Limited slip to full lock rear locker?
Discussion in '1st Gen Tundras (2000-2006)' started by cameron92, Oct 19, 2021.
  1. Oct 19, 2021 at 3:06 PM
    cameron92
    cameron92 [OP] New Member
    PNW (State of Jefferson)
    2005 Phantom Pearl Grey Tundra Limited DC 4WD, 4.7L VVTI, LSD, Tow Package
    2.5in suspension lift (Bilstein 5100's, Icon add-a-leaf, Eibach pro springs, Camburg upper control arms, and kyb replacement tophats.) ARMA Bedliner. Trailer Braking System. Fifth wheel underbed mount plates (frame mounted) W/ through bolts in bed. Yakima Q-Towers W/ 58in Yakima round crossbars and 52in Yakima wind fairing.
    Been looking around for a nice limited slip to full lock rear differential for my 05 DC Limited. Any suggestions would be appreciated. Also would love to know what kind of experience you've had with it. Thanks everyone!
  2. Oct 19, 2021 at 4:05 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    You mean you want either a limited slip or a locker?
    alb1k and FrenchToasty like this.
  3. Oct 19, 2021 at 4:08 PM
    cameron92
    No a limited slip differential with a selectable on/off full lock whether it be air or electronic.
  4. Oct 19, 2021 at 4:11 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    You can’t have both, it’s one or the other.
    I have a lsd but I will be getting a Elocker soon
    des2mtn and alb1k like this.
  5. Oct 19, 2021 at 4:18 PM
    cameron92
    I have the factory LSD already. I'm talking more about a diff like the Auburn Select-a-Loc which when the the full lock is turned off the diff then works as a limited slip until you turn on the full lock.
  6. Oct 19, 2021 at 4:29 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    It's one or the other. Call a differential shop. I have LSD and eventually will lose that for a locker.
  7. Oct 19, 2021 at 4:33 PM
    FrenchToasty
    Mo
    Bone stock
    We’ll apparently Auburn does make a lsd to full lock, but doubtful it will fit our rear ends, I couldn’t find where it lists compatibility
    alb1k[QUOTED] likes this.
  8. Oct 19, 2021 at 4:38 PM
    cameron92
    I'm trying to see if anyone has actually had a diff like that Auburn diff without having to swap out the whole rear end to aquire such a diff for our 1st gens.
  9. Oct 19, 2021 at 9:06 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    2” Lift, Bilstein 5100’s and 885’s second notch, Rear 5100’s Icon 3 Leaf Pack and Firestone Air Bags w/Daystar Cradles. Spider Trax 1.25” Wheel Spacers, 4Runner Pro Wheels, Falken AT3W 285/75r17 (34x11).
    Not sure what you are talking about. You don’t have to replace the housing, only the differential.
    The ELocker is about $1,200, plus rebuild kit and cost to install. And if you are going that far you might as well regear and add bigger tires.
    I don’t know of a combo LSD and Locker for the Tundra’s, and I don’t think I would want one, sounds like it would do two things not very well. I put an ARB air Locker in my Tacoma, and I never wished I also had an LSD.
  10. Oct 19, 2021 at 9:35 PM
    cameron92
    I know Auburn makes a lsd locker combo diff for the tundras but not sure if it is for the newer generation tundras and if it would fit in my housing or if i would need a different housing to fit the diff. I live on the coast where it rains a ton and i go to the the snow enough where having an lsd is great but i also want to start taking my tundra through more sand and mud trips where having a locker would be better. Thats my reasoning for wanting a lsd/locker combo.
    Diablo169[QUOTED] likes this.
