Light height settings for leveling???
Discussion in 'Suspension' started by Tun-D, Mar 27, 2019.
  1. Mar 27, 2019 at 11:56 AM
    Tun-D
    Tun-D [OP] New Member
    Don
    Sacramento CA
    2019 TRD Sport MGM
    Hey all. I am having my truck leveled today with Bilstein 6112's set at 1.9" on the front. Rear will remain stock (for now). For those that have had the same level done, can you tell me if you had to adjust your headlights down to not blind other drivers? If so, what setting?
    If it makes a difference, I have a 2019 CM TRD Sport 4x4.
    Thanks.
    georgiey22 likes this.
  2. Jul 1, 2019 at 12:21 AM
    Calidude7
    Calidude7 New Member
    did you ever resolve this issue ? I just level mine today and have the same question .
  3. Jul 1, 2019 at 1:25 AM
    Nm6300'asl
    Nm6300'asl New Member
    2022 DC SR5 4x4
    Oem tonneau, side steps, spray in liner. Trd skidplate.
    Try the headlight adjusting switch, just move the dial.
    NewImprovedRon likes this.
  4. Jul 1, 2019 at 3:18 AM
    Stumpjumper
    Stumpjumper New Member
    Fate, Tx
    2017 Tundra TSS 4x4
    Just check the height on garage door before installing levelling kit. Note the height then use the levelling adjustments on back of headlight to duplicate. This way you will retain the full adjustment on the dash levelling dial.
    plinyyounger likes this.
  5. Jul 1, 2019 at 5:46 AM
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    Mine is still well within the level adjuster on the dash, it went down a couple notches but still have a few more notches to lower it if I needed to because of weight in the bed.
  6. Jul 1, 2019 at 6:19 AM
    Tun-D
    Don
    Sacramento CA
    2019 TRD Sport MGM
    Since I didn’t take any measurements before the level I just dropped it about 1.5 on the dial as a best guess.
  7. Oct 19, 2019 at 6:39 PM
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
    2016 Toyota Tundra SR5 TSS Off Road
    TTC MEMBER #0193 2.5 Bilsteins struts (front) JDMstar led lighting inside Lazarstar spot lights Auxbeam LED headlight bulbs Auxbeam LED fog light bulbs 1.25” Spidertrax wheel spacers OEM fender flares
    How do you know how many inches off the ground you should be? I felt mine were a little bit low so I put them higher. Black tape is around 48” (4ft) somewhere their and felt that was way too high
  8. Oct 20, 2019 at 4:48 AM
    belanger9
    Edmonton, AB
    A bunch
    There's a little dot in the lens of you're headlight that you need to measure to. In you're picture if all 4 wheels are on the driveway and it's a constant slope take that measurement and transfer it to your garage door and have the cutoff be about 2" below that mark. I personally keep it slightly lower, like 3 inches lower with the truck 25 feet back to make sure I don't blind people. IIRC my truck is around 42-43" to this dot so I go to ~40" with the light cutoff.
    Toyotoholic and NewImprovedRon like this.
  9. Oct 20, 2019 at 6:51 PM
    I run a 3 inch lift and set my dial at 3 and a half and I run led headlights and fogs. I don't have any issues with oncoming traffic.
  10. Oct 20, 2019 at 7:02 PM
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
    3 and half what does that mean sorry lol
  11. Oct 20, 2019 at 7:15 PM
    It's for auto headlight leveling.....if you have it.
  12. Oct 20, 2019 at 7:24 PM
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
    Oh yeah i have that didn’t know what it does
  13. Oct 20, 2019 at 7:38 PM
    No problem. It's used to aim your lights down when hauling heavy loads. Park facing a wall and move it up or down and you can see how much the light moves. It works great when some dumbass cuts in front of you and doesn't have tinted windows.
    JimboSlice413 likes this.
  14. Oct 20, 2019 at 11:13 PM
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    2016 Limited 4x4, 2003 Sequoia
    Bilstein 5100/5160 Toyo at2 295/70r18 Ray10 GunMetal
    :rofl:I also do this
    Tundyfundy and Tundra234[QUOTED] like this.
  15. Oct 21, 2019 at 10:31 AM
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
    Ohh yeahhh it worked lol this whole time I thought i was adjusting the brightness inside my truck. Haha
  16. Oct 21, 2019 at 11:00 AM
    Kelly Kelly Kelly...LOL:rofl: (just giving you a hard time)
    KELZ84[QUOTED] and Tundyfundy like this.
  17. Oct 21, 2019 at 2:32 PM
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
    I can be airheaded at times lol women!
  18. Oct 21, 2019 at 6:27 PM
    Lol. But hey, you're a girl with a truck and not a little Honda so it's all good! :hattip::thumbsup:
    KELZ84[QUOTED] likes this.
