Lifted tundra outside tire wear
Discussion in 'Suspension' started by Cg13055, Feb 14, 2021.
  1. Mar 16, 2021 at 8:06 PM
    Cg13055
    Cg13055 [OP] @yota.parts.distributor
    South Florida
    Mcfly Tundra @yota.parts.distributor
    2012’4.0 Tundra-2004’4.7 crewcab-2021 2.7 Tacoma
    hmmm that sucks, I like these rims because they're pretty rare and came on the truck from factory but they don't leave me with much options for tires. Any way to fix this?
  2. Mar 17, 2021 at 3:48 AM
    R0CKETMAN
    R0CKETMAN IG: @rocketmanmtb
    NGAMTNS
    '17 TUNDRA TRD PRO CEMENT ‘15 TUNDRA SR-5 WHITE
    What’s your wheel and tire width?
  3. Mar 19, 2021 at 7:26 AM
    Cg13055
    South Florida
    265/70R18 stock BBS 18’s. I believe my issue is not because of the wheels. The more I look into it the more I realize my lift is just too much in stock suspension so my camber when turning is horrific. I’m think I will get 5100’s put them on the max setting and add the half inch lift spacer. It’s about 135 a strut and pretty hard to find on eBay. Anybody have recommendation on max lift on stock suspension? Only thing is I have the JBA Uca’s but they are pretty useless past 3.5 inches of lift when speaking on camber etc. I don’t want a drop kit so I rather just swap out the suspension and sell the rough country 3.5 coil overs if anyone wants a set I’m your man:spending:
  4. Mar 19, 2021 at 7:30 AM
    R0CKETMAN
    NGAMTNS
    yeah that’s 10.4” on presumably 8” rim so you should be GTG
    I’m running 285/70/18 on 9” +20
    5100s top setting plus two shims each side stock uca and no issues
  5. Mar 19, 2021 at 11:56 AM
    Cg13055
    South Florida
    I’m planning on the 5100’s top setting shims with JBA uppers. How are they treating you? I have a 2” rear lift as of right now on shackles will it be looking really weird with your lift or nothing too crazy. As long as the truck is proportional I won’t be too bothered
  6. Mar 19, 2021 at 12:01 PM
    Occidentalis
    Occidentalis Out Snakin'
    North Florida
    2015 Inferno TRD Pro
    295 70 R18 on the BBS wheels here, stock trd pro. The truck wears the outer edges too.
  7. Mar 19, 2021 at 12:07 PM
    Cg13055
    South Florida
    I wear my outer edges incredibly fast I never noticed why until I turned my steering wheels to an angle and went outside to see my camber. It was extremely noticeable how bad it was which gives me the idea that I am basically last the limits of the stock suspension in terms of geometry
  8. Mar 19, 2021 at 12:10 PM
    Occidentalis
    North Florida
    In my case I have no idea when the alignment was last done. New tires in soon, will try to sort it at that point.
  9. Mar 19, 2021 at 12:12 PM
    Cg13055
    South Florida
    Tundras are pretty hard to align most techs are lazy with it, your truck I think isn’t lifted so you should be good on that end. I am regretting the giant lift right now because my less than year old $900 tires are looking like they are 3 years old
