Looking at a 2014 tundra
Discussion in '2.5 Gen Tundras (2014-2021)' started by paddyb15, Jan 9, 2019.
  1. Jan 9, 2019 at 9:01 AM
    paddyb15
    paddyb15 [OP] New Member
    Looking at a 14 tundra crew max. Never had a tundra but I know most that have them swear by them. Curious if I’m over paying at 25k for 55-70k miles. Any insight into longevity and durability would be greatly appreciated. Also common problems or things to look out for?
    Thanks,
    Paddy
    Rica25 and Metro14536 like this.
  2. Jan 9, 2019 at 9:10 AM
    Metro14536
    Metro14536 New Member
    Brandon
    Las Vegas, NV
    2021 Army Green SR5 CM TRDOR 4x4
    Ehh it should be decently reliable...you will probably only get about 600-750k miles before you run into a tiny problem that’ll cost $10 to fix
    15Yota, Tundraman479, Rica25 and 5 others like this.
  3. Jan 9, 2019 at 9:18 AM
    paddyb15
    Haha! Perfect.
  4. Jan 9, 2019 at 9:36 AM
    UTTundra
    UTTundra New Member
    Lou
    Utah
    I think most will probably suggest to inspect for the notorious cam tower leak.
    Rica25 likes this.
  5. Jan 9, 2019 at 9:41 AM
    Alexstundra
    Alexstundra Not a new member
    Northeast PA
    2016 MGM DC Trd
    Is it a 4x4. Sr5 or limited. Any accidents. Any warranty.
  6. Jan 9, 2019 at 9:41 AM
    Y0TA PR0
    Y0TA PR0 Dirt biking & fishing
    Rafael
    2017 TRD PRO
    WELCOME
  7. Jan 9, 2019 at 12:33 PM
    Crunch527
    Iowa
    TRD Supercharger/BAM
    I have a '14 CM 4x4...Supercharged since 6,700 miles and now has 65K miles...belt tensioner is the only thing I had to replace. Original brakes still on the truck.
    Mine is a Limited and as a general rule, the Tundra's aren't as "pimped" as the domestic trucks. Rather what you are getting with Toyota is a well apportioned vehicle that has unmatched reliability and resale.
    Oh the newer Toyotas don't rust like the Domestic trucks...so that could be a downer...;)
  8. Jan 9, 2019 at 12:47 PM
    BuckWallace
    BuckWallace Ball don't lie.
    Oregon
    Sierra 3500 AT4 Gasser
    Definitely check for the cam tower leak, or even if it's been repaired. Mine was "repaired" and developed another issue that still hasn't been resolved, so just be careful.
  9. Jan 9, 2019 at 1:12 PM
    bvia
    bvia New Member
    2013 Texas Edition Tundra 2WD 4.6 DblCab
    None
    Or create one by trying to replace all the interior lights with LEDs...*pop*!
    B
  10. Jan 9, 2019 at 1:24 PM
    Welcome from NY.
  11. Jan 9, 2019 at 2:09 PM
    paddyb15
    Thanks for all the help! One is an sr5 the other is limited. Not big on all the “pimped” features. Less is more with a truck imo. But all the same I’m trying to stay between the 50k and 80k miles on the truck when I purchase. So I’ll look for the cam tower leak/ repair and other than that hopefully it’ll be easy least from there. Cheers!
  12. Jan 9, 2019 at 2:13 PM
    BuckWallace
    Oregon
    I wouldn't 100% let the fact that it's had a cam tower repair scare you off, but just know it's had the engine opened up. Drive it kind of hard on the test drive and listen for any weird sounds. Good luck!
