Loaded up for camping. Now we’re overweight.
Discussion in 'General Tundra Discussion' started by Terndrerrr, Jul 4, 2021.
  1. Jul 5, 2021 at 6:27 AM
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    It was a tough call on the F-250 and F-350. I did a ton of research and for what I needed the F-250 worked, and came in the configuration I wanted. If I was in the “Go Big or Go Home” mindset, I’d get a 1-ton diesel and possibly DRW. I agree with @ColoradoTJ - diesels are working trucks meant for big time towing. They’re expensive to buy and maintain.
    I needed a truck to haul more than a scoop of dirt and not worry about payload. I unknowingly hauled some dirt a while back way over payload. It was only a scoop which was a little over a yard of soil and I afterwards I got curious and did some research - way over payload with just a single scoop of dirt.
    Wallygator and ColoradoTJ like this.
  2. Jul 5, 2021 at 6:31 AM
    BayRunner
    2017 Tundra Platinum
    Nope, A company the size of Toyota, this is just crumbs off the table.
    Wallygator, Cpl_Punishment and Hbjeff like this.
  3. Jul 5, 2021 at 6:32 AM
    18" TRD Off Road Wheels
    Yup. Half ton trucks aren't super work horses, and the Tundra is operating off needs/standards fron over a decade ago. It's definitely behind the times on payload, but I'm not sure an F150 would have done much better with dirt. If I need to move dirt it'll be rarely, and I know people with a dump trailer and a diesel. :burp:
    Wallygator, Black Wolf and ColoradoTJ like this.
  4. Jul 5, 2021 at 9:31 AM
    Bammer
    Bammer I'm disinclined to acquiesce your request.
    Monroe, CT
    2019 Tundra SR5 TRD Crew Max 4x4
    My 07 LBZ Duramax was my daily driver. It's still on the road with over 200k. Oil changes, fuel filters, brakes and normal maint and wear items. Not counting the 2000 electrical work when mice ate wires and cooked my ECM. 15 ish round town, 18 -20 on the highway ( unloaded). Haul or pull anything you could throw at it. The best truck I've had to date( don't get me wrong, I love the Tundra). I didn't need a diesel, but I wanted one. If you want payload and pulling power, diesel is the only way to go, and it didn't kill me to use it as an every day vehicle.
    AircareTundra likes this.
  5. Jul 5, 2021 at 10:16 AM
    That is a pre-emissions/DPF/SCR truck.
    Try that with a modern diesel and you will regret it.
  6. Jul 5, 2021 at 10:28 AM
    jordoncloutier
    jordoncloutier New Member
    Jordon
    Alberta , Canada
    2019 Tundra CrewMax SR5 Plus 4x4
    Daily Driver / Tow Vehicle , Retrofitted Trans Cooler , 10 Ply tires , Raptor Lined Ranch Hand Grille Guard
    Nice move on making 3k profit but you just threw out the long-term reliability by switching to a domestic 3/4 ton IMO ..
    I'm in the same situation with my 19' Cm , but I will not sacrifice the reliability by trading off my tundra for a domestic , this is the entire reason I switched to Toyota , owned multiple ford ,Gm and Ram in the past 10-15 yrs , all of them had their share of major issues and ended up being money pits. A few of my buddies own older 2007 - 2010 tundra with over 300k on them with minimal cost , zero drivetrain problems , just maintenance and fluids .
    When I tow my camper , I'm aware that I'm most likely over payload by a few hundred pounds , it doesn't worry me . I believe Toyota is underrating these trucks with their payload #'s
    AircareTundra and AggiePhil like this.
  7. Jul 5, 2021 at 10:58 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I love how everyone with internet access, a Tundra and a heavy trailer is somehow smarter than the engineers working for the largest automotive company in the world.
  8. Jul 5, 2021 at 11:33 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    imagine a marketing department with this pitch to the boardroom:
    “Guys, here is our idea, let’s intentionally advertise less capability than our competitors”
  9. Jul 5, 2021 at 12:46 PM
    AggiePhil
    AggiePhil Texas Chapter President
    College Station, TX
    2020 Smoked Mesquite Platinum 4x4
    What are the primary concerns about an overweight Tundra? If suspension sag, can this be overcome with upgraded leaf springs? If braking distance, can this be overcome with upgraded brake pads and lines?
    Terndrerrr[OP] and AircareTundra like this.
  10. Jul 5, 2021 at 1:27 PM
    glowblue
    VA
    No argument on the reliability.l, that is surely a difference maker. I wasn’t going to be a few hundred pounds over, I was going to be way over towing and the Tundra just wasn’t going to cut it. It’s dangerous and not safe.
  11. Jul 5, 2021 at 1:31 PM
    glowblue
    VA
    This is true. If anyone thinks the Tundra can haul/tow way more than what it’s rated for safely, they should ask why then Toyota wouldn’t just up the posted weights to be more competitive?
    My F-250 has a 3120 LB rated payload. Using the Tundra way of thinking I surely could load 5,000+ pounds and be just fine.
    Cpl_Punishment likes this.
  12. Jul 6, 2021 at 11:43 AM
    Terndrerrr
    Terndrerrr [OP] 923000 miles to go
    Music City
    6UR-FE
    Out West, I’ve seen a million tundras with bumpers, sliders, tents, and presumably armor underneath. Even more Tacomas. There’s no way all of those trucks aren’t grossly overweight. I mean, I’m overweight and you’d have no idea because it's all in the cab and under my retractable cover.
    To be honest, I can’t believe how well this big fat pig did on some of the trails and access roads.
  13. Jul 6, 2021 at 11:56 AM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
  14. Jul 6, 2021 at 11:58 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Helper spring, don’t make ur rig tow and haul more
    jordoncloutier likes this.
  15. Jul 6, 2021 at 12:26 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    There are so many expo tacoma rigs driving around loaded with armor/look cool instagram gear/ camping accessories. They have to be far over payload
  16. Jul 9, 2021 at 12:06 AM
    OnespeedTRD
    OnespeedTRD New Member
    Don
    San Diego
    2020 Tundra Limited TRD Off-Road
    275/70r18 Cooper AT3 XLT on SCS Ray 10s, Eibach Coilovers, DD 12" Exhaust, AJT Blackout Kit, Truxedo Pro X15, paint match/chrome delete.
    I just did a road trip/move from the PNW to SD last week. Fully loaded I weighed in at 6980lbs, w/ full tank but w/o passengers.
    So add another 475-500ish for two adults and two dogs. Meaning I was travelling right at 7500lbs. The unloaded weight after the trip was 6060lbs, so I was carrying 920lbs of stuff, plus myself, my wife and the dogs, so call it 1450lbs of payload.
    No sag and no weirdness, although the truck didn't like some of the larger/steeper mountain passes.
    Averaged 15.7mpg over 2500 miles with lots of stop and go, lots of hills, some trails, and too much idling (it was super hot and we had dogs), which is better than I was expecting.
    For reference this is what I was carrying:
    On the truck:
    Valhalla's front and rear cat plates, oversized AT tires, spray in bedliner, and a Softopper
    For the trip:
    Queen Ikea mattress
    Truck tent for Softopper
    All of our camping gear in two Pelican cases
    EZ Up and two folding chairs
    65qt Cooler
    Tool box
    Plywood dog platform for the back seat
    Rockymounts hitch mount and two mountain bikes
    Plus a bunch of stuff I wouldn't normally take camping, but since we were moving it had to come along, ie a shotgun, a rifle and three pistols, plus a bunch of ammo, another Pelican case with a full computer setup and extra cloths, valuables, etc, and a bunch of other odds and ends that were stuffed anywhere I could fit them.
    I guess this is all to say I don't see how anyone is packing that much stuff for just a simple camping trip.
    If I was not moving and just going camping I could have easily shed about 4-500lbs, maybe more, leaving me plenty of room on my payload cap. If I were pulling a trailer a lot of that stuff would be inside, further reducing the payload on the truck.
    I think a lot is being made of the Tundra's low payload capacity, but for normal 1/2 ton use I just don't see how you'd need so much stuff with you that you go over the GVWR. Maybe watch an episode of Tiny Homes and then lay all your stuff out on the driveway and go through it and see if you really need all that stuff with you on a camping trip. My guess is you could easily shed some weight and be just fine.
    If you're planning to pull a boat or trailer then as long as the tow itself is not a huge pig you should be able to put most of that stuff in the trailer and have room to spare on both the payload and combined weights.
  17. Jul 9, 2021 at 3:26 AM
    Bammer
    Monroe, CT
    Very true, and the LBZ was the best diesel ever made IMHO. If the winter salt didn't do its damage, no matter how hard I tried to stop it, I would still have it now. I look out my window and see it in my neighbors driveway, she's still pulling a mini -excavator and his toy hauler !
  18. Jul 9, 2021 at 4:27 AM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    Hopefully not the same engineers who deleted Dual HVAC Controls, Lighted Ignition Rings, Amber Flashers/Signals, Dual Glove Boxes, Sliding Consoles, Transmission Coolers,Lights In Door Bottoms,Storage in Crewmax and Driver's Side Grab Handles on SR5 models!:D
  19. Jul 9, 2021 at 5:07 AM
    #49
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    The reality is that it is not really overweight. There are so many safety factors built into the suspension, axles, frame etc. that you can safely load a lot more than what is advertised.
    There are however 1. lawyers involved, and 2. the Tundra is a light duty truck. Everyone saying they should upgrade the payload, should realize that though it is possible, it will put it in 3/4 or 1 ton classification and that is not what most Tundra owners want.
    Also, the rest of the world have Hilux (Tacoma sized), Nissan Frontier, Isuzu etc. that are 1-ton trucks. I grew up on a ranch in South Africa and we loaded 1.5 tons on those Hiluxes all the time. Everything under the Tundra is beafier than a Hilux, so there is no way that loading camping gear and a family is "really" putting it over the limit. By that I am not suggesting that you should load it up all the time since technically it would be illegal to do so, but it is more on paper than it is a technical thing.
    pickeledpigsfeet and Wallygator like this.
  20. Jul 9, 2021 at 5:09 AM
    #50
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Most of those sound like accounting decisions, rather than engineering decisions and, other than the transmission cooler, don't have anything to do with the capability of the truck (other than making it lighter to increase payload :thumbsup:).
    Wallygator likes this.
  21. Jul 9, 2021 at 5:34 AM
    #51
    Totally agree. One of my best friends that lives in TX has a 07 LBZ CC SB truck with 45k miles on it. I offer to buy it from him monthly. He laughs and politely declines.
    Wallygator and Cpl_Punishment like this.
  22. Jul 9, 2021 at 5:34 AM
    #52
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    Being over payload and / or towing capacity MIGHT be “safe” and the truck may be perfectly capable. However, should something happen on the road and there is an accident, there isn’t a lawyer in the world who couldn’t prove some type of fault by the operator regardless of situation. The advertised towing and payload capacities protect the truck manufacturer from being held accountable for any type of functional failures and place them strictly on the operator. In legal terms they probably DO underestimate the totals but it is actually to protect them AND the owner of the truck.
    When I insured my camper, the company stated in a disclaimer that it would only be applicable if towed within recommended specs of the tow vehicle……
  23. Jul 9, 2021 at 5:38 AM
    #53
    BrakeDust
    BrakeDust New Member
    Hill Country, TX
    2021 CM SR5 4x4 Magnetic
    Indeed. Some minivans (eg. Toyota Sienna) have more 'payload' capacity than a Tundra.
    Yet try putting a few bags of mulch in that minivan and then talk to me about how the vehicle handles - the thing is almost scraping the pavement. 1300 lbs in a Sienna vs 1300 in a Tundra is like night & day.
    Boerseun[QUOTED] likes this.
  24. Jul 9, 2021 at 5:42 AM
    #54
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    THIS! You aren't the only one on the road or even in your truck. Don't drive over the limits, it's selfish, ignorant, unsafe and illegal.
    Most here don't seem to care or think like this though. They buy a trailer that's too big or a truck that can't tow/haul enough and drive it anyways.
  25. Jul 9, 2021 at 5:51 AM
    #55
    shawn474
    MoCo, Maryland
    I don’t quite understand the people who will pay thousands of dollars in mods / upgrades to equip a half ton truck to tow a trailer that is too large or exceeds weight capacities. They put air bags, compressors, heavy duty leaf springs, heavy duty shocks, better tires, etc……..when all that money could have put them in a 3/4 ton truck that would safely tow the trailer they wanted. Sure it won’t be a Toyota but it would be much safer……
  26. Jul 9, 2021 at 6:03 AM
    #56
    SnrDisregardo
    SnrDisregardo New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
    TRD Sport Suspension, TRD Front & Rear Sway bar, TRD Pro Shift knob, Charcoal Filter Delete, aFe Pro Dry S w/SABM, LineX bed, Remote Start, OEM tonneau cover, DIY pop'n lock, DIY TRD cold air intake, TRD skid plate, DD SS3 amber fogs, HotShot Offroad Hot Tails, 2020 OE radio with tech12v amp and sub.
    I would add to this by investing in using a good diesel treatment every time you fuel. I have customer that have had zero issues after putting them on a additive regiment and blows my mind that the companies other terminals haven't adopted the same. Depending on which one you go with, it only adds pennies to your fuel cost, but can save you thousands down the road.
  27. Jul 9, 2021 at 6:17 AM
    #57
    Absolutely. I run Howes every fuel up. One once per 5 gallons.
  28. Jul 9, 2021 at 6:25 AM
    #58
    Howes is an auto include for any diesel IMO.
  29. Jul 9, 2021 at 7:13 AM
    #59
    CMB
    CMB New Member
    Cecil County MD.
    Absolutely true. Nothing to do with the truck's capability but plenty to do with too much power given to Toyota's beancounters, especially when the "big 3" increase features every year, without making phony "safety reason" excuses, like Toyota did for deleting the driver's side grab handle.
  30. Jul 9, 2021 at 7:27 AM
    #60
    glowblue
    VA
    Exactly! I just hauled about a 1,000 lbs of “stuff” in my F250 and it didn’t even flinch. My Tundra would have sagged a couple inches. At least on this trip I didn’t break down either.
