Light Bar install W/Aftermarket Stereo System
Discussion in '1st Gen Tundras (2000-2006)' started by Cnusax, Jan 28, 2020.
  1. Jan 28, 2020 at 4:47 PM
    Cnusax
    Cnusax [OP] New Member
    Michael
    2006 GRY V6 Tundra SR5
    Added amp and 12” Kicker CompR Added Pioneer 2-DIN touchscreen radio with CarPlay Added generic backup camera inside tailgate handle
    Hi all,
    So I have a 2006 V6 SR5 half cab Tundra. I have a 12” sub with an amp and capacitor installed, along with a pioneer head unit. My question is, would I be able to put in a dual rack light bar and get away without needing to change any of the electrical system, or would I need another/bigger alternator or battery?
    Thanks for the help!
  2. Jan 28, 2020 at 5:06 PM
    Welcome from NY.
    Maybe @james@tech12volts can chime in and lead you in the right direction.
  3. Jan 28, 2020 at 6:16 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    It really depends on the amp draw for the new light bars. Many stock alternators can handle a bit more load.
  4. Jan 28, 2020 at 9:11 PM
    smokey0810
    smokey0810 New Member
    '03 Tundra SR5 AC 4WD
    If the new light bar is LED it shouldn’t be pulling that much voltage. Shouldn’t be an issue.
    tvpierce likes this.
  5. Jan 28, 2020 at 9:27 PM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    How much amperage are you looking to add? What is the added draw going to be?
  6. Jan 29, 2020 at 4:53 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    How many watts is your sub amp, and how many ampheres does it draw?
    What kind of light bar? Assume it will be LED?
  7. Jan 29, 2020 at 3:28 PM
    Cnusax
    Michael
  8. Jan 29, 2020 at 3:43 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    I(Amps) = P(Watts) / V(Volts)
    I(A) = 120W / 12vdc
    I(amps) = 10 amps or 10000milliamps
    bmf4069, KarmaKannon and scottymt36 like this.
  9. Jan 29, 2020 at 4:06 PM
    KarmaKannon
    Utah
    Some junk
    Pie!
    That's not much added load. A quick search shows that your alternator might be 100 amps. I don't think 10 amps or so is going to kill you, but stereo stuff and a worn out alternator or battery wouldn't like any more load anyway.
    If your alternator and battery are good then 10amps is pretty small.
    BubbaW[QUOTED] likes this.
  10. Jan 29, 2020 at 4:19 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    "Pie are not square! Pie are round! Cornbread are square!"
    KarmaKannon[QUOTED] likes this.
  11. Jan 29, 2020 at 4:28 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Sas and BubbaW[QUOTED] like this.
  12. Jan 29, 2020 at 6:01 PM
    Professional Hand Model
    Hand Protectors
