Lifted Truck Alignment Pros Chime in!
Discussion in 'Suspension' started by throughitalldude, Oct 21, 2019.
  1. Nov 11, 2019 at 3:53 PM
    throughitalldude
    throughitalldude [OP] New Member
    Jeff
    Southern California
    2017 Platinum
    3/1 Lift |TSS 20" Wheels | 35 Cooper AT3 XLT | Flowmaster 40 Series Exhaust
    Keep us posted I am headed to another alignment shop myself because i am getting wear on the outer edge of my tires so we will see what happens. If they get it dialed even better Ill come back with my new numbers.
  2. Nov 11, 2019 at 5:03 PM
    DM 2018 Tundra
    DM 2018 Tundra New Member
    South Carolina
    2018 Limted Tundra
    6inch RC with upgrade struts. 295/65/20 Nitto Ridge grappers 20x9 fuel vapor with 0 off set
    Ok. Will do. They told me at the aliment shop that probably need UCAS.
    Sunnier likes this.
  3. Nov 11, 2019 at 5:08 PM
    DM 2018 Tundra
    South Carolina
    2018 Limted Tundra
    Oh have you looked up coach builders. I am thinking if I can get the spec close enough getting them to help with bump steer and outside tire wear.
  4. Nov 11, 2019 at 5:16 PM
    DM 2018 Tundra
    South Carolina
    2018 Limted Tundra
    Just hit me. You have 3 or so on ur caster and still wearing your tires?? Maybe I need to tell them get close to 3 as they can if ur tires are wear. What kinda tire you running They told me that my camber needs to be brought in if there was room.
  5. Nov 11, 2019 at 5:59 PM
    throughitalldude
    Jeff
    Southern California
    2017 Platinum
    Yes I asked spoke with David at CB and he stated that based on my numbers he can understand why it’s wearing that way. I am going to give the new shop his numbers and hope for the best.
  6. Nov 12, 2019 at 11:45 AM
    DM 2018 Tundra
    South Carolina
    2018 Limted Tundra
    That’s what’s Iam going for now. They working on trying to get the this now 2432655E-3C93-4BB7-866D-3FFE3AF0F227.jpg
  7. Nov 12, 2019 at 11:47 AM
    DM 2018 Tundra
    South Carolina
    2018 Limted Tundra
    Is that the numbers you going for?
  8. Nov 12, 2019 at 11:48 AM
    DM 2018 Tundra
    South Carolina
    2018 Limted Tundra
    If I get them numbers going with CB if not guess I save up for icon UCAS.
  9. Nov 12, 2019 at 12:57 PM
    throughitalldude
    Jeff
    Southern California
    2017 Platinum
    Yes those numbers from CB you posted are where I am going to try and get the new alignment shop to dial the truck in at. David at CB was actually surprised that my truck achieved those numbers. He said that everything is way out of whack. Saying my toe is set to make each wheel fight each other. My camber he stated is definitely not where he would like to see it and he also said where my caster is at is definitely not ideal. He told me if the shop can get everything to his numbers he said i should see 110% difference in handling the second I leave their shop.
  10. Nov 12, 2019 at 1:40 PM
    DM 2018 Tundra
    South Carolina
    2018 Limted Tundra
    Yea he is very smart. Going to call my shop now and see what they have found out.
  11. Nov 12, 2019 at 3:06 PM
    DM 2018 Tundra
    South Carolina
    2018 Limted Tundra
    Keep me updated man and good luck. When I called my shop they told me not safe to go with RC specs. They going to see if they can get into spec for CB if so I will be getting them tomorrow.
  12. Nov 13, 2019 at 7:00 AM
    yoshi82
    yoshi82 New Member
    DAVID
    HOUSTON
    2014 Silver Tundra SR5
    3in ToYtech lift on Tundra and 2.5in in the rear. Tow Mirrors. Toyota grill, and Front bumber. New 6in antenna. Repainted the stepping boards
    This stuff is really confusing. Taking in my truck today, just did a lift and new wheels. It rides good but everybody tells me i need to get it alignment before i mess up my tires up. Is that true or False??
  13. Nov 13, 2019 at 7:17 AM
    throughitalldude
    Jeff
    Southern California
    2017 Platinum
    Anytime you mess with the suspension with a lift you should always have it aligned. You have to assume the changes you make have put you out of alignment spec. Its very confusing but luckily if you reach out to the right people on here you should be able to get it dialed.
  14. Nov 13, 2019 at 10:12 AM
    DM 2018 Tundra
    South Carolina
    2018 Limted Tundra
    What type of lift?
  15. Nov 13, 2019 at 11:02 AM
    yoshi82
    yoshi82 New Member
    DAVID
    HOUSTON
  16. Nov 13, 2019 at 12:23 PM
    Sunnier
    Sunny
    San Diego, CA
    What kind of lift? Coilover/ spindle lift gonna be different than drop bracket, spacer lift. If not already done, ask the alignment shop to note the specs as they are when you arrive. Then they can move toward whatever goal you want, but you will be able to articulate what ‘felt good’ to you.
    yoshi82[QUOTED] likes this.
  17. Nov 13, 2019 at 1:26 PM
    throughitalldude
    Jeff
    Southern California
    2017 Platinum
    Ok just got back from my second alignment and right away i can say it drives wayyyyyy different and much better! Now it drives like it did before the lift but here is the kicker.... they had to completely abandon the numbers CB stated. The alignment shop tried to achieve them and said they were unable to get the truck to get close to his numbers without UCA's. Keep in mind this shop does alignments by gauge not computers. Reviews said that they are one of the best alignment shops in the Inland Empire (Socal Area) because its not just a inexperienced tech using the computer to tell him what is in the green or not. The guy said to me trust me on this one we will align it to what we know works and if it doesnt drive how you like we will realign it however you want it no charge. So heres my new numbers
    Right Camber: -.25 Left Camber: -.25
    Right Caster: +5.5 Left Caster: +6
    Toe Right: -.06 Toe Left: -.06
    Truck drives amazing no feedback in the wheel from what I could tell.The tires we actually pretty loud in comparison to by old truck with 35" KO2's and I guess the alignment caused they cause they are extremely quiet now. According to his opinion he felt my original toe was way too positive causing the bump steering and the outer edge wear. He told me I was dragging my tires to a degree. He said had my toe been closer to .5" I would've destroyed these tires so thankful that didnt happen. Hope this helps everyone.
    kparrow and DM 2018 Tundra like this.
  18. Nov 13, 2019 at 1:56 PM
    DM 2018 Tundra
    South Carolina
    2018 Limted Tundra
    Great to hear that!!!! Since I am on a 6 in not 4 I don’t know if them numbers would help me?? Do you think the numbers you posted would work?I spoke with my shop and they can get mine to CB specs they said so I guess I be getting them this week.
  19. Nov 13, 2019 at 1:59 PM
    #49
    DM 2018 Tundra
    South Carolina
    2018 Limted Tundra
    That caster is high? Right? I can’t even get to 3.3
  20. Nov 13, 2019 at 2:09 PM
    #50
    throughitalldude
    Jeff
    Southern California
    2017 Platinum
    Yes and when I gave him CB's number he said he couldnt get my truck that low. I have a weird feeling CB's numbers may work for you give your a completely different lift then my set up.
  21. Nov 13, 2019 at 2:16 PM
    #51
    DM 2018 Tundra
    South Carolina
    2018 Limted Tundra
    Yea the aliment shop has worked on it for 2 days. Then can get be they said drives really bad. Lol. I am glad to hear you got it set bro. Makes driving the tundra a whole lot better now I bet.
  22. Nov 13, 2019 at 2:48 PM
    #52
    throughitalldude
    Jeff
    Southern California
    2017 Platinum
    Like a completely different truck....... sending good vibes they can get you dialed in.
  23. Nov 13, 2019 at 3:00 PM
    #53
    DM 2018 Tundra
    South Carolina
    2018 Limted Tundra
    The wheel was shaking at 55-65 they have that fixed. I will pick it up tomorrow around I hope. Then I get the CB if they get close or get new UCAS.
  24. Nov 13, 2019 at 3:21 PM
    #54
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    2" Tuff Country Level kit with axle drop, 5100's low setting. TRD front sway bar.
    First alignment shop told me after I installed the level kit that it was with in factory range. I said BS quietly in my head after paying $198.00 for 3 year plan. Today I brought it to another shop by the same national chain. and it was completely off.
    Alignment shop 2 have great numbers on paper, but it does track to the left for some reason, I did notice the abrupt steering response when I got on the highway changing lanes. It felt like my race car with max caster.
    I might eat the 3 year warranty and try taking it to 4x4 shop to get it aligned.
  25. Nov 13, 2019 at 3:55 PM
    #55
    DM 2018 Tundra
    South Carolina
    2018 Limted Tundra
    You have an offset on ur tires?
  26. Nov 13, 2019 at 4:35 PM
    #56
    SprinterAE86
    Ian
    Yes, 18x9 +12. 275.65.18
    They used a 2018 since they can't seem to have any data on the 19's and 20's.
  27. Nov 13, 2019 at 4:54 PM
    #57
    DM 2018 Tundra
    South Carolina
    2018 Limted Tundra
    Maybe @throughitalldude might can help on ur aliment. But I think more offset makes the lane change more difficult. I have 0 offset they stick out about 1-1.5
  28. Nov 14, 2019 at 1:31 PM
    #58
    DM 2018 Tundra
    South Carolina
    2018 Limted Tundra
    Update got truck back and was able to get the steering wheel jerks out of it. Ordered the CB today. Driving really good and hope even better with the CB on it.
    SprinterAE86 likes this.
  29. Nov 15, 2019 at 7:26 AM
    #59
    throughitalldude
    Jeff
    Southern California
    2017 Platinum
    So when I was at the alignment shop the guy told me he sees 9/10 vehicles with Toyo made tires have a shake of some size in the higher speeds. He claimed something about their sidewall rubber being stiffer then other brands and it can cause the tire to do what it wants at times. Not sure if its true or not but took his word for it because I could still feel a slight steering shake up in the 50-60 range. Called Americas tire about what I heard they immediately offer to take the Toyos back and gave me the tires I originally wanted KO2's.... havent felt the shake at all and they look alot better too:thumbsup:
    Pinay and yoshi82 like this.
  30. Nov 15, 2019 at 10:51 AM
    #60
    DM 2018 Tundra
    South Carolina
    2018 Limted Tundra
    That’s good. My tires was out of balance. I run nitto Ridge grappers
