Light white smoke on morning start
Discussion in '2.5 Gen Tundras (2014-2021)' started by Norfolk757, Jun 8, 2018.
  1. Jun 8, 2018 at 5:14 AM
    Norfolk757
    Norfolk757 [OP] עַם יִשְׂרָאֵל חַי
    Tom
    Norfolk, VA
    2015 White Tundra- CrewMax TRD Off Road
    got a 2015 CM SR5 that recently purchased with about 76K miles from a dealer. The dealer changed the oil before I took possession.
    When the truck is started in the AM it will omit a thin cloud of white smoke for about a second then stops. It seems to do that every morning so far. Our Temps in the AM have been aroud 62-70. Is this a sign of some issues or is this something that can be fixed with oil change with additives? Any help/advice would be greatly appreciated.
  2. Jun 8, 2018 at 5:23 AM
    Did you get an extended warranty on it? Take some videos of it take back to dealer n show em have em fix
    15whtrd likes this.
  3. Jun 8, 2018 at 5:23 AM
    15whtrd
    15whtrd Mr. Blonde
    Id say possible PCV valve. Do you have a warranty? If so take it in.
  4. Jun 8, 2018 at 5:26 AM
    Norfolk757
    Tom
    Norfolk, VA
    No warranty on it as they sold it to me AS IS. I have to drive out of town to get it.
  5. Jun 8, 2018 at 5:28 AM
    15whtrd
    15whtrd Mr. Blonde
    Is it within 30 days?
  6. Jun 8, 2018 at 5:29 AM
    Norfolk757
    Tom
    Norfolk, VA
    Not yet, got it on 5/18.
  7. Jun 8, 2018 at 5:34 AM
    15whtrd
    15whtrd Mr. Blonde
  8. Jun 8, 2018 at 5:42 AM
    I’m going with this is a Flex Fuel and needs an update.
    Pale_Horse likes this.
  9. Jun 8, 2018 at 5:44 AM
    Norfolk757
    Tom
    Norfolk, VA
    Thanks for the link. It sound like this was also loosing oil but with out it being spilled on the floor so im assuming his issues was something else. I will see about replacing the PCV Valvle this weekend, maybe it could be that.
    15whtrd[QUOTED] likes this.
  10. Jun 8, 2018 at 5:45 AM
    Norfolk757
    Tom
    Norfolk, VA
    What this now.. I dont think i have flex fuel, how would i know. Also, if i do how/what needs to be updated? Thanks @T-Rex266
  11. Jun 8, 2018 at 5:47 AM
    Check your fuel cap.
    The dealership will know if the ECU needs an update. I’ve seen / read this more than once and hope that’s all it is.
  12. Jun 8, 2018 at 6:10 AM
    Norfolk757
    Tom
    Norfolk, VA
    I just wanted to say thank you to @15whtrd and @T-Rex266 . You guys sure know your SH!T! I called the dealer and talked to one of the service advisors who owns a tundra and is an actual Forum member, and he said the same thing. It most likely is a PCV valve and if that doesn't fix it, the ECU upgrade is about $175. Going to pick it up today and try to replace it this weekend.
    T-Rex266 and 15whtrd like this.
  13. Jun 8, 2018 at 6:23 AM
    15whtrd
    15whtrd Mr. Blonde
    No problem! I’m no expert by any means, but I do a lot of reading around here. There is a write up on how to change that PCV valve around here somewhere I’m sure. It’s just under the intake manifold in the front. If you’re clever should be able to get to it no problem.
  14. Jun 8, 2018 at 7:01 AM
    LOL, whats his username?
    15whtrd likes this.
  15. Jun 9, 2018 at 10:15 AM
    Norfolk757
    Tom
    Norfolk, VA
    Just replaced the Valve but testing it it was functional. It would suck in air and pretty much acted like the new one. Also noticed some oil in the hole of the thread of the PCV Valve.
    This is the gas cap, does it look like I have Flex fuel? As Tex mentioned something about the ECU update.
  16. Jun 9, 2018 at 10:19 AM
    seniramsu
    seniramsu Pro Runnin
    Nate
    VA
    2017 TRD Pro Tundra Wht
    Negative sir, you do not have ff.
  17. Jun 9, 2018 at 10:20 AM
    TheBeast The Beach
    regular engine. doesn't look like Flex fuel gas cap.
    Norfolk757[OP] likes this.
  18. Jun 9, 2018 at 10:27 AM
    Norfolk757
    Tom
    Norfolk, VA
    Thank you guys. I just hope the smoke will stop when I start it tomorrow AM.
  19. Jun 12, 2018 at 5:52 AM
    Norfolk757
    Tom
    Norfolk, VA
    It looks like the smoke was gone the next day but this AM when started it had a very little puff of smoke for less than a second and disappeared. Do you guys think that was the issue and this is the process of it getting cleared out so it will start to completely disappear or am i too hopeful and there is a bigger issue for the engine? I tried to attach a Vid but was not able to due to the format.
  20. Jun 12, 2018 at 6:16 AM
    15whtrd
    15whtrd Mr. Blonde
    Did it seem different than before? Give it a few days or maybe even by tomorrow. Fingers crossed for you.
  21. Jun 12, 2018 at 8:18 AM
    MistrRoboto
    MistrRoboto '17 MGM SR5 TRD CrewMax
    Virginia Beach, VA
    Any chance you or the dealer overfilled the oil? Give the dip stick a peek. I did it once (and not by that much) on my old vehicle and it smoked on start until I lowered the level back to normal.
    Thanks!
  22. Jun 12, 2018 at 8:46 AM
    Norfolk757
    Tom
    Norfolk, VA
    Thank you I think you might be right and time will tell.
    I was thinking about the same thing as the dealer who changed the oil was a GMC dealer and probably never worked on foreign trucks. I have contacted my local Toyota dealer to see how much they will charge to change the oil to synthetic and if they could tell what type of oil was used before.
  23. Jun 13, 2018 at 6:50 AM
    MistrRoboto
    Virginia Beach, VA
    You don't really need to call anyone to check the oil level. Just pull out the dip stick, wipe it, put it back in, pull it out, and see where you are at.
  24. Jun 13, 2018 at 6:58 AM
    Norfolk757
    Tom
    Norfolk, VA
    Lol, yeah I figure that I could handle that’s aspect, I was more referring to the question of the kid of oil used (synthetic or conventional) in the previous or current oil changes.
    Hey, you’re in my area, do you have any recommendations for a shop that will do quality work for a fair price when it comes to Suspension/exhaust/ work?
    Thanks.
  25. Jun 13, 2018 at 7:01 AM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    Could also be valve seals. Smoking for a few seconds at startup is telltale of those little things wearing out. I had the same problem in the past and new valve stem seals cleared it right up.
    Abrams65 likes this.
  26. Jun 13, 2018 at 8:32 AM
    MistrRoboto
    Virginia Beach, VA
    I've heard good things about Production Offroad in Virginia Beach, but haven't been yet.
  27. Jun 13, 2018 at 8:59 AM
    rds95991
    rds95991 New Member
    2018 Super White Tundra CrewMax SR5 TRD
    I was told brown was gas, blue was oil, and white was water/coolant. Had a 1965 Mustang and went through all three, but then I guess I'm old school.
    But then again, is it possible this is condensation in the exhaust system from sitting overnight. What does it smell like? That may give you a clue.
    TTund16 and Norfolk757[OP] like this.
  28. Jun 13, 2018 at 1:28 PM
    SMK Shoe
    SMK Shoe Not New Member
    Paul
    Central North Carolina
    2017 Tundra TRD DC
    Step Bars, Rear Swaybar, 2,000 Watt Amp, 2-10" Subs, new door speakers, De-Badged, Hondo vent mounts, Calipers, 6112/5100 shocks, SPC UCA's, Front bumper, Bed Bars, bed rack, Fuel Rims
    Would like to see a video of the smoke. Smell will defiantly tell you where to start looking. Sweet smell is antifreeze and everyone knows what burning oil smells like.
    15whtrd and Norfolk757[OP] like this.
  29. Jun 13, 2018 at 8:13 PM
    darkknight2014
    darkknight2014 Mods mods and more mods!!
    Phil
    New york
    2014 tundra sr5
    20" Cooper STT Pros on md rims, quadfire lights, pro grille, leather interior, navi, retrofitted headlights, blacked out chrome, TRD sway bar, hypertech interceptor, k&n air intake, Banks exhaust
    It turned out that the oil seperator caused it. That was my thread it went from the pcv to the oil seperator. Since then no smoke at start up. Good luck with urs
    TTund16 likes this.
  30. Jun 14, 2018 at 7:59 AM
    Norfolk757
    Tom
    Norfolk, VA
    I was able to at least get a little puff of faint smoke this AM but it lasted less than a second and as far as smell, i could not tell any weird sweet or oil burning smell. It was that general combustion smell that comes out of the tailpipes on any car.
