Lift
Discussion in 'Suspension' started by New2TundraTRD, Apr 28, 2020.
  1. Apr 28, 2020 at 2:29 PM
    New2TundraTRD
    New2TundraTRD [OP] New Member
    Adrian
    Ontario
    2011 SR5 CrewMax TRD
    Offset rims with lift in the rear w/275-65-18 10s
    I have a 2011 crewmax trd and I want to put a lift on. I have offset 18" rims on it now. Rubber sticks out about 4" from body. How high can I go without having to monkey with the steering, drive shaft and rear end? If you have part numbers for the kit that would be awesome too.
    Thanks
    Oh and what size tires will fit to make it look great?
  2. Apr 28, 2020 at 7:04 PM
    Too many options and variables. What size tires are you wanting to run to start with?
  3. Apr 29, 2020 at 8:58 AM
    f.pecan
    f.pecan New Member
    Forest
    2007 Tundra DC 5.7L
    Eibach COs and rear AAL., Morimoto XBs, Rough Country 20" Light Bar, Rough County Ditch Lights, CBI ditch brackets, rock lights,
    Seems like your offset is very negative if the rubber is sticking out 4" from the body. This will probably mean that you will need to cut more material to make the wheels fit (and not rub while turning).
    What are you planning to do with the truck? Will you be taking it off road at all? Are you concerned with preserving OEM ride quality, or are you just looking for something that looks good?
    In general, you can get away with strut spacers for the front suspension for any lift height less than 2.5". If you are going over 2.5", you'll also need to upgrade your upper control arms and add a differential drop, which will increase costs. Note the difference between the ReadyLift 3" SST kit and the ReadyLift 4" SST kit. The rear lift components will generally be the same (block, or shackle, or leaf pack replacement).
    Any lift kit over 4" will generally require some cutting and adding a drop bracket to the front suspension components. The rear end will generally only need some specific parts and some brake line extension brackets.
    What size tires are you running or planning on running?
  4. Apr 29, 2020 at 9:02 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I always advocate for a 3/1 lift. Looks good, allows for 35" tires, doesnt require cutting frame members, stable, safe, and ride with the right components.
    f.pecan likes this.
  5. Apr 29, 2020 at 9:04 AM
    csuviper
    Broomfield, CO
    BamaMan44 and texasrho83 like this.
  6. Apr 29, 2020 at 9:11 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    If you run super pos offset right? Pretty sure I would be rubbing with 35s on a 3/1 with -24 os
  7. Apr 29, 2020 at 9:27 AM
    csuviper
    Broomfield, CO
    I have not gone that far out with tires to know honestly. I have had my 35s with +25mm and +18mm.
  8. Apr 29, 2020 at 9:48 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Yeah I figured. Positive offset with the right amount of back spacing makes a huge difference
  9. May 1, 2020 at 6:22 AM
    New2TundraTRD
    Adrian
    Ontario
    I have fairly wide tires is why the previous owner put these type of rims on. Won't be off roading like jumping sand dunes and stuff butvifbibhad to cross a sloppy wet muddy field, I would like that option lol.
  10. May 1, 2020 at 6:25 AM
    New2TundraTRD
    Adrian
    Ontario
