Locker down vault Console vault -14 Tundra CM
Discussion in '2.5 Gen Tundras (2014-2021)' started by Patriot, Aug 29, 2016.
  1. Aug 29, 2016 at 4:32 AM
    Patriot
    Patriot [OP] Member
    Western NC, “Boondocks”
    It's been awhile since I have posted, it's good to be back on this forum. As with most things in life the more you learn the better it gets. I am a very strong proponent of the freedom and right to bear arms. Being an avid shooter and Hunter, I decided to look around for a way to secure my firearm(s) pistols or revolvers in my 14 Tundra crewmax. Found this company in San Antonio called "Locker-down". Just a personal note; I conceal carry and don't subscribe to leaving a revolver or pistol just laying on my console or holstered somewhere in my cab. I always carry concealed on my person. If I need to make a hasty egress from my truck for whatever reason I want my pistol secured on me, not me looking for it somewhere in my cab. Surely gents to each his own.
    There are times when I may have to secure an important docs, iPad, CD's, additional weapon, ammo, binoc's, range finder etc in my cab. I found the locker-down vault to be the ticket for my needs. It's a very serious vault easy to install and heavy duty. Hope this helps anyone considering a nice vault. High quaility vault. Ordered and it was drop shipped in 4 days to my door. Considering the rifle locker down which installs under the rear seat. Made in USA. FWIW....
    A few pics of my 14 CM console and locker-down-
    A quick perfectly set spring loaded console door-
    Yes, Sig fan here and own a few, but in this pic my "BUG" G27.
    Cat3ILS, NewImprovedRon and r4z0r51o like this.
  2. Aug 29, 2016 at 4:39 AM
    r4z0r51o
    r4z0r51o have fallen off the forum, but I’m still alive.
    Dave
    Northeast San Francisco Bay Area
    2016 Silver Sky Metallic Crewmax 5.7L TRD 4x4
    22x12”HostileRage/33”NittoRidgeGrap/StealthFighter/FOX-BDS
    Love the hat! The Glock is okay :wink:
    Patriot[OP] likes this.
  3. Aug 29, 2016 at 5:27 AM
    How much room is inside the safe? Enough for ammo, pistol, owners manual, napkins, gloves etc?
  4. Aug 29, 2016 at 5:32 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    Ok I'll start with dumb question #1. Can you still access the 12v port in the console with this setup? I would assume they would make a hole for it but I cant seem to find a picture showing that...
  5. Aug 29, 2016 at 5:41 AM
    Patriot
    Patriot [OP] Member
    This vault is laser matched/measured to the fit console interior precisely. Even slotted for 12 vplug inside console. So essentially no loss of space. 10-15 min install tops, and bolts into the floor using (4) hardened longer bolts supplied with vault. It bolts directly into the OEM console floor. Remove OEM bolts add the longer hardened bolts supplied with vault.
    And Yes, enough room for all you mentioned and much more. I would buy again in a minute. A really tuff powder coated finish.
  6. Aug 29, 2016 at 5:42 AM
    Patriot
    Patriot [OP] Member
    Never a dumb question MotoTundra....Yes, I will take a photo and post up.
    MotoTundra[QUOTED] likes this.
  7. Aug 29, 2016 at 5:51 AM
    Patriot
    Patriot [OP] Member
    A small area cut out of the 12 volt access inside vault. Also a closer pic of the tuff well done powder coat finish. Word of caution, if you order, follow combo setting instructions very carefully. The instructions are crystal clear, but... If you accidentally lock the safe and don't have the combo set, you now own a heavy cold rolled steel empty vault. There is nothing they can do for you. The plus side is its not at all hard to set the combo. The instructions are easy to follow.
  8. Aug 29, 2016 at 5:55 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    Thanks! I have the same feelings about carrying. I don't drive my truck much, but sometimes I have to leave something important in the truck, and locking the glovebox doesn't give me the confidence this bad boy would.
    Patriot[QUOTED][OP] likes this.
  9. Aug 29, 2016 at 6:04 AM
    Patriot
    Patriot [OP] Member
    I have no affiliation with locker-down..learned about them in my former career, but like to pass it forward on a great product. They did give me 10% off being a retired LEO. I do not know if this is still available, never hurts to ask. Any other questions, glad to help. Also the combo lock is nice in that you click one number that only YOU know, and your in quickly as the spring loaded heavy steel door opens fast. You will be pleasantly surprised at how heavy this vault is, I was.
    www.lockerdown.com
    T-Rex266 and MotoTundra[QUOTED] like this.
  10. Aug 29, 2016 at 11:38 AM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    I have the same safe and it is awesome. I have the same lock you have too. I heard those are really easy to pick. So i am considering changing out to one of their key locks. I have the double cab so i also want their rear long gun safe. Looks even deeper then the stock plastic box.
    I modified the dividers on Amazon to fit my safe and i have it packed with all kinds of edc stuff.
  11. Aug 29, 2016 at 12:12 PM
    RussellVaughan
    RussellVaughan New Member
    Houston
    2015 Gray TSS 5.7 CM SR5 4x4
    AMP Research PowerSteps; Katzkin leather seats (Nightrunner, all black, no perf/logo); TRD 18" BBS Forged rims; Nitto Terra Grappler G2 LT295/70R18) tires; LT295/70R18 spare tire; Rough Country speedo calibrator; Fox 2.0 IFP front & rear w/1" leaf blocks; TRD PRO black headlamps w/Headlight Revolution harness; TRD PRO grill w/color match hood bulge; RCI engine skid plate; BakFlip MX4 tonneau; Baja Design Squadron Sport fog lights w/clear wide lens; front/rear color match bumper covers; K&N CAI; Pedal Commander throttle controller w-trailer brake bezel; SE Toyota wireless charger tray; VLEDS interior and exterior LED lights; AJT Designs interior chrome delete; Sparks Parts driver side grab handle kit; Pop&Lock tailgate lock; ICS Fab dash mount w/support plate; ICS Fab center console mount; SNS Custom Design ABS sensor guards; TRD PRO shift knob; Undercover Swingcase bed storage; Rad Rubber Design engine splash guards; Bull Ring bed rail tie-downs; exterior debadge w/black & engine badge and black 4x4 badge; Charvonia Design billet bed tie-down anchors; rear console USB port; TRD rear sway bar; Fumoto Oil Pan Valve; Toyota metal oil filter assembly; Vexing R1 dash cam; X2Power 24F Battery.
    nice safe. def considering. just a thought - can you set the combo before you install? just in case you mess up...at least it's not bricked in the truck.
  12. Aug 29, 2016 at 2:11 PM
    Patriot
    Patriot [OP] Member
    You should set the combo before install. If you follow the basic instructions it's super easy just take your time. You'll be fine.
  13. Aug 29, 2016 at 2:19 PM
    Patriot
    Patriot [OP] Member
    Yep, awesome vault as stated. Honestly I never heard or read anywhere that the combo was easy to pick. I know I will never loose the combo, keys sometimes they do get lost. And one flick of a certain number I am in my vault much faster than "Barney Fifing" a key ;). Just depends on how quick you want access.
    My main use is securing my "BUG" or multiple BUGS :cool: and anything I want secured.
    Cheers!
    SouthBoundSteve likes this.
  14. Aug 29, 2016 at 3:13 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Very impressive, thanks for the post
  15. Aug 29, 2016 at 3:20 PM
    Patriot
    Patriot [OP] Member
    Sure, glad to help.
  16. Oct 24, 2017 at 10:31 AM
    Dan Diego
    Dan Diego New Member
    San Diego, CA, USA
    2007 Double Cab 4x4 5.7l
    I'm looking at the different console safes available for the Gen 2. For those that've done it, do you prefer any brand? How about key/combo type? I will likely go with the LockerDown with a 4-digit combo.
    There are at least 5 options (that I've found).
    http://www.tuffyproducts.com/c-4-consoles.aspx
    http://www.consolevault.com/console-vault.html
    http://www.autosafes.net/
    www.lockerdown.com
    https://www.sparksparts.com/accesso...s-tundra-console-safe-00016-34174?parent=1325
    A co-worker has the Tuffy brand and says it really good, though he went to a locksmith and upgraded to a MEDECO brand lock rather than the tube style key that most keys systems come with.
    Thanks in advance.
  17. Oct 24, 2017 at 10:52 AM
    texasflyer
    texasflyer New Member
    2016 MGM Crewmax
    Magnuson S/C, BD Tuner, TRD Exhaust, TRD Rear Sway Bar, TRD Pro Grill, TRD Wheels, TRD Shift Knob, Escort Passport 9500ci Radar/Laser Detector, Retrofit Headlights (RX350 Projectors), Morimoto XB LED Fog Lights, Retrax Pro MX, Ceramic Tint, ESP Full Length Storage Box, Console Vault, Driver Side Grab Handle, WeatherTech Floor Liners, Diff Breather Mod, Color Matched Front End Bumpers, Color Matched Door Handles and Mirror Caps, Black TRD "Tundra" and "iForce" Badges, Removed chrome badges
    I had the console vault safe in both my 2nd gen and 3rd gen Tundra. No complaints. From what I understand, the locker down safe is very similar in design and construction and wouldn't hesitate to use their safe either.
    Personally, I would go with a combo lock in lieu of key. One less thing to look for in case opening the safe is time sensitive.
    Dan Diego likes this.
