Liner, bedrug, or nothing?
Discussion in 'Tonneau Covers, Caps and Shells' started by caz41, Oct 25, 2017.
  1. Dec 31, 2017 at 3:40 PM
    757TUNDRA
    757TUNDRA Not a New Member
    Illinois
    2018 Barcelona Red Metallic Platinum 4x4
    OEM Bed Cover, OEM Bed Rail System, OEM Bedmat, OEM Doorsill Protectors, OEM TRD Rear Sway Bar, OEM Color Matched Door Handles, OEM Color Matched Mirror Caps, OEM Bed Net, OEM Driver Side Grab Handle, BFG K02 LT275/60/20, WeatherTech Digifit FloorLiners, Salex OCD Console Organizer, Salex Console Tray
    @eccracer104 may be able to help you out ... he works for AutoAnything. Send him a PM and I'm sure he'll get back to you.
  2. Dec 31, 2017 at 3:54 PM
    THIS^^^^
    eccracer104 and TXDrifter like this.
  3. Dec 31, 2017 at 8:39 PM
    eccracer104
    eccracer104 Dirty Paws Off-Road
    San Diego, CA
    2011 Tundra 5.7 4x4 CM
    Thanks guys! :cheers:
    @TXDrifter I'll be back at work Tuesday and can look up your price. Just shoot me a PM please :thumbsup:
  4. Jan 5, 2018 at 2:34 PM
    TXDrifter
    TXDrifter BlueGrass Crew
    Jeff
    Louisville, KY
    2017 Tundra MGM DC
  5. Jan 11, 2018 at 7:10 PM
    TXDrifter
    Jeff
    Louisville, KY
    2017 Tundra MGM DC
    Finally installed the bedrug and I noticed when I remove the tie downs they leave a a bare metal spot where they were screwed in. What is the best way to take care of these spots so i don't get rust?
    Thanks
  6. Jan 11, 2018 at 7:13 PM
    Cuzican
    Cuzican New Member
    Louisiana
    2017 Black Platinum Crewmax Tundra
    8" Lift, 22x10 Fuel Forged FF19, 37x13.50r22 Trail Grapplers, Amp Research steps, Spyder black smoked headlights with 35w HID's, all interior lights LED, Undercover tonneau.
    My bedrug had slits in it for the tie downs to come through instead of removing them.
  7. Jan 12, 2018 at 7:33 AM
    eccracer104
    San Diego, CA
    ^ This. If it isn't precut you can cut a small opening in the bedrug to allow those tie downs to poke through.
  8. Jan 12, 2018 at 7:53 AM
    TXDrifter
    Jeff
    Louisville, KY
    2017 Tundra MGM DC
    Well, it's a bit late. I have already removed the tie downs as per the instructions so cutting small opening is not an option now. Even if i put them back there will areas that are still bare and still prone to rust. I am leaning on getting touch up paint and covering the bare spots but not entirely sure if that will do the trick of keeping moisture out..
  9. Jan 12, 2018 at 8:10 AM
    eccracer104
    San Diego, CA
    Painting over the bare metal will definitely help.
  10. Jan 12, 2018 at 9:06 AM
    TXDrifter
    Jeff
    Louisville, KY
    2017 Tundra MGM DC
    Will do!
    Thank You
