Lifting my tundra trd pro
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Johnyoon, Dec 17, 2015.
  1. Dec 17, 2015 at 8:43 PM
    Johnyoon
    Johnyoon [OP] New Member
    john
    2015 tundra trd pro inferno
    Hello...I'm trying figure out how to lift little higher...
    Is anyone who already lifted?
  2. Dec 17, 2015 at 8:44 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    You are looking to add more lift your TRD Pro?
  3. Dec 17, 2015 at 8:49 PM
    Johnyoon
    john
    Yes...tundra is my first truck and I don't know alot about lifting truck...
  4. Dec 17, 2015 at 9:03 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Gotcha... You may want to check this out, it has some good info on lifts.
    My truck isn't lifted and I have never had a lifted truck, so I'm not the best guy to give you an answer.
    How much more are you looking to get? You will probably need to get a whole new setup unless a small spacer lift (like 0.5") would work, but I don't think it would be worth it.
    https://www.tundras.com/threads/guide-different-types-of-lifts.546/
  5. Dec 17, 2015 at 9:07 PM
    Johnyoon
    john
    Thank you..yeah lot of people say don't lift it just get some bigger tire..I probably will.
  6. Dec 17, 2015 at 9:33 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    I wouldn't. Your suspension setup is great the way it is.
  7. Dec 17, 2015 at 9:35 PM
    Johnyoon
    john
    Your right....I probably get some bigger tires.
  8. Dec 17, 2015 at 9:53 PM
    jdm ctr '00
    jdm ctr '00 New Member
    los Angeles, CA
    2016 Tundra TRD PRO
    Bigger tires :thumbsup:
  9. Dec 18, 2015 at 4:31 AM
    Airbagged
    Airbagged New Member
    2015 Toyota Tundra TRD off road DC
    Camburg UCA Fox 2.5 front Fox 2.0 rear Timbren bump stops 20" wheels Coachbuilders shackles Coachbuilders tie rod ends 46 gallon transfer flow tank Flush bed cover Billet grill LED light bar front Led reverse lights TRD sway bar rear TRD cold air intake Locker down consol safe Towing mirrors Fender flares Magnaflow exhaust TRD shift knob Magnum running boards Paracord wrapped grab handles And more
    You need to contact Coachbuilders he has just what you need to do I lift on your TRD pro, and his parts are top
    Notch high quality!!
    boardude and tat2ude39 like this.
  10. Dec 18, 2015 at 5:44 AM
    Johnyoon
    john
  11. Dec 18, 2015 at 5:44 AM
    Johnyoon
    john
    Thanks
    Airbagged likes this.
