Lifted Leaf Advice...
Discussion in 'Suspension' started by 1BadTundra, Feb 20, 2019.
  1. Feb 20, 2019 at 6:01 AM
    1BadTundra
    1BadTundra [OP] New Member
    Clinton
    2010 TRD Rock Warrior Crewmax
    Too Much to List
    I don't want to run this 4" block in the back of my rig. I also don't want to use an AAL, so I'm looking for a new leaf pack. I cant build my current pack, as my 2010 leafs are pretty much de-arched. I'm looking for a 2.5"-4" lift. What do y'all have?
    diablodalton likes this.
  2. Feb 20, 2019 at 6:03 AM
    seniramsu
    seniramsu Pro Runnin
    Nate
    VA
    2017 TRD Pro Tundra Wht
    I have Alcan leafs and couldn’t be happier. You can have them built with what lift height you want. And their customer service was top notch for me.
    Black Wolf and Sunnier like this.
  3. Feb 20, 2019 at 6:08 AM
    1BadTundra
    Clinton
    Too Much to List
    did you buy them straight from the manufacturer?
  4. Feb 20, 2019 at 6:11 AM
    seniramsu
    Nate
    VA
    Yes sir. I have attached their info. Give them a call and you’ll be good to go:thumbsup:
    jewsNbrews and Black Wolf like this.
  5. Feb 20, 2019 at 6:12 AM
    1BadTundra
    Clinton
    Too Much to List
    Thanks man!
  6. Feb 20, 2019 at 7:07 AM
    1BadTundra
    Clinton
    Too Much to List
    Just sent them the info... Thanks again!
  7. Feb 20, 2019 at 7:14 AM
    Vince
    Vince New Member
    Vincent
    Terre du lac, Missouri
    2011 White DBL cab 5.7
    K&N intake, Air bags
    You could do an air bag with the lift cup your needing for your height you wanted
  8. Feb 20, 2019 at 7:26 AM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    @froggy78 has some custom atlas leafpacks for sale 4”
  9. Feb 20, 2019 at 7:30 AM
    1BadTundra
    Clinton
    Too Much to List
    Sounds good, thank you. I'll msg him
    dcsleeper408[QUOTED] likes this.
  10. Feb 20, 2019 at 9:07 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Icon leaf pack can be adjusted to different heights. Then you can install a coachbuilder shackles for additional lift. Help eliminate bed hop as well.
    Wouldn’t a 4 inch thick leaf pack be almost the same as putting a 4 inch block? Would it be stiff? I think a small pack with a coachbuilder shackle be the best.
    1BadTundra[OP] likes this.
  11. Feb 20, 2019 at 4:01 PM
    joeguam
    joeguam New Member
    JOE
    2015 Toyota Tundra SR5
    Pro Comp 6 Inch Stage II Lift Kit with Icon 2.5 coil overs and piggyback rear shocks, SPC Upper Control Arms, Atlas 6” Leaf Springs, Coach Builder Steering kit, Coach Builder +3 Shackles, BDS Recoil Traction Bars, Amp Research steps, Fuel Nutz two piece 20x12-44 offset wrapped with 38” Toyo MT tires, LineX Bed Liner, Viper 5706V Alarm and Remote Start, Pioneer 4200, JLAudio Amps, JL Audio Subs. Nitro Gear 5.29 and Auburn LSD
    I too ditch the whole block lift and had both Alcan and Atlas. Atlas gets my vote for durability and customer service. Even after I gave Alcan aka Bill's all the specs and additional weight of what is in the truck, the springs started to warp. I have emailed Alcan on a couple occasions but customer service is crap. I had no choice but to purchase the Atlas and could not be any happier.
    dcsleeper408 and Sunnier like this.
  12. Feb 21, 2019 at 2:11 PM
    1BadTundra
    Clinton
    Too Much to List
    What lift is on your truck in your profile pic? It looks killer. Alcan just got me back... $800 for the set. I can get Icon for a little over $700 and they are adjustable.
  13. Feb 21, 2019 at 2:12 PM
    1BadTundra
    Clinton
    Too Much to List
    Leaning toward Icon now. I have adjustable shackles already, so these would probably be perfect
  14. Feb 21, 2019 at 4:16 PM
    joeguam
    joeguam New Member
    JOE
    Pro Comp 6 Inch Stage II Lift Kit with Icon 2.5 coil overs and Icon piggyback rear shocks with Atlas 6” Leaf Springs. I have 2 shims on the driver side coilover and 1 on the passenger side. I also have a bit preload on the coilover to give me additional 1 inch height for a total of 8" lift on the front. The rear has shackles to give me additional 1 1/2 height paired with the 6" Atlas.
    mtndds98 likes this.
  15. Feb 21, 2019 at 4:29 PM
    1BadTundra
    Clinton
    Too Much to List
    That thing is sick!!
  16. Feb 21, 2019 at 4:44 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    How much weight do you have in the back? Icon RXTs are adjustable but will get stiffer if you go that high without weight.
    dcsleeper408 likes this.
  17. Feb 21, 2019 at 4:47 PM
    1BadTundra
    Clinton
    Too Much to List
    Usually nothing... But when I load it up, I don't want it sagging as much as it does.
  18. Feb 21, 2019 at 5:27 PM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    Putting a big shackle on the icon packs will flatten em and probably compromise ride quality vs a stock shackle. Also the bushing in the Icon packs have teeth on the inner sleeve(like oem) that can cause binding and/or damage to the shackles. Toytec/Coachbuilder recommend replacing with a poly bushing.
    The custom packs are spec’d Out. I think they are called Valley springs out in Arizona and lots of people had good experience with them as well. Check them out too.
  19. Feb 21, 2019 at 10:45 PM
    brettski7
    brettski7 New Member
    Brett
    I’ll be getting some as well and going with Alcan. Reasonable price and each set custom built to your order
  20. Nov 22, 2021 at 7:43 PM
    How are the Alcans holding up? He quoted me 973 for the springs with 1/2 inch of lift and told me to use my Toytec shackles for the other 1.5 inches.
    How do you like the ride? Any pics of them? Thanks
    This post is the issue that I am having, and now I need springs. https://www.tundras.com/threads/drivers-side-leaf-spring-help.98375/#post-2504521
  21. Nov 29, 2021 at 4:27 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Mine just came in. Took about 6 weeks from the time I placed the order. Gonna slap em in this weekend. Can't wait. Lew and his team were a pleasure to work with. Walked me through taking measurements over the phone and then had his U bolt builder walk me through the U bolt fitment/order so I didn't muck that part up too. My lift is around 7.5" so he built my pack with 5" of lift. Can't wait to ditch the blocks.
  22. Nov 29, 2021 at 4:32 PM
    Please post plenty of pics and tag me when done. I just ordered some Alcans last week. Mine are being built with 1/2 lift and will be used with my Toytec shackles for the other 1.5. My OEM springs are flat at 13K miles. https://www.tundras.com/threads/2020-models-leaf-spring-issues.98791/
  23. Nov 29, 2021 at 4:34 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
  24. Nov 29, 2021 at 4:36 PM
    I have a 2 inch lift in the rear so they will fight it but the Toyota springs are pretty soft and weak for these trucks. One of the guys on here has a gap in his springs at 4400 miles.
  25. Nov 29, 2021 at 4:36 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I put add a leaves in mine so I guess I didn't notice any sag.
  26. Nov 29, 2021 at 4:37 PM
    Mine have the "W" wave going on.
  27. Nov 29, 2021 at 4:46 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I'd push hard for Toyota to replace them
  28. Nov 29, 2021 at 4:51 PM
    Why...the stock springs are crap. I already ordered the Alcans.
    AZBoatHauler likes this.
  29. Nov 29, 2021 at 4:51 PM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax
    I bought the skyjacker leafs, but they are still waiting to be installed. I believe they are advertised at 4" lift.
  30. Nov 29, 2021 at 5:07 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Principle I guess. You paid for a quality truck and it has sub par quality springs.
