Line-x undercarriage - to do or not to do
Discussion in 'General Tundra Discussion' started by TundraNC, Aug 13, 2021.
  1. Aug 19, 2021 at 7:51 AM
    TundraNC
    TundraNC [OP] New Member
    Joel
    North Carolina
    18 Tundra Limited 4x4 SW
    I will definitely look into the CRC and Amsoil now though. Had not heard of these before now so thanks for the info
    OHwendTrd likes this.
  2. Aug 19, 2021 at 8:02 AM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    Neither did I and the options are endless, have to get what works best for you. Even from the start I got full support from the wife on buying a brand new truck, whatever I really wanted within reason. With months of research, test driving and past experiences is why I chose the Tundra. It worked best for me.
    Happy coating.
  3. Aug 19, 2021 at 8:09 AM
    mech_engineer09
    mech_engineer09 Tundra Enthusiast
    Ohio/Pennsylvania
    2020 MGM Platinum
    Ceramic Pro, XPEL Ultimate Plus, Woolwax Undercoating, Diamondback HD, TRD Air Intake, TRD Skid Plate, TRD Front & Rear Sway Bar
    use woolwax. it stays on year after year with only minor areas that need a touchup like high wash areas and they make a high viscosity version now that is very viscous. ill link my write up one second. I would actually do the woolwax now before it starts getting even slightly cold. much easier to apply and it gets a nice dirt layer over the top which protects it even more in the winter and doesn't allow the salt/nasty shit to cling to the outer layer
  4. Aug 19, 2021 at 8:12 AM
    mech_engineer09
    Ohio/Pennsylvania
    2020 MGM Platinum
  5. Aug 22, 2021 at 7:00 AM
    clarkritchie
    clarkritchie New Member
    No. I cannot fathom doing repair work or any modifications on a vehicle with Line X on its underside. But then, I've never dealt with salt and corrosion. Line X just seems like a bad idea to me.
    TundraNC[OP] likes this.
