Lit up like a Christmas Tree
Discussion in '2nd Gen Tundras (2007-2013)' started by LibertySand, Jan 14, 2017.
  1. Jan 14, 2017 at 5:24 PM
    LibertySand
    LibertySand [OP] IH Support Rig
    Montclair, CA
    07 TRD DC 5.7 Tow 4X4
    Problem:
    4Lo, VSC, Tractin Control and Check Engibe light all on. 4Lo blinking.
    Guys. I need help. Just drove 50 miles. Dropped off father in law at his shop and drove away. Before the first stop sign, the trucks instrument panel lit up like a Christmas tree. 4Lo, VSC, Tractin Control and Check Engibe light all on. 4Lo blinking.
    Did a sensor go out? Fuse? I searched and found nothing here. I also Googled, maybe it's a wheel sensor, ABS?
  2. Jan 14, 2017 at 5:31 PM
    99% sounds like AIP
    MotoTundra and zcarpenter92 like this.
  3. Jan 14, 2017 at 5:33 PM
    LibertySand
    Montclair, CA
    No limp mode yet. I have driven it serval times now. Home. Store. Home. Now another store.
    This all occurred an hour ago.
  4. Jan 14, 2017 at 5:36 PM
    LibertySand
    Montclair, CA
    How does all those lights say AIP? So not ascosiated with drivetrain then?
    What can I do in the meantime right now?
  5. Jan 14, 2017 at 6:26 PM
    LibertySand
    Montclair, CA
    What pisses me off more is that yesterday I had the dealership do the Trans and Oil change. I never go there. Never trust them. I typically do the oils myself but this is my first Tundra that I bought privately and decided to do a service with a Toyota dealership.
  6. Jan 14, 2017 at 6:47 PM
    LibertySand
    Montclair, CA
  7. Jan 15, 2017 at 8:37 AM
    LibertySand
    Montclair, CA
    So last night I unhooked the battery. This morning, plugged it back in. No more Lit Christmas Tree. Drove it for a few, nothing above 50. So far, so good.
    Still need to resolve this. I read somewhere there is a bypass kit for this problem with the AIP. Anyone?
    Tundraplatinum and joonbug like this.
  8. Jan 15, 2017 at 8:38 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    @Nor7 did it I believe.
  9. Jan 15, 2017 at 9:15 AM
    LibertySand
    Montclair, CA
    Found this video, boy am I looking at a long weekend to fix this, if this truly is the problem.
  10. Jan 15, 2017 at 9:22 AM
    Motor71
    Motor71 teufel hunden
    Rob
    New Jersey
    2016 tundra platinum
    TRD sway bar, matching mirror cover, 20% tint, esp aluminum box, Line-X premium, Undercover Flex tonneau cover, led interior lights, winjet smoked tail lights. Road armor rear bumper w/ road armor shackles, go rhino front bumper.
    The screeching in the background.....omg.
    thumper7799 likes this.
  11. Jan 15, 2017 at 12:37 PM
    LibertySand
    Montclair, CA
    Was able to pull codes today.
  12. Jan 15, 2017 at 1:53 PM
    sc134
    sc134 O.P.S.
    2017 Tundra PreRunner
    Front 2.5 Fox Factory Extended Length Coilovers, Total Chaos Upper Control Arms, Swapped projector Headlights, Tint, Dual Carven Exhaust
  13. Jan 15, 2017 at 6:38 PM
    Nor7
    Nor7 Chilton Manual Guy
    2007 Tundra Limited CM, 5.7L
    Sounds like air injection system. That sucks, don't know if you're covered, they extended the warranty for that system to 10yr/150k miles so not sure if your 2007 fits into it since it's now 10 years old.
    I did do a write up. Go to the mods/tutorials tab and click on the first one, then it should be listed at the bottom of the first post.
  14. Jan 15, 2017 at 8:31 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    https://www.tundras.com/threads/diy-aip-timing-valve-replacement-write-up.6282/
  15. Jan 15, 2017 at 8:47 PM
    ToyotaTundraMike
    2015 Tundra
    Yea there is a bypass kit. Learned about it when I was researching this problem on my 1st gen. I would save some $$ and start there. Why fix something that the truck doesnt even need? Pretty sure all it does is help with emissions during a cold start.
    NewImprovedRon likes this.
  16. Jan 16, 2017 at 9:35 AM
    LibertySand
    Montclair, CA
    Ok, so here's an update.
    Saturday- Truck Lights up like a Christmas tree. All symptoms pointed towards the AIP issue. Friday night, unplugged the battery.
    Sunday- Plugged the battery back in and all the Warning Lights were cleared. Drove around, still good. Then Drove on the freeway and Engine light comes on. Only the Engine light though. Later on, borrowed an OB2 reader and I get 4 Codes. P0101, P0171, P0174, P0101. I get home and those codes say on the lines, Mix to Lean. I don't truck the truck, leave the battery alone.
    Monday- I start the truck up, No Engine light on. I drive to work. No Engine Light. I push the truck hard for a bit (80/90mph) no Engine light on. I am Confused.
    Also, leaving this Link here for future reference. http://hewitt-tech.com/store/ Just in case I need to do the By Pass Kit. Which I might just do anyways for preventive maintenance ;)
  17. Jan 16, 2017 at 9:55 AM
    zlaneb
    zlaneb New Member
    Austin, TX
    @LibertySand I had similar problem on my 2011 - Lit up like a Christmas tree. Turned out a Rat had chewed up some of the main harness. We tried to put it back together, but ultimately did a new main harness At the cost of about $700 installed. Find any rat turds under you hood?
  18. Jan 16, 2017 at 10:15 AM
    LibertySand
    Montclair, CA
    No, all clean. I had the truck in at the Dealer the Friday before this weekend when all this mess took place. They also did a "Toyota 100 point Inspection". They added some water to my Windshield Tank. Checked my Brakes and told me the pads are low. Which by the way they measured the thickness of the pads. Not sure how they did that with the wheels still on. And the best part was they took air out of the tires to 36psi because thats what the Stock conditions are, yet the tires are 35" BFG's rated E and need 65 psi.
    So maybe through their 100 point inspection they rubbed my truck the wrong way and she didnt like being touched like that? Who knows.
    NewImprovedRon and thumper7799 like this.
  19. Jan 17, 2017 at 2:18 PM
    Alters1did
    Alters1did New Member
    Jesus
    08 tundra sr5 dblcab 4x4
    Airaid intake
    Its your mass air flow sensor. Mine lit up like a tree the same way on he freeway. I panicked and took it to my budy that works at avondale toyota. He pulled codes and it was that. Probably will happen again after it does the cycle. It went away right away after install
  20. Jan 17, 2017 at 4:42 PM
    LibertySand
    Montclair, CA
    I'll have to stop by AutoZone on the way home and grab some Mass Flow Sensor Cleaner.
  21. Jan 17, 2017 at 4:52 PM
    Alters1did
    Jesus
    Airaid intake
    Ive tried that but it did not work on the last truck i had. But its only 5 bucks.
  22. Jan 17, 2017 at 5:38 PM
    10 years depending on the month. I've got until June before 10 yrs. I won't bother knocking on wood.
  23. Jan 17, 2017 at 9:22 PM
    TundraTRD504
    TundraTRD504 New Member
    Bob
    TRD Supercharger, Fuel wheels, TRD Exhaust, TRD sway bar, Rigid fog light upgrade, Bakflip rigid Box cover, complete audio upgrade, Bilstein 5100 shocks, ARE cap, tow mirrors, Air bags
    I was towing my RV into Anaheim and hit a small canyon sized pothole in the road in the dark. Truck was fine except dash lit up just like yours. I got to my campsite in Disney and opened the hood in the AM to find the air tube connected to the throttle body bounced off. Turns out it is the mass air sensor reading a problem sending the dash lights into a flurry. Disconnected battery for 5 mins after fastening air intake tube and problem gone. I expect your mass air sensor is done and needs to be replaced.
  24. Jan 17, 2017 at 9:40 PM
    rons23 and joonbug like this.
  25. Jan 18, 2017 at 5:51 AM
    Alters1did
    Jesus
    Airaid intake
    Ha ha ha yes sean266.. Were you ableto clean out the sensor??
  26. Jan 19, 2017 at 9:39 AM
    Lupe
    Lupe New Member
    Lupe
    2006 Tundra
    I had these pop up and i just called toyota and dropped off at toyota for the AIP Recall. 10/150k. My truck is an 07 with 87k 20161231_112317.jpg 20161231_112330.jpg
  27. Jan 19, 2017 at 9:51 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Phewwww..... just in the nick of time Lupe.
  28. Jan 19, 2017 at 10:09 AM
    LibertySand
    Montclair, CA
    Can't be any further than the truth how I feel right there. The entire time, Every time I am driving the truck since all this has happened my brain won't stop going over WHAT THA FAWK HAPPENED!
    Havent cleaned it yet nor has the Engine Light turned back on.
  29. Jan 20, 2017 at 7:05 AM
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
    You have a "soft-code" that will intermittently appears and go away. After a few cycles, the code may clear itself from the ECU. it could be as simple as a plug-pin rattling out of position when you hit a bump then up pops the code,or the entire unit slowly going bad.
    just me, .... the DIY link is a straight write up. Do an EBAY search if you can find that OEM part cheaper than stealership. the fix seems relatively simple. Do the fix. Don't wait then you ready for a trip and you are stranded $%%$##^%$ all the way on a tow truck.
    And oh, nice color---- bought my 08 same color less than 30 days now.
  30. Jan 20, 2017 at 7:12 AM
    Alters1did
    Jesus
    Airaid intake
    So much yes..
