Locked OUT after battery drain
Discussion in 'General Tundra Discussion' started by Rons66, May 11, 2016.
  1. May 11, 2016 at 1:47 PM
    Rons66
    Rons66 [OP] New Member
    Polished and waxed the Tundra and left in the garage for several days. When I went to get in,the door unlock via the fob did not work!
    Opened the door with the key and placed the key in the ignition switch and attempted to start the truck. No response, Dead battery - The overhead light had been left On. Released the hood and closed the door.
    Opened the hood and connected the battery charger On Start Cycle. Seconds later, the alarm sounded and the lights flashed. When I tried to open the door to reset the alarm, it was Locked- With the key in the ignition!
    Lights flashed and alarm sounded for several minutes,then stopped- Doors remained locked with the key in the ignition.
    Had to use another key to get in.
    Never thought you could lock thedoorswiththekey in the switch!
  2. May 11, 2016 at 2:20 PM
    Welcome!
    What year Tundra is this?
  3. May 11, 2016 at 2:32 PM
    15whtrd
    15whtrd Mr. Blonde
    Yeah I found out that if you leave the domelight on the alarm sounds every 10 or 15 minutes constantly. Instead of just the light shutting itself down after a period of time it would rather your alarm go off and piss everybody else off and drain your battery in the process.
    But I guess I'll take that over your situation. Quite a few of my previous vehicles the domelight would just shut itself off after a while.
    Eclipsed & Floating likes this.
  4. May 11, 2016 at 2:52 PM
    Ryan Mc.
    Ryan Mc. New Member
    Ryan
    Mission Viejo
    2015 Toyota Tundra SR5 Double Cab 5.7L
    Hand made bed divider, bed d-rings
    I accidentally hit my dome light the first night I brought it home. Alarm kept sounding every 10-15 min. It took me standing outside watching the truck for 30 minutes to figure it out. I almost thought someone kept hitting the truck (jealousy) and was running off before I could see. But Id rather it sound and wake me up/keep me wondering than to wake up with a paperweight sitting in my garage. Id say good call Toyota with that feature!! ;)
  5. May 11, 2016 at 3:09 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    I didn't know about the dome light/alarm thing. I need to try it because I'm curious ("like a cat, that's why they call me whiskers")...
    JC303, joonbug, Krezz and 1 other person like this.
  6. May 11, 2016 at 3:22 PM
    Ryan Mc.
    Ryan Mc. New Member
    Ryan
    Mission Viejo
    Just beware of curiosity.....it killed the....
    MotoTundra likes this.
  7. May 11, 2016 at 3:55 PM
    15whtrd
    15whtrd Mr. Blonde
    Yeah I didn't figure it out until the next day. I got so frustrated with it the first time it happened that I just unpluged the battery. I started thinking it was a hood sensor that went bad so I unplugged that to no avail. Well the next morning I found that my dome light was on. Had it happen a second time where I must've bumped the domelight on, went to school and almost 3 hours later I come out to find my truck alarm going off. It must've done it constantly while I was in there just slowly draining the battery. And I know how punk kids can be. An alarm is almost like an attractant to F with the vehicle.
    Personally I think it's a ridiculous feature it should just timeout!
  8. May 11, 2016 at 6:44 PM
    I discovered something the other week. I turned off the truck and removed the key from the ignition but it gave me a quick one beep tone...I couldn't figure it out..started checking the truck...I didn't close the sun roof all the way..it does this for all windows.
  9. May 12, 2016 at 3:04 PM
    Rons66
    Tundra is a 2008.
    I have had dead battery's before, but nothing like this.
  10. May 13, 2016 at 11:02 AM
    alalmcgrath
    alalmcgrath Old Fart at Large!
    Al
    Boulder Creek Ca
    2016 SEQUOIA SR5
    Ditto on my 2011!
  11. May 13, 2016 at 12:54 PM
    Could be a feature of the "limited" and up models.
  12. May 14, 2016 at 5:14 AM
    MT Madman
    MT Madman Just an ordinary guy
    Hawk Point MO
    2020 Silver Platinum
    TRD dual exhaust TRD Rear Sway Bar SnugTop Hi-Liner
    Happened to me with a '08 Suburban in the middle of winter in Montana, yeah it was flippin' cold out, it has something to do with the security system getting a sudden jolt of good ole 13.8 VDC. Had to call a guy to come out and let me in and from that point forward when I leave the truck running I'll either not close the door or leave the window down.
    NewImprovedRon likes this.
  13. Jun 4, 2017 at 6:58 PM
    Slvr&blk 43v3r
    Slvr&blk 43v3r New Member
    08 Slvr SR5 TRD
    cold air, Pioneer stereo, 10" sub, light bar, leveling kit, 20 " Fuel Kranks, fender flares and Tonneau cover
    Hello,
    Well i am new here but i am going thru the same issue. Feeling dumb :facepalm::facepalm: was afraid of someone taking stuff out of my tundra so i locked the doors for an over night charge of my battery. Now genius me can not open the doors nor hood to put battery back. Any ideals its an 08 sr5 tundra. Thanks in advance :amen:
  14. Jun 4, 2017 at 8:14 PM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    Welcome! If I'm understanding you right, the keys are in the ignition? If that's the case, there's no battery in the truck and you don't have a second set of keys you probably only have two choices. 1 call a lock smith or 2 go to your local Toyota dealer with your ID, proof of ownership and VIN and have a valet key made. I had one made for a 'just in case', it cost me $10 bucks.
    NewImprovedRon and 15whtrd like this.
  15. Jun 5, 2017 at 6:09 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    I usually make a spare and hide it somewhere underneath the truck. Use wire to secure it, not the magnetic hide a key. Those fall off.
    My wife's Camry has the smart key and it won't let you lock the key inside.
  16. Jun 5, 2017 at 4:35 PM
    Slvr&blk 43v3r
    08 Slvr SR5 TRD
    Hi,
    Thanks for the advice no i have the key but the doors will not unlock without the battery in. I have turned the key and nothing happens:(
  17. Jun 5, 2017 at 6:51 PM
    duece292
    Greg
    Green Bay, WI
    I'm stumped on that one. Using the key to unlock the door is a totally mechanical action, independent of anything electrical, so it shouldn't matter that the battery is out of the truck. Just grasping at straws here and not implying anything....you're turning the key the right direction to unlock? Maybe try lifting the handle slightly while turning the key.
  18. Jun 6, 2017 at 7:46 PM
    Slvr&blk 43v3r
    08 Slvr SR5 TRD
    :amen::amen:
    the great news we got in.. how thru the license plate light:thumbsup::thumbsup:
    Tacogrande likes this.
  19. Jun 6, 2017 at 8:21 PM
    duece292
    Greg
    Green Bay, WI
    Excellent!! Now, PLEASE, PLEASE, PLEASE enlighten me...how in the hell did you get in thru the license plate light? This is a trick that I need to know how to do!
  20. Jun 7, 2017 at 5:19 AM
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
  21. Jun 13, 2017 at 6:40 PM
    Slvr&blk 43v3r
    08 Slvr SR5 TRD
    Alright here it is we took the battery that was out of the truck, ground it to frame removed the bulb to the left side of license plate,we had two wires cut about 18" long stuck on to frame as a ground the second in where the bulb came out. Next its magic the other side lit up i pushed the unlock on my remote and that yota sound went i hit it twice all door open then just popped the hood battery in and she is growling once again:benchpress::bowdown::bowdown::bowdown:
  22. Jun 14, 2017 at 7:53 AM
    nammer
    nammer New Member
    Sarasota, Florida
    wow, that's pretty insane, now that you're in, i'd investigate why putting your key and turning doesn't unlock your truck, because it should with or without the battery in
  23. Jun 14, 2017 at 8:35 AM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    I have to ask how did you know to try that?
  24. Jun 16, 2017 at 11:57 AM
    alalmcgrath
    Al
    Boulder Creek Ca
    2016 SEQUOIA SR5
    Very ingenious!!!
    I'll have to remember that.
  25. Jun 16, 2017 at 5:32 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    12v is 12v. Doesn't matter where it gets into the system from.
  26. Jun 17, 2017 at 5:46 AM
    MT Madman
    Hawk Point MO
    Rowdy remember, door locked, hood release inside the cab.
  27. Jun 17, 2017 at 6:30 AM
    MT Madman
    Hawk Point MO
    Thought you'd get a kick outta that. Back when SNL was a good show.
    But it still does make you wonder about the key?!?!
  28. Jun 17, 2017 at 7:14 AM
    alalmcgrath
    Al
    Boulder Creek Ca
    2016 SEQUOIA SR5
    With the doors locked he couldn't open the hood to get to the battery.
  29. Jun 25, 2017 at 5:07 AM
    Slvr&blk 43v3r
    08 Slvr SR5 TRD
    My hood was closed and doors locked so i could not release the hood to place battery back in
