Lifted 3" upper control arms??
Discussion in 'Suspension' started by TundraTJ2017, Jan 26, 2017.
  1. Jan 26, 2017 at 8:23 AM
    TundraTJ2017
    TundraTJ2017 [OP] New Member
    TJ
    2012 Tundra 4x4
    Lifted 3" front 2" rear, black rhino 18" wheels with 265/75/18 mxt rubber. Black led tails, painted mirrors
    hi all, new member first post. Recently lifted tundra with readylift 3"/2" spacer, block kit. Getting some minor tire rub at full tilt (parking spots) with 18" wrapped in mastercraft courser MXT 265/70/18 in front wells. Any quick suggestions on how to eliminate this problem, without welding in a curved bracket?? Also having a tough time getting alingment, alignment shop recommended upper control arms, but not sure of what brands/type recommended for such lift??? Any help appreciated!
    YotaDan likes this.
  2. Jan 26, 2017 at 8:24 AM
    TundraTJ2017
    TJ
    2012 Tundra 4x4
  3. Jan 26, 2017 at 8:34 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Welcome. What's your wheel offset? Where exactly is it rubbing?
  4. Jan 26, 2017 at 8:41 AM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Welcome! UCAs will def help with alignment issues. General rule is any lift 3" and greater should be accompanied with UCAs. There are many good UCA options out there depending if you want a ball joint or uniball, which will also drive the price. All depends on what you plan to do with your truck.
    Law323 likes this.
  5. Jan 26, 2017 at 8:44 AM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
  6. Jan 26, 2017 at 8:49 AM
    TundraTJ2017
    TJ
    2012 Tundra 4x4
    Believe it's a 12mm offset on the wheels and also running a 2" spacer off the hub. Rubs on bottom plastic above small mud guard front and rear of tub on fronts depending on angle. Have heard of heating and pushing in??
  7. Jan 26, 2017 at 9:05 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    If it is a 12mm offset, you probably don't need the wheel spacers. Probably get rid of the rub by removing the spacers.
    BarcelonaSX and Law323 like this.
  8. Jan 26, 2017 at 9:55 AM
    YotaDan
    YotaDan New Member
    Grants Pass, Oregon
    We offer a number of different UCA options to fix alignment issues.
