Light Bar Wiring Install - Help needed
Discussion in '2.5 Gen Tundras (2014-2021)' started by ccwebster, Aug 20, 2019.
  1. Aug 20, 2019 at 6:18 PM
    ccwebster
    ccwebster [OP] New Member
    Christian
    2015 Toyota Tundra Platinum 4x4 4WD
    Hey Guys,
    So I bought a rough country lite bar and it came with a wiring harness, and the instructions have me directly wiring to the battery (see attached). That can't be right - Seems like I'd want to attach the positive to something that turns off when the vehicle is off. Any recommendations for thoughts?
  2. Aug 20, 2019 at 6:31 PM
    AZTundra
    Paul
    Phoenix, AZ
    Your switch will be the on/off control for the light. Looks like you'd be able to use the light regardless if the vehicle was on or off.
  3. Aug 20, 2019 at 7:21 PM
    jordan0317
    jordan0317 Just hoodrat things...
    Jordan
    Martin, TN
    2017 White Tundra XP 4x4
    Yea, mine is wired straight to battery as well. Can turn the light bar on with the truck off, as well as the ditch lights. I Just cut the push button switch the harness comes with off and wired an OEM style light bar switch in and run it in a blank spot on my dash next to to my ditch light switch.
    AZTundra likes this.
  4. Aug 20, 2019 at 7:24 PM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    jordan0317 likes this.
  5. Aug 20, 2019 at 9:35 PM
    fundratss
    fundratss Send it!
    Joe
    Colorado Springs
    2016 Magnetic Grey Tundra TSS
    Toytec 2.5” Coilover boss suspension 3/1 lift w/camburg uca’s Morimoto xb headlights Morimoto fog Rough country grill 2 RC blacked light bars Volant air intake system Rear air bags (for towing) I’m sure there’s more but I’m lazy
    Both of mine are wired up pretty much how RC shows except o didn’t use their switch. I used a custom Toyota switch that go right into an empty switch spot on the dash. Looks factory on the switch also. You could wire it up directly to batt, or fuse box. Or a key on engine off location if you wanted to.
