Light bar size behind a TRD Pro grill
Discussion in 'Lighting' started by Stumpjumper, Sep 11, 2017.
  1. Feb 15, 2018 at 3:52 AM
    Njmike13
    Njmike13 New Member
    Hunterdon county, NJ
    2021 PRO Lunar Rock
    Cool. I see you used stacked washers as spacers and added a support to the center of the light. Was that center support put in because of vibration due to the added height? How did you determine where to cut the notches? Lastly how did you like that light bar? Lots of questions sorry.
  2. Feb 15, 2018 at 4:10 AM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    I used all stainless steel hardware so it wouldn't rust. First thing I did was take the grille off and notch the grille to fit the light bar. It's a lot easier to do off the truck. Then I put the grille back on without the lightbar. Took a measurement of the distance from the new cut opening for the light to the metal OEM bracket. This help me determine how many washers I would need. I had to notch the lightbar brackets to allow the grille to push back all the way. Without the center support the light bar will move and have bounce. You need to make the center support the right length to aim the light at the right angle. This is project that will take some back and forth adjustments. The Rigid Radiance light bar was great. I know there are other light bars that are good as well.
    Mr. Cade likes this.
  3. Feb 15, 2018 at 5:39 AM
    Njmike13
    Njmike13 New Member
    2021 PRO Lunar Rock
    Great. Thanks for the info
    1UPPER[QUOTED] likes this.
  4. Feb 15, 2018 at 6:42 AM
    inferno_pro_satx
    inferno_pro_satx New Member
    Roger
    2016 Tundra TRD Pro
    For the center support I used a turnbuckle so I could adjust up or down.
    philly, Njmike13[QUOTED] and 1UPPER like this.
  5. Feb 15, 2018 at 7:25 AM
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    photo of how you attached it?
  6. Feb 18, 2018 at 3:15 PM
    1UPPER
    TEXAS
    Flux capacitor!
    I took the front of my truck apart today. So I've attached the measurements of the holes i drilled to mount the 40" lightbar behind the grille.
    Driver side 3 3/16" from the edge.
    1/2" back from the front is the exact center point.
    Passenger side. 3 3/16" from the edge and 1/2" back from the front edge to center hole.
  7. Feb 18, 2018 at 3:45 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    IMG_20171016_171528423.jpg IMG_20171019_081910939.jpg IMG_20171016_171542471.jpg IMG_20171016_182504743.jpg
    This is from Headlight Revolution. It is their own version, fits perfectly, and for the $ it's a winner.
    1UPPER and 4Runner like this.
  8. Feb 18, 2018 at 3:46 PM
    4Runner
    4Runner New Member
    Columbia, SC
    2017 Black Limited FFV
    Magnuson Supercharged, FOX 2.5 DSC front and rear, TRD Exhaust, TRD Rear Sway, and many more....build thread coming
    Headlight Revolution 40" Stealth (behind grille)...easy install.
    Toyotoholic likes this.
  9. Feb 18, 2018 at 3:47 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Funny we just posted the same thing!
    4Runner[QUOTED] likes this.
  10. Feb 18, 2018 at 3:49 PM
    4Runner
    4Runner New Member
    Columbia, SC
    Just saw that. Hey, I did have to push back the bracket that holds some hose connectors at the front of the radiator. Did you? It was easy to bend so I just figured my bracket was a tad out of spec. Once I did that, it was easy. Hardest part was running the wires through the firewall.
  11. Feb 18, 2018 at 3:57 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    I believe you are talking about these... and yes I had to very easily bend them slightly to not hit. I also bored the mount to accept a larger bolt and added a stabilizing square washer to minimize flex of the truck's metal... It's a little thin.
  12. May 20, 2018 at 7:47 PM
    War_Wagon312
    War_Wagon312 Puddle Dodger
    Rich
    2016 Pro MGM CM
    Toyo MT 285/70/R18, led's all around, Baja Design squadron sport fogs, spider trax 1.5 spacers, led foot well lighting, interior chrome delete, kc hilites 40inch light bar grill mounted, 20%tint all around, color lugs black lugnut caps, 2019 pro head lights, led lights all around, spyder co tail lights, DMX1057xr, super crew box with kicker 10” sub,jbl door speakers, factory amp bypass trd air flow accelerator with drop in filter, x3 battery, Toyota bed cover, swing case,
    Do you have a build thread on this? This looks nasty and I want to do it.
  13. May 20, 2018 at 8:06 PM
    1UPPER
    TEXAS
    Flux capacitor!
    War_Wagon312[QUOTED] likes this.
  14. May 21, 2018 at 6:46 AM
    Js18tundra
    Js18tundra New Member
    18 Tundra sr5 TRD 4x4
    Diamondback se tonneau
    Which roof bar mounts did you use?
  15. May 21, 2018 at 7:13 AM
    War_Wagon312
    Rich
    2016 Pro MGM CM
  16. May 21, 2018 at 7:41 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    I got them off of Amazon. Xprite 50" straight and curved light bar mounts. I've had them on for about a year and a half and still holding strong
  17. May 28, 2018 at 8:16 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Now I just need to fab the brackets off my cardboard templates.
  18. Aug 26, 2019 at 8:11 PM
    nlaroy
    nlaroy New Member
    Nick
    So Cal
    2017 Inferno Crewmax
    LED bulbs, RCI Underwear, WKOR Sliders, Fox 2.5 w/ resi Front and back, Deaver leaf springs,
    How did you mount that 42" did you use mounts? I got a no name brand, and wondering if i need brackets
  19. Aug 26, 2019 at 8:49 PM
    #49
    TXRailRoadBandit73 YOTAS,RAILROADIN',RĂ–KnRĂ–LLN',BEER,MAX/GEMMA
    Mine is a Rough Country 30" it comes with all necessary mounts, but now, I wanted light bar to come more forward bout, sono cut the plastic mesh out, and had some galvanized metal strap, drilled two holes, 3" center to center, and the light bar is flush with the TOYOTA letters
  20. Aug 26, 2019 at 9:03 PM
    #50
    This is what I did now, cause I asked if anyone else has done and @War_Wagon312 replied I like what he did, his is a 40"
    @War_Wagon312 ^
  21. May 6, 2020 at 7:55 AM
    #51
    Mrlumens
    Mrlumens New Member
    Hey bud, which light bar did you put in your hood scoop? and was it a hard install. this is the lightbar placement that most interests me.
  22. May 8, 2020 at 5:16 AM
    #52
    1UPPER
    TEXAS
    Flux capacitor!
    Thats the NSV auto Lightbar. It’s not very hard to install. It’s a already made to be a plug and play install. They have the instruction with the light bar and it’s made specifically for the 3rd gen Tundra.
  23. May 8, 2020 at 6:24 AM
    #53
    Mrlumens
    Mrlumens New Member
    Awesome! Thank you.
    1UPPER likes this.
