Line-X repair
Discussion in 'Detailing' started by Tundra234, May 28, 2019.
  1. May 28, 2019 at 8:54 AM
    Tundra234 [OP] New Member
    So when my bumper was removed for Line-X, it was given to the shop in separate pieces. They put the step pads on before they sprayed it, so it had to be cut before it could be reinstalled. Now you can see some chrome. What would you guys do for a "blend" or repair. The shop looked lost when I asked them about it.
  2. May 28, 2019 at 8:57 AM
    Ask them for some Line-X and fill the chrome area with a toothpick.
    Was that crack there on the right side?
  3. May 28, 2019 at 9:25 AM
    That is part of where it started to peel after it was cut...drives me nuts!!
  4. May 28, 2019 at 9:43 AM
    They need to make this right!
    Maybe you should call Line-X directly and complain that this shop is doing bad work.
    LINE-X CORPORATE OFFICE:
    301 James Record Rd, Ste 250
    Huntsville, AL 35824
    Ph: 877-330-1331
    Darkness likes this.
  5. May 28, 2019 at 10:53 AM
    SoCalPaul
    SoCalPaul New Member
    Paul
    San Fernando Valley, CA
    2006 Tundra Access Cab Limited 4wd.
    Front Bilstein 6112 shocks & Bilstein springs. Rear Bilstein 5160 remote Reservoir shocks, Wheeler’s Off-road add-a-leafs. LED lighting. Pioneer Avic 7200NEX Nav Head unit. Borla cat back exhaust.
    That's not acceptable. They should've sprayed the parts separately.
  6. May 28, 2019 at 12:14 PM
    FirstGenVol
    FirstGenVol Brake Czar
    East TN
    2002 AC
    Yeah that's not acceptable. Is that a crack also? Right hand side.
  7. May 28, 2019 at 12:18 PM
    TheBeast The Beach
    here is my rear bumper. I specifically asked Not to paint the step pads. It was also line x over chrome. still looks as new 3 years later..
    Mnorris1206, 15whtrd and Darkness like this.
  8. May 28, 2019 at 7:54 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    That's pretty crappy job, hate to sound like a dick but it doesn't look good at all. I'd definitely go back and make them redo that or get a refund and find someone who will do it right. That's gonna peel, rust, and look even worse in a few months.
    15whtrd and RitcheyRch like this.
  9. May 28, 2019 at 8:26 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Second pic I think they have no pride to let something leave that way. They should have sprayed the parts separately and wouldn't have a problem now. Leaving them together is an opening for chrome to peak through the gap. The bubble and crack says they didn't prep it. That all needs to be taken apart, sanded off and repainted proper.
  10. May 28, 2019 at 8:27 PM
    Dabutcher
    Dabutcher New Member
    D
    Twin Cities
    2008 Nautical Blue Tundra SR5 CM 4x4 Beauty
    Toytec Boss coilover, Ray10’s ,Ridge Grapplers,Bilstein 5100,BAM 8”,TRD sway,
    Can you both tell me how much it costs for front and back bumpers? I was quoted at $600 for Rhino liner here in the Twin Cities. I thought that was too expensive. I can buy two new rock warrior bumpers for not much more than that. Thanks. D
  11. Jun 19, 2019 at 3:54 PM
    birdman076
    birdman076 Bird, bird, bird...bird is the word
    Chuck
    Montana
    2015 Brown Tundra Crew Max Limited
    Airbox with K&N Filter, 2" lift on 33's, Alpine iLX-F309 head unit, Pull out bed tool boxes, brown with black trim, rims, etc, black leather interior, matching topper. Muffler delete (too loud..) 62k miles!!!
    They didn't prep the chrome correctly, it needed to be roughed up for the Line-X to adhere. That's a respray for sure, they will have to strip it all off and re-shoot it. You're in Florida, Tampa Bay by the looks of the plate I'm in the Tampa Bay area as well shoot me a PM where you had it done I do some work for a shop that sprays Line-X and may be able to help. I had mine encapsulated (sprayed inside and out) because I mounted the pods through the bumper.
    rons23 likes this.
  12. Jun 19, 2019 at 3:57 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    X2
  13. Aug 31, 2019 at 4:46 PM
    So i finally got it repaired yesterday. They completely stripped and resprayed it at their cost. Good to go now. I had the flares done as well.
    TheBeast and NUDRAT like this.
