Limited slip differential or not?
Discussion in '1st Gen Tundras (2000-2006)' started by hibilly, Oct 21, 2015.
  1. Oct 21, 2015 at 9:24 AM
    hibilly
    hibilly [OP] New Member
    William
    2000 Tundra V8
    I'm not sure if I have a limited slip differential or not./ My 2000 Tundra is a V8 4wd. I recently had the differential start leaking from the housing, I fiberglassed over it and am going to check differential fluid but I am not sure if it is limited slip or not. I read in two manuals that limited slip takes limited slip hypoid while standard takes regular hypoid. Any clarification as to how to find out and fluid recommendations is appreciated. Thanks..B
  2. Oct 21, 2015 at 9:47 AM
    jberry813
    jberry813 The Mad Scientist Staff Member
    Lake Tahoe
    2015 Tundra Platinum, 2012 Tacoma, 2007 T4R
    Metric shit ton of parts
    Use Redline 75w90 gear oil and it will work for both. It has friction modifiers for LSD's but you can safely use it on non-lsd diffs.
    mcharfauros likes this.
  3. Oct 21, 2015 at 11:56 AM
    twotrack
    twotrack New Member
    Clint
    Tampa, FL
    2015 Tundra SR5
    00-01 didn't have a factory LSD option. LSD was a factory option starting in 2002.
  4. Oct 21, 2015 at 12:21 PM
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    Would also say lSD oil only in the back of the axle housing next to the fill plug
  5. Oct 21, 2015 at 12:33 PM
    jberry813
    Lake Tahoe
    Only if the sticker stays on. Mine pealed off after about 5 years
  6. Oct 22, 2015 at 7:25 AM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Well stop rubbing your junk on the axle housing and it won't do that
    Black Wolf likes this.
  7. Oct 22, 2015 at 7:02 PM
    Don't spoil the all the fun!
  8. Oct 25, 2015 at 5:46 AM
    hibilly
    William
    2000 Tundra V8
    Thanks to all who responded. Will look for tag and assume pre 02 is not LSD.
  9. Nov 2, 2015 at 10:00 AM
    pejohnson
    pejohnson New Member
    phil
    2006 Tundra SR5
    Will Royal Purple work for both as well? I bought a pre-owned vehicle that had the frame coated to protect it from rusting further. As such all stickers have been coated or lost.
