Long crank when cold
Discussion in '1st Gen Tundras (2000-2006)' started by Chkahi808, Jan 19, 2023.
  1. Jan 26, 2023 at 11:30 PM
    Chkahi808
    Chkahi808 [OP] New Member
    Chey
    03 ac tundra 4x4
    Figured it out,fuel line connected to sending unit assembly locking tab is worn out and wasn’t on all the way so the system was leaking out over time and that’s the cause of the long cranks in the morning
  2. Jan 27, 2023 at 1:34 AM
    Aerindel
    Aerindel New Member
    Montana
    Great! Nothing like an easy answer.
  3. Jan 27, 2023 at 6:48 AM
    shifty` We call it “riding the gravy train”
    That's awesome news, so it basically was a pressure issue - line was draining off over time, so when starting up, the line needed to repressurize, which would happen as the engine was cranking, it just had to re-prime each time.
    And you weren't smelling any gas outside the truck?
    I'm not following exactly where the bad connection was, but I'm also curious what brought you to that spot to notice it wasn't fully inserted.
  4. Jan 27, 2023 at 12:42 PM
    Chkahi808
    Chey
    03 ac tundra 4x4
    The first week or so when everything started I didn’t smell gas but it eventually got worse and worse and then started leaking badly so I just traced it back up and then there it was
    shifty`[QUOTED] likes this.
