Limp mode in 07 Tundra limited
Discussion in '2nd Gen Tundras (2007-2013)' started by Formerchevyman, Feb 23, 2020.
  1. Feb 23, 2020 at 1:28 PM
    Formerchevyman
    Formerchevyman [OP] New Member
    Shawn
    07 Tundra DC LTD
    6” RC lift. 35x12.50 BFG KO2
    So today my tundra went into limp mode for the first time. Luckily, I had read a lot about it on this forum prior to it happening so I knew how to clear it. Now.... what I’m looking at doing is buying a bypass kit from Hewitt and a bully dog programmer. Can anyone tell me if this has worked for them? Or maybe they know someone that’s done this. All feed back is welcome.
  2. Feb 23, 2020 at 3:32 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Whoa there....
    What CEL code are we talking about that was cleared?
  3. Feb 23, 2020 at 3:44 PM
    Formerchevyman
    Shawn
    07 Tundra DC LTD
    I don’t have it in front of me but best I remember it was P1445 or something like that. I’m at work so it will take me going home to get the printout.
  4. Feb 23, 2020 at 3:48 PM
    Formerchevyman
    Shawn
    07 Tundra DC LTD
    It was the code for the secondary air value
  5. Feb 23, 2020 at 6:41 PM
    FXFormat
    FXFormat New Member
    That bypass kit works, install it and you'll never have to worry about it again. Plenty of us Land Cruiser owners have had it installed, very easy to do, look on youtube for DIY
    Formerchevyman[OP] likes this.
  6. Feb 23, 2020 at 9:34 PM
    Formerchevyman
    Shawn
    07 Tundra DC LTD
    FXformat. Thanks for the info. I think I’m going to go ahead and get one.
  7. Feb 23, 2020 at 10:36 PM
    TTund16
    TTund16 New Member
    What is the problem and how can you clear it without fixing? I missed other threads about this issue.
    Can you give a quick summary?
    Thanks
  8. Feb 23, 2020 at 10:45 PM
    Formerchevyman
    Shawn
    07 Tundra DC LTD
    Ok in summary. I started the truck this morning. (Around 1pm cause I work the owl shift) truck ran fine. Drove about 1 mile and stopped at a stop sign. When I pressed the gas it went into limp mode. Vsc light flashing and 4 Lo flashing. I pulled over and took the battery cable loose for 30 seconds. Re attached the positive post cable and started the truck. All lights were off and the truck ran fine.
    TTund16 likes this.
  9. Feb 23, 2020 at 10:49 PM
    TTund16
    TTund16 New Member
    isn't the CEL for secondary air valve coming back again? What is causing the code?
  10. Mar 5, 2020 at 4:02 PM
    Formerchevyman
    Shawn
    07 Tundra DC LTD
    So here’s the update. Got the Hewitt-Tech by-pass. Took it to my buddies shop and we installed it. Took about an hour only because he refuses to let his work look less than OEM. On startup. All codes cleared themselves. (P2440 was the code) truck runs great. Only about 20 miles on it right now. But I’ll be updating as I put more miles on it.
    Im pretty happy about this.
    Spaceiscool and Rph74 like this.
