Lift Question for daily rider?
Discussion in 'Suspension' started by TexMike, Jul 19, 2015.
  1. Jul 19, 2015 at 2:01 PM
    TexMike
    TexMike [OP] New Member
    15 Blk Crewmax TSS
    I'm new to Tundra and this site. just got a 15 Crewmax TSS black package. Is the leveling kit better or is the 3/1 lift better for a daily driven truck?. I drive 50 miles round trip to work.
  2. Jul 19, 2015 at 2:06 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Welcome Both are fine. 3/1 with new longer struts or coilovers in the front will give you the better ride.
    Check out the lift links in my sig for more information.
    15max likes this.
  3. Jul 19, 2015 at 2:12 PM
    TexMike
    15 Blk Crewmax TSS
    Thank you for all the info. Just trying to give the Beast the best look and ride, while not spending unreasonably
  4. Jul 20, 2015 at 1:19 PM
    chphilo
    chphilo Tundra addict
    Western PA
    Some people call 3/1 as a leveling kit. The boundary between a leveling kit and a lift seems quite unclear.
    I would personally avoid spacer lift/leveling kit. I've seen people breaking their front struts due to spacers more frequently than I would like.
  5. Jul 20, 2015 at 1:35 PM
    15max
    15max New Member
    Cole
    15 SR5 TSS 4x
    3/1 lift level, 35" Toyo Trail Grapplers
    3/1 lift, level. 1" block in the rear and 3" strut spacer in the front. Its okay for the time being but I'm saving for coilovers, diff drop and upper control arms so that I can push it closer to 4" of lift in the front and have better component's/ride. 35" tires in the picture. It is necessary to get 1.25" spacers if you keep your TSS wheels and put 295/65/20 (35" tire).
  6. Jul 20, 2015 at 2:53 PM
    TNTundra08
    TNTundra08 New Member
    Blake
    2008 DC 4x4
    3/1 lift. 20x9 Method standards, machine face. 305/55/20 nitto trail grapplers
    295/65/20 on a 3/1 lift? How much did it rub?
  7. Jul 20, 2015 at 5:44 PM
    15max
    15max New Member
    Cole
    15 SR5 TSS 4x
    I had to remove the front lower fender liner that went on the bumper and of course modify the skid plate. Besides that it would rub the sway bar at full lock, that's why I went with the 1.25" bolt on wheel spacers. Once I put those I had to remove the rear mud flap but now zero rubbing. I can't speak to if it would rub the stock bumper, the metal tabs sticking out, because I installed a NFAB front bumper before the spacers.
