC843
    Tom
    Charleston, SC
    What area do you live that your supply house is selling HVAC equipment to unlicensed people. Never seen equipment not sold on eBay sold too unlicensed guys. Thats why you cant buy it at Lowes, and hell call the EPA on the suppy house.
    #59
  30. Jun 27, 2018 at 8:56 PM
    #60
    PennSilverTaco
    Charlie
    2010 Zombie Truck
    :amen:
