LineX questions
Discussion in '2.5 Gen Tundras (2014-2021)' started by Darren509, Jun 9, 2018.
  1. Jun 19, 2018 at 6:35 PM
    Ike74
    Ike74 New Member
    Anthony
    Sugar Land, TX
    2020 Kia Forte
    Products like Line-X are sprayed hot and are harder than the store bought stuff. This process creates a better seal and a tougher longer lasting product
  2. Jun 19, 2018 at 7:39 PM
    Travo60
    Travo60 New Member
    Travis
    Austin, TX
    2018 Limited CM Cement
    15whtrd[QUOTED] likes this.
  3. Jun 19, 2018 at 7:52 PM
    15whtrd
    15whtrd Mr. Blonde
    That is courtesy of @Roman A member here. As far as I know there are only two vendors for OEM Toyota parts here. He is the one I use. If you compare his prices to the dealer it’s crazy.
    I want to say there is a forum discount as well I just can’t remember it at the moment. Like Forum20 or Tundras20
    Roman likes this.
  4. Jul 5, 2018 at 6:13 PM
    Darren509
    Darren509 [OP] New Member
    Darren
    Dayton NV
    2016 White Tundra TRD
    Got it sprayed today. Had them remove the bed bolts but they stripped out and cross threaded 3 or 4 bolts that mount my bed rail sliders. They clearly used an air tool with the wrong size torx bit.
  5. Jul 5, 2018 at 6:35 PM
    InfernoToyo
    InfernoToyo New Member
    Barty
    Inland Empire
    2018 Inferno Limited
    Are they going to fix this?
  6. Jul 5, 2018 at 7:00 PM
    Darren509
    Darren
    Dayton NV
    They told me to bring it back tomorrow and see if they have any bolts or order me some. Im goingvto need a tap also !
  7. Jul 5, 2018 at 7:05 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    My bed’s bolts are sprayed. I’ve had minor difficulty bolting flag holders into the bolt holes where the rail system goes due to the liner spray.
    My tailgate’s screws aren't sprayed :confused:
  8. Jul 15, 2018 at 9:57 PM
    Silv333
    Silv333 Patriot
    NJ-NC-MD-NC
    2018 Cement Crewmax TRD Off Road
    You end up doing yours yourself? Pics please!
  9. Jul 16, 2018 at 6:23 AM
    Professional Hand Model
    Hand Protectors
    My 02’ came with a plastic bed liner. I’ve enjoyed it with no problems. If I purchased a new truck, then I’d get another plastic liner as it suits my needs (washes off easily, allows heavy items to slide in, and has an element of padding).
    The spray in looks good. My post above you quoted was in regards to how easy doing a spray in liner is along with the low cost of readily available spray liner product at the big box stores. So many here on this forum do the plasti-dips (which is extremely tedious/time comsuming compared to taping off a bed and spraying). Not sure why they do not do the spray in themselves. The big box spray in cans product is very good IMO as I’ve used it myself on other exterior items.
  10. Jul 16, 2018 at 9:43 AM
    Baldmonkey22
    Baldmonkey22 New Member
    Quartz Hill, Ca
    I dont think you realize that Line X when applied is about 1/8" thick and weighs 50 to 90 pounds. your suggestion of grabbing 5 cans at 7 dollars each wouldn't add up to more than a pound or so of product
  11. Jul 16, 2018 at 1:01 PM
    Hand Protectors
    And it doesn’t cost $500+ dollars either (line x cost from memory?).
    Not dying on a hill on this, but whatever floats your boat.
  12. Jul 16, 2018 at 1:20 PM
    Baldmonkey22
    Quartz Hill, Ca
    right but you are saying for 35 bucks you can do the same thing which is far from true, the finished product wouldn't even be comparable.
    NewImprovedRon likes this.
  13. Jul 16, 2018 at 1:30 PM
    Hand Protectors
    Like I said, I would do a bed liner over any ‘spray in’ liner. If its Line-x (1/8” thick per your comment) or (big box spray in 1/16”) if you throw a piece of nail embedded wood or drywall it will scratch. Heavier items will dent your bed for sure.
    I never said you could do the ‘same for $35’, but I did offer a low cost solution/alternative which will work very well. Spray can scratches can be touched up at home too. Line-x make an appt? Again, I could care less about spray in liners. Its your money and do with it what you want.
  14. Jul 16, 2018 at 4:06 PM
    Baldmonkey22
    Quartz Hill, Ca
    Got it.
    I had a drop in liner in my last truck and liked it for the reasons you stated except for how things slid around. My tundra only came with a bed mat so that combined with the line x seems like a pretty good trade off other than being twice the cost.
